Question about The Office Equipment & Supplies
Service manual has a section for resetting ecm, but I no longer have the manual. It said something about a sequence turning key on and off
  • The Master
  • 2,185 Answers
Try disconnecting the battery and while disconnected turn the key to discharge any residual charge in the system and reconnect the battery after 15 minutes
Posted on Apr 18, 2017
Kyocera C6050 error
C6050 Error
Abnormally low fusing unit thermistor temperature
SIM 163 Reset (only do this one SIM, by doing others you could cause your machine to no longer function. Also see note at bottom.
Entering Simulation Mode
1. Press the system menu/counter key.
2. Select Service setting using the up/down cursor keys.
3. While pressing the start key and the # key, press the enter key. (Maintenance mode is entered.)
4. Select Maintenance mode using the up/down cursor keys.
5. Press the enter key.Enter the maintenance item (163 Resetting fuser problem) number using the up/down keys.
6. Go to step 1 under method below.
Resetting the fusing problem data Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Purpose
To prevent accidents due to an abnormally high fusing temperature.
Method
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Note:Sometimes in order to do the reset when the machine is in an error state you need to open the top cover (like to replace the toner) and leave it open until you have performed the reset
Jul 03, 2014 | Kyocera Office Equipment & Supplies
Bike fell on right side in my trailer now it won't start is the a reset sequence Thanks
TSM/TSSM BANK ANGLE FUNCTION
GENERAL
The turn signals, the starter motor, the ignition controller (ECM) and the coil will be disabled in the event the vehicle tilts more than 45 degrees from vertical for longer than one second.
CAUTION
If the vehicle is being operated with a sidecar, the setting MUST be switched from solo vehicle operation to sidecar operation or the TSM/TSSM will not function properly. If a sidecar is installed, reconfigure the TSM/TSSM using the method under Service manual VEHICLE DELIVERY instructions.
OPERATION
The engine will shut off automatically if the vehicle tilts more than 45 degrees from vertical for longer than one second and the engine will automatically shut off even if the tilt occurs at a very slow speed. To restart the motorcycle after shutdown has occurred return the motorcycle to an upright position. And then cycle the ignition key to OFF and then to ON before trying to start the vehicle.
Aug 08, 2013 | 2001 Harley Davidson FXD Dyna Super Glide
Samsung R4266w turns off automatically. I've
Rest the lamp hour meter
  • 1 Press menu on the DLP's remote.
  • 2 Scroll down the list to "Timer."
  • 3 Press "Enter" on the remote, then "Reset." Press "OK" to complete the process, and "MENU" to exit the menu.
Service Level Reset
  • 1 Turn off the DLP with the remote.
  • 2 Press a pre-determined button sequence on the remote control to access the factory reset option. These sequences are found in the owner's manuals of the various DLP televisions, or in the "Support" sections of the manufacturers' websites. Scroll to the "RESET" option on the menu to reset the bulb timer.
  • 3 Press a factory-determined combination of buttons on the remote and front panel of the individual DLP display to reset the bulb timer without entering a menu.
Aug 14, 2011 | Samsung Televison & Video
I bought a new battery from harley, installed it and it worked for a day. Now the lights come on and the security works, but the engine will not turn over. I looked in the manual and can't tell what I...
Look for "resetting the ECM" in the manual. I don't work on the ECM equipped bikes but I've heard guys talk about the procedure of turn the ignition switch on and off several times while pressing different buttons on the bike to "reset" the computer after a battery change. This is just something I've heard that you may find something about in the owner's manual. I do know that the security systems have something like this on them as well. That's why I don't work on them. I work on the early model bikes that the dealers will no longer work on. Shovelheads and Ironheads.
Good Luck
Steve
Aug 08, 2011 | Harley Davidson FLSTN- FLSTNI Softail...
How to reset service light
I think the following will work:
1 . Insert key into ignition barrel.
2 . Press and hold the Reset switch (located on the Trip Computer Switchpack).
3 . NOTE: The reset switch has to be released immediately after the ignition is switched 'ON'. This is critical to enable the rest of the procedure.
Turn the key to Ignition position II and at the point of entering Ignition position II (i.e when a click is heard), instantaneously release the Reset switch.
4 . Wait one second.
5 . Press and hold the Trip switch (located on the end of the left-hand side stalk).
6 . Wait one second.
7 . Press and hold the Reset switch (whilst still holding the Trip switch).
8 . The cluster should display (within three seconds) the warning message 'RESETTING SERVICE MODE'.
9 . Keep both buttons pressed until the warning message changes to 'SERVICE MODE RESET' (after ten seconds).
10 . Once the message is displayed the buttons may be released â€" sequence is now complete.
11 . If a Service Required message was displayed prior to the reset sequence, cycle the ignition to 'Off' and then back to Ignition position II and check that the message is no longer displayed.
Jul 12, 2011 | 2005 Jaguar S-Type
Service engine soon light stays on. I had the oil changed and the filter but didn't see any reset on these devises.
Will not reset it's self you need to reset your ECM on your car's computer. Do this by Turniing your ign. key to on position then turn on a/c then disconnect your positive battery terminal. wait 30 sec then turn key off and replace battery cable. Good luck to ya. PS, If something else is a problem this will put the code back to your ecm and will come back on. But this should fix your problem.
Mar 24, 2011 | Saab 9 3 Cars & Trucks
Error code c6000 of copystar cs1815
Purpose
Method
Completion
Note:Sometimes in order to do the reset when the machine is in an error state you need to open the top cover (like to replace the toner) and leave it open until you have performed the reset.
Mar 20, 2011 | Kyocera COPYSTAR CS-2050 Printer
Service engine light no longer turns on when key is turned and car wont start
ck fuses, either ecm does not have power, or the ecm maybe bad.
Jul 05, 2010 | 1995 Honda Accord
Reset service interval on instrument display W210
Try this:
1) Turn key to position 2.
2) Press/release the R button to show the next service due light. Release button.
3) Turn key to Off.
4) Press and HOLD the same R button to view the service light, THEN, within 2 seconds, turn key to position 2.
5) Wait up to 10 second and the light will reset to show new service .
Lone99star
Apr 29, 2009 | 1994 Mercedes-Benz C-Class
Speed / tach 'ometers don't work
Turn Ignition key OFF. Push and hold Odometer reset button until indicator lights come on. Wait until sequencing is complete and all will work again.
Nov 17, 2008 | 2001 Dodge Grand Caravan
29 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Gareth Cockram
Gareth Cockram
Peter March
Peter March
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
