Question about Refrigerators
Fridge and freezer not cooling
Freezer went bad about a week to ten days before fridge, just cleaned out the coils and fan.
    Problem Solver:
  • 15 Answers
Check the evaporator. it sounds like the defroster heater isn't working.
Posted on Jul 25, 2009
Freezer only gets down to around 18 degrees but fridge is fine. No frost on the freezer evaporator fan is running
Modern consumer refrigerators only have coils in the freezer. In the lower back of the freezer there is a small fan and possible a damper (flap that opens/closes) to push cold air from the freezer to the refrigerator. Given that the freezer is 18 deg, it's probably cold enough to keep the fridge area at typically 34 deg.
So the cooling system (compressor, coils, thermostat) are not working properly to keep the freezer at, typically 0 deg. Possible causes: partial loss of refrigerant gas, icing around evaporator coils (in freezer), compressor failing, dust clogging condenser coils (under fridge), condenser fan clogged or broken (under fridge), thermostat failure.
I'd start with condenser. Remove the slotted trim at the bottom front and look in with a flashlight. Are the coils clean? Pull out the fridge and remove the lower back cover (usually cardboard). You can now see the coils and fan. Clean and blow them out.
If it's icing, it probably means freezer door not closing tight. If auto-defrost not working properly it would probably get worse over the period of a few days so not likely.
Apr 21, 2016 | Frost Refrigerators
Where is the evaporator fan motor? My Freezer and fridge would quit cooling/freezing. I took the back panel off in the freezer a week ago and the evaporator coils were completely frozen over with ice. I...
I do not believe the problem is the fan. sounds like the frig. is low on Freon this is what will cause the ice build up. you need to find the leak, you can do this by spraying soapy water on coil tubes & watch for bubbles. repair leak & recharge.
May 25, 2015 | Samsung RS261MDBP Side by Side...
Evaporator fan
Usually the fan is automatically turned on when needed. Good job on cleaning the coils; number one issue with refrigerators.
Oct 29, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
CDA CI785/2 fridge not getting cold in fridge part. but the freezer works ok
If freezer is working then you must check for the cool air to come from the freezer coils. Shut off the fridge and check for the working of the fan, check the ducts from the freezer to the fridge. once you have confirmed the fan and the ducts and have cleaned up the coils, you can switch on the fridge. Notice if the fridge is cooling now, if so check later for any timer failure for frost build up blocking the duct. Keep an average setting for the fridge and freezer. Hope you try this out.Good day
Aug 10, 2010 | Refrigerators
Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Oct 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Fridge and freezer are not cooling well
hi.
If the evaporator fan isn't working, that's probably the problem. Test here>http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
thank u
rate me!!
Jul 20, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Feb 15, 2009 | Maytag Refrigerators
Motor runs, freezer defrosting and fridge won't cool
If you have frozen coil at the back of the freezer section, then the defrost thermostat is usually failing. Allow the fridge to defrost completely overnight. If the fridge restarts cooling immediately after defrost, then the problem was the defrost system. In that case the fridge will stop cooling again in a couple of days, as soon as the evaporator coils restart freezing and the condenser goes under stress with the whole cooling system loosing efficiency.
Nov 25, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
Fridge Problems
what model and make is it
Oct 30, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
