My fire tv not sign in now ??? - Televison & Video
I disconnected my firetv stick to send back.but then i realized i never took my info,password,etc. Out of it.do i need to reconnect it to delete info?
I would absolutely reset the firstick.
Steps To Reset Your Fire TV or Fire TV Stick
  1. On your Fire TV device, click Settings
  2. Scroll over to the right and click System
  3. Scroll down and click Reset to Factory Defaults
  4. A dialog will appear that reads "You are about to reset your Fire TV to its original factory settings. Your sign-in information and personal preferences will be lost". Click the Reset button.
  5. The system will go through the restore process and this can take approximately 5 to 10 minutes. Be patient and wait for your Amazon Fire TV to reset.
Nov 02, 2017 | Computers & Internet
How do I install sling tv to my fire stick
I just googled your question and got this:
How does it work?
It's easy! Here's how:
  1. Connect your Amazon Fire TV or Amazon Fire TV Stick device to your TV's HDMI port, and set it up as its instructions specify.
  2. Download the Slingplayer for Fire TV app to your Fire TV device.
  3. Using your Amazon Fire TV remote control, scroll to Apps. Select the Slingplayer for Fire TV app to launch it.
  4. Sign into your Sling Account.
  5. Use the Directory to connect to your Slingbox.
  6. Enjoy watching your programs ... no matter where your TV is!
Apr 25, 2017 | Televison & Video
How do I install sling tv to my fire stick?
I googled your question and got this
How does it work?
My fire stick wont allow me to sign into my internet connection
Just incase the problem is still on going, I want to assume that you have disconnected and reconnected the fire stick with your HDMI slot. Perhaps tried a different HDMI slot on your TV? Does your TV recognize the fire stick when you plug it in? If not, remove a device that you know works, from their HDMI slot and plug in the fire stick. It should be recognized by your TV. If not, return the fire stick to the store. Depending on where you bought it, they may be able test it with you there. Best Buy is really good for this, but you need to ask.
Moving on, once the TV recognizes the fire stick in the proper HDMI slot, it is just a matter of finding your wireless network, logging on to it and go forward & do great things!
just follow the setup steps on the setup menu. I reran thus through my Amazon Fire equipment to make sure.
As long as there isn't advanced security set up on your wireless router, there should not be any problem.
I would be very curious to know if this helped you.
Regards,
Mar 29, 2017 | Internet Computers & Internet
How do I start watching Netflix on my hitachi smart TV
Open the Netflix app and sign in to your account!
Dec 24, 2016 | Netflix
I want to access Netflix on my television. I have a fire stick but I also get adverts when I use 'on demand' or 'search' etc. How would I pay if I joined on my television?
I use a FireStick and it does have Netflix. I would recommend signing up using a computer first (they give you 1 month free) and then you can use the same credentials to sign into Netflix through the FireStick. If you are asking whether you are already signed up on Amazon Prime, then I suggest you sign into Amazon and check your account through there. If you are, then you will have access to lots of content on the FireStick as well. Hope my answer helped. : )
Aug 20, 2016 | Computers & Internet
Problem with getting tv to fire up, takes about 20 minutes of pushing power button to start.
Recent Fire TV software updates causing blank screen issues
www.aftvnews.com/recent-fire-tv-software-updates-causing-blank-screen...
Aug 17, 2015 - Ever since Fire TV software update 51.1.6.1 and Fire TV Stick software update ... update, Fire TV devices now enable HDCP immediatly at boot up. ..... I'm still getting this blank screen issue on one of my TV's but not the others.
How to Get Your New Fire TV Device Up and Running - Wired
www.wired.com/2014/12/amazon-fire-tv-setup/
WiredDec 25, 2014 - Here's how to take that new Fire TV device from zero to streaming in five easy steps. ... How to Get Your New Fire TV Device Up and Running .... I'm not sure why this is not an issue for Chrome Stick, et. al but I invite you to ...
Report Amazon Fire TV / TV Stick Playback issues here - Plex Forums
forums.plex.tv > Google TV & Amazon Fire TV
Jan 10, 2015 - Indicate if your problem is for the Fire TV/ TV Stick or both, if the FireTV, .... when playing files back, i'm getting the same freezing issues regardless of ..... to have to refresh content about 25% of the time when I first fire up Plex.
Jan 10, 2016 | Televison & Video
Can I use my daughter's login info? She added me to her account. I now have Fire Stick but cannot get Netflix using her info.
Here are the directions from Netflix (https://help.netflix.com/article/en/node/23934?ba=GSButtonClick&q=). Is this what you've been trying?
To connect your Amazon Fire TV or Fire TV Stick to your Netflix account, make sure you are on the Home screen and follow the steps below.
  1. From the main screen, select Search.
  2. Type "Netflix," then select Netflix.
  3. Select Netflix.
  4. Select Download.
  5. When the download completes, Open.
  6. Select Sign In.
  7. Enter your Netflix email address and password to sign in.
Your device is now connected to your Netflix account. Enjoy!
Apr 26, 2015 | Netflix
Cancel 30 day free program
then I suggest you go to amazon . we can not help you get out of something you signed up for
Feb 16, 2015 | Amazon Fire TV Stick
Kindle fire HD
This is usually a sign of a bad HDMI Cable or Port. Replace the HDMI cable if that does not work contact Amazon for a replacement device.
Mar 22, 2013 | Amazon Kindle Fire HD
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
