Question about Dishwashers
Model DMT800RHS/XAA have oE code blinking when drying cycle is half thru and machine shuts down. dishes clean but still wet.
4 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: when the wash cycle is done, the dishes are wet
It seems that the newer dishwashers are worse at drying dishes than their tupperware melting predecessors were. They have all been tuned down, and do dry less. The only thing that you can do is to set your machine for the hottest wash, power dry and use a rinse agent that provides a sheeting action. Some folks use white vinegar as a supplement to their rinse aid, which has the added bonus of killing mold. Water also stays attached if the water has laid down minerals as noted by cloudy glassware. If this is the case, a dishwasher filter (dishwasherfilter.com, $70) might help. We try to wash hot, with a power dry and use a rinse aid/vinegar. Then, when the cycle is complete, but the dishes are still hot, we open the dishwasher, and "jiggle" the racks to get the excess water off of the glasses, and leave the dishwasher open about 2" at the top, so the dishes will continue to air dry. This has been an effective method for us.
Best regards, --W/D--
Posted on Aug 03, 2009
  • 901 Answers
SOURCE: Dishes stay wet after going thru dry cycle. Can
check hot air. Refer service center
Posted on Apr 30, 2010
heatman101
  • 43501 Answers
SOURCE: dishes dont seem to be
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenanceDishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 26, 2011
When i turn on the dishwasher and cycle has run and its finised . the dishes come out cold and wet
sounds if the drying cycle isn't working , most washers use a small blower fan to move air thru chamber 2 dry dishes , these little fans do rust up over time and need replaced sometimes , id say finding fan and cking it for rust and freedom of movement is a first step in this , most times there inside door of machine
Dec 21, 2016 | Dishwashers
Fixed problem after viewing 93 code but now dishes have brown film or white film. Dishes still dried on food. Have a Samsung DMT800RHS. One suggestion was to get phosphorus which is ******* for deterg
look at the arm that has the water nozzles on it to see if some of them are plugged. Also make sure the screen at the bottom of the machine isn't restricted.
Nov 06, 2014 | Samsung DMT800RHS Dishwasher
LG wm1832CW Front load washer , error code OE and shut down, drain cleaned pump ok, ?
Yes, could be that the pump has dropped down on the efficiency.
check this link for tips to reset or rework the pump
Click on Pump
Jan 15, 2013 | Washing Machines
The "clean" light blinks 8 times, then there is a pause, then it blinks once. The dishes are clean but not dry, as if it has not completed the drying cycle. We had an engineer out to fix it who said it...
I'm not familiar with Kenmore but it sounds like a faulty heater element. The flashing 'clean' light normally means a water flow problem (blocked pump etc) but since it's washing that isn't the problem. After washing they dry with steam, which needs a heater.
It may be a problem with the board, as your engineer thought, but i would sooner replace the heater, but they are not easy to reach.
A suds sensor may be present, should be a plastic grille or hole in the side or back wall halfway up, this you can flush with a garden hose, messy but it usually works!
Mar 28, 2017 | Kenmore Dishwashers
When the wash cycle is done, the dishes are wet
Aug 03, 2009 | Siemens Dishwashers
Bottom drawer won't clean or drain
My top draw F&P won't drain, it seems to want to go thru the cycle, but then leaves about 3 inches of water. no codes are displaying. No extra beeping. please help!
Jun 30, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher stopped drying dishes at end of cycle
check the heating elemt circut and make sure that heated dry has been selected it the machine allows to need the model of the machine for more help
May 05, 2008 | Dishwashers
Does not go thru dry cycle, clean light blinks 7 times
clean light blinking is a tricky problem to find and cure can be a few different issues.heres an edited down version of official manufacture explaination,its been an issue (I would call manu for assisstance in repairing this further)
A heater fault detection program has been added to the electronic control to check for temperature rise and shut down dish washer. If the temperature rise is less than the criteria, then the unit will drain and blink the clean light 7 times. The Proper incoming water temperature should be between 120°- 140° F.
Possible causes of insufficient temperature rise would include wires off at thecontrol, heating element, thermistor,inlet valve, door switch, motor or capacitor, failure of any of the above components or siphoning of the water during fill.
Feb 27, 2008 | Kenmore 24 in. 16034 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
