Question about Toshiba Televison & Video
I was watching tv and then my tv just stopped. It turned up with little black and gray pixels. How can I get it back to the normal screen?
It's a Toshiba tv and I already try turning the power switch on and off for one minute.
  • 790 Answers
did you hear the sounds? or maybe you have defective power source in hot side..
Posted on Oct 02, 2007
  • 829 Answers
SOURCE: monitor went black
Try reinstalling the Display
Posted on Mar 31, 2009
  • 63 Answers
SOURCE: Toshiba tv screen goes black every 5 minutes with sound still on
Is it ok when you watch regular TV thru the cable or sat?
Posted on Sep 03, 2009
  • 666 Answers
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Posted on Mar 26, 2010
SOURCE: Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Posted on Feb 21, 2011
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
Have a thin green line near bottom of screen
Pixels stuck in the "on" position may revert to normal operation with a little pressure. Use a small piece of tape to show where the line runs and turn your screen off. Slightly dampen a soft cloth and apply gentle pressure to the stuck pixel line. Don't press too hard or you may make the problem worse. The idea is to gently flex the screen material and encourage the pixels inside to shift out of the permanent "on" position. Work slowly, applying gentle pressure along the whole line. Turn the screen back on when you've finished to see the line's response. Repeat as necessary until all pixels are back to normal
Mar 02, 2015 | Televison & Video
Picture goes black with gray fuzzy lines ~ 1/2" apart horizontal.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sanyo DP50749 50 in. Plasma TV
Black band across bottom of screen
Is the black band is about one two inch thick have to check the back light section of your lcd tv. All lcd tvs have back light to illuminate the pixels. Two types of back lighting are there CCFL (cold cathode fluorescent Lamp) and LED. In your tv its CCFL. CCFL need high voltage 1000V or above . For providing this high voltage there is inverter stage ( back light inverter). Also there will be 12 or more CCFL behind the lcd screen. If any on of there CCFL failed the there will come a gray bar noticeable only when there is hight light.
There will be two causes for this problem.
1. CCFL is faulty.
2. The inverter transformer driving CCFL is faulty.
You have to check the inverter fist. For conforming which one is faulty do the following.
There is independent connection for every two CCFL from the inverter board. Try interchange the two nearest connection. And watch is the line is shifting or not after every interconnection. You have to try by interchanging all the nearest to connections for CCFL.
If the line shifted then the inverter board is faulty. If the line stays there then the CCFL is faulty. Normally there will be problem with inverter transformer. If the transformer is faulty then you have to replace the inverter board as a whole.
Jun 11, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
All three lights turn on like normal and then nothing
Depending on the pitch. humming noises are either a motor ie: fan motor or if it is very low a defective capacitor . Since you have the yellow band and the high pitched beep my fist thought is somthing defective in the power supply. Take it to an authorized servicer.
Apr 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Vertical black bar down the middle of hitachi plasma tv
Ok if your hitachi TV dies with no power anywhere try this:
Some models have a kill switch under the bottom edge. It's like a gray switch like a small light switch press it back in and voila let there be LIGHT. Saves you at least a $200 trip to repair shop!!
Jan 05, 2009 | Televison & Video
Straight out of the box had 3 pixels out, Now 2 days later a Black Circle.
The white spots are called 'dead pixels' and depending on the manufacturer, they may allow a certain number of them but normally not in the primary viewing area.
The other anomaly shouldn't be there and LCD displays are not affected by magnetic fields as are CRTs.
Return it quickly and I would be reluctant to accept a simple exchange.
Do some checking on the Dynex brand before you take it back though to see if this kind of quality is common to the make.
You might start here:,GGLG:2005-37,GGLG:en&q=dynex+lcd+problems
Jul 06, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
My Samsung Plasma just got burned in!
I stupid friend of mine came over to feed my dogs when I was out. He watched my Plasme tv for a while and when he shut the system down he only turned the cable box off for opprox. 6 hours. I did have th Tv on pixal shift . Know my screen seams grainy in dark scenes . I does seem a little better after a rolling picture screen. How long do need to run the screen before it gets better?
Apr 02, 2006 | Samsung HP-R5072 50 in. Plasma HDTV
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
