Delete print queue - Office Equipment & Supplies
  • 24 Answers
SOURCE: there is a frozen deleted job in my print queue
turn off the printer and unplug it from the computer. after which you restart computer
Posted on Mar 27, 2009
len52155
  • 20 Answers
SOURCE: can not print...jobs are held in queue
go to administrative tools THEN SELECT SERVICES. STOP THE PRINT SPOOLER SERVICE. then see if the item is still in the print queue.. if so delete it .. but I think it'll go away when you stop the service. when it does.. restart the print spooler
Posted on May 20, 2009
  • 13 Answers
SOURCE: Can't delete document from printer queue. Can't print anything.
I've had this problem several times, and the only solution is to restart your system. Once rebooted, the printer will continue printing your other documents
Posted on Jun 07, 2009
dburns60
  • 410 Answers
SOURCE: deleted print job stuck in queue
You can always restart the computer, that will "unstick" a print job that gets stuck deleting.
Posted on Jul 05, 2009
57 varieties
  • 1653 Answers
SOURCE: my last print job gets stuck deleting in the queue!
Go to C:\Windows\System32\spool\PRINTERS on your PC and you will see two files listed fior each of the outstanding print jobs. These will have the file extensions .SHD and .SPL
You need to delete both of these files then power off and power on your printer to be able to continue printing.
Posted on Sep 24, 2009
What to do if after canceling the printing in queue document its status is still showing deleting ?
Give it a few minutes. Sometimes it takes awhile to delete the document.
If that fails, turn off the printer, wait a minute, then turn it back on. The document should be deleted.
Jun 29, 2015 | Office Equipment & Supplies
How do I delete a print job?
turn off the printer and remove power to the printer. Job will be stored in printers memory. Go to p.c you printed from and check printer queue see if job is in printer queue on p.c as well and then delete from queue. If it does not delete from the queue go to if windows p.c the services under control panel and stop and restart the spooler service.if print job is stuck in the printer queue.
Mar 10, 2015 | HP Envy 4500 e-All-In-One Printer, Copier,...
So far answers don't coincide with the directions I've been given, which is "Press the WSB Button for 5 seconds."
The print queue is what is locked up. Try deleting the items in the print queue.
Start by pausing the print queue. Then delete the items in the queue one by one.
When you have the last print job in the queue it will probably be jammed up in the transition between the computer and printer. Switch off the printer. This should cause the printer on the computer to become offline.
Try deleting this job abain. If it dissapears then turn the printer back on making sure the computer understands the printer is back online. Then try printing again.
If it does not dissapear then you will need to restart the computer to free up this job. When the computer is back up and running check the print queue again. If the job is gone then turn the printer back on and try printing again. If it is not gone then try once again to delete the print job and it should dissapear this time.
Once the job is gone and the print queue is empty turn the printer back on and make sure the computer understands it is back online again.
Oct 14, 2014 | Canon Office Equipment & Supplies
Canon pixma mp610 cant delete the printing queue or print
This is not the fault of the printer but windows. Open the Control Panel, select Devices & Printers, find your printer, click on it, select Delete Print Queue. Problem is fixed.
Jan 07, 2013 | Canon PIXMA MP610 InkJet Printer
How to access print queue
You can find the print queue going to Start-Settings-Printer and Faxes, Open printer and faxes by clicking and You will find the printers installed. Select your printer probably the one which has tick mark on it ( default printer) double click to open and see the files in queue. You can delete the queue if printing stucked.
Other way to delete the printing queue if not getting deleted from the above method is to go to start-.>run type "services.msc"
search for print spooler service in the rights side pane, right click the service and stop it. Now again go to Start->run type
"spool" and hit enter. It will open up folder for you, double click on PRINTER folder and delete all the files in that folder. This will clear up the queue from printer. After deleting all files, go to again follow the same process to start the print spooler service. Go to start->run-> type "Services.msc" hit enter, on the right side pane search for printer spooler service, right click and start the service.
Hope this helps
May 19, 2010 | Microsoft Office Home and Student 2007...
Document stuck in queue and will not delete or print.
Its a common problem. All you have to do is to restart the Print Spooler service and delete the print queue. To restart the service follow the steps: Open Control Panel > Administrative Tools > Services. Now find service named "Print Spooler" and right click over it and select "Restart" to restart the service.
Now open the "Printers and Faxes" folder and try to delete the print queue. Now you will be able to delete the print queue. If applicable you can follow the steps once again if any print queue refuse to get deleted.
Once the print queue is empty, you can print from your printer smoothly.
Cheers!
Apr 05, 2010 | Dell 926 All-In-One InkJet Printer
I tried to delete a print job and it is stuck in the queue. Won't print or delete
Thanks for using FixYa!
Try to turn the printer off then restart or reboot your computer. Then pull up the print queue then delete the documents in queue. I hope this helps.
Have a wonderful day.
- HotRatchet
Jul 30, 2009 | Lexmark X2500 All-In-One Printer
Can not print...jobs are held in queue
May 20, 2009 | HP Deskjet D4260 InkJet Printer
My last print job gets stuck deleting in the queue!
Feb 15, 2009 | Lexmark X5470 All-In-One InkJet Printer
22 people viewed this question
k24674
