Question about The Watches
I have a wadsworth pocket watch serial number 1184734. It is unusual because it has a strange drawing below the 12 spot on the face. Could you help with any info I would appreciate it. Thank you
SOURCE: Pulsar Men's analog wrist watch - how to set day and date
Pull crown out to 1st position....Turning one way will alter the date and turning the other way will alter the day.
Posted on Jun 11, 2008
escapement
  • 2334 Answers
SOURCE: opening an elgin pocket watch
The best tool to do it is watchmakers knife, but any proper knife with hardened steel blade can do the job. Make sure the blade is NOT flexible.
Check carefully the sides of your watch and you will notice the groove. Place knife blade into that groove and press it in. At the same time try to make a scooping turn to lift the caseback. Usually there must be underlayed caseback as well and it opens exactly in the same manner.
Make sure you do all this carefully and do not let the blade to slip or your watch will end up with nasty scratches or even damaged movement.
That job isn't a big deal, but requires some skill, so, BE CAREFULL.
Don't forget to rate, please.
Posted on Jan 05, 2009
SOURCE: antique hamilton pocket watch how to open
Pull the wind knob out...it takes a firm pull on mine. You will hear it click, then you have room to pull the movement out towards the hinge. Then close when done, and push the wind handle back in.
At one oclock the lever is pulled out about 1/4" then you can set the time, when finished, push the lever back in.
Hope this helps...george
Posted on Jun 14, 2009
cmcduncand
  • 714 Answers
SOURCE: antique pocket watch
Case info does not help in dating a watch, A movement serial number helps greatly.
r/
David
Posted on Jan 22, 2010
cmcduncand
  • 714 Answers
SOURCE: I have an Illinois pocket watch and I can't figure
The back screws off.
Turn it Counter clockwise.
The numbers you need is the actual serial number off of the movement not the case.
We then can provide you the production information on your particular run of antique pocket watch.
Hope this tip helps.
r/
David
Posted on Feb 19, 2010
Can you tell if a wadsworth pocket watch case is solid gold by the serial number inside the case itself
it will have a stamp with 9K or 22K or if plated it will say gold filled
Dec 26, 2017 | The Watches
Can I get a D&G watch serial number check to see if it’s genuine before buying (SN:8068W) (247704-39
The only sure way is to take the back off. There are many Chinese copies around at present and people are passing them off as the real thing.
How to spot a fake D&G Watch ' eBay
www.ebay.com/gds/How-to-spot-a-fake-D-G-Watch-/.../g.html
This guide might help someone not be taken in by buying a fake D&G watch or the full brand name Dolce & Gabbana. ... (see pictures below). Don't panic if you have bought a D&G watch and you are worried it is a fake - here are some simple tips on how to tell:- *Check the stones ... A fake will loose its stones very easy. D & G watch serial numbers Google Search
Dec 13, 2017 | Watches
Find out if a watch i have is worth money
Check to see if your watch or one closely resembling it, is for sale on Ebay. This generally gives an idea of value, at least in terms of resale and value. Watches, other than Rolex and very high end types, don't have very good resale value. Of course, all of the value may be in the diamonds or 14K cases, no matter who is the maker.
Dec 13, 2014 | Waltham Watches
I have a 9k waltham pocket watch and cant find any info about it, or the value of it?
A little bit more information would help the Fixya staff to address your question.
Please be as specific as possible adding as much information as you can provide will ensure a more accurate response to your question.
The below information is currently requested:
-Serial number from movement.
Mar 21, 2010 | Chase IK7A Waltham Antique Watch
Deuber watch co. Pocket watch serial no. 2549465
If the serial number came off of the movement the pocket watch was manufactured between 1909 - 1910.
Hope this tips.
r/
David
Mar 02, 2010 | Watches
Have a waltham pocket watch in an illinois case enameled dial with a recessed seconds dial at bottom with a numeric 6. seconds on face also. can't find year or pic of this watch
If you go to the web site "www.antique-pocket-watch.com/waltham-pocket-watch.html", you will find information about Waltham watches and if you read the serial number off the movement (open the back and read it off the back plate), you may be able to find out the year of manufacture.
Feb 10, 2010 | Chase C6A Waltham Antique Ps Bartlett...
How find serial number on ~1910 hamilton pocket watch?
The serial number is usually engraved on the movement. If you open the back of the watch, you should be able to see it.
I looked at the Hamilton pocket watch site (in might be helpful if you visit the site, simply type "hamiltonpocketwatches.com" into your search engine and your will be able to examine photos of a number of movements).
The position and size of the number varies but it shouldn't take to long to find. One of the pictures I found impossible to see the number but the rest I found, although sometimes you had to look quite carefully.
Jan 29, 2010 | Sterling J3E Hamilton Antique Pocket Watch
Antique Hamilton pocket watch how to open? I unscrewed the face and see a notch at the bottom and a hinge on top of face. I tried prying upward at notch but it did not want to open. I was applying enough...
Jun 13, 2009 | Sterling J3E Hamilton Antique Pocket Watch
Antique pocket watch
r/
David
Oct 15, 2008 | Colibri Swiss CSQ Pocket Watch
Watches Logo
20 people viewed this question
Top The Watches Experts
D. E. Hev
vince
gbob59
Are you a The Watch Expert? Answer questions, earn points and help others
