Question about Reebok Exercise & Fitness
Reebok z8 treadmill with error code 7 - Reebok Exercise & Fitness
4 Suggested Answers
diodeic
  • 1622 Answers
SOURCE: My reebok 8000c treadmill has
Hi,you will need too contact a reebok 8000c treadmill expert for help. You can use the link below for help...Take care..
http://www.treadmilldoctor.com/RBTL060080-REEBOK-8000-C-FRONT-ROLLER
Posted on Apr 07, 2011
ercupa190
  • 12223 Answers
SOURCE: reebok treadmill Z8 error E-01
Dear Sir:
Thank you by your request, I will help you inmediately.
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Thank you in advance, sincerely. God bless you
If you need further assistance, contact me
E.CUADRA
MANAGUA, NICARAGUA. C.A
Posted on Sep 29, 2011
colmheneghan
  • 7 Answers
SOURCE: reebok z8 feels like its on an incline even when it's on zero incline
Is there a certain procedure for calibrating the incline motor for my reebok z8 running machine.
If so can you send me a copy please?
Its driving me bananas.
First of all I bought it second hand and the guy says the incline was working when he sold me it.
But its not.When the running machine is on and incline rises from 1 -12,but doesnt move..
I've taken the cover off aIn pic 1 i came across the bottom micro switch switch in the on position.
When I released the switch by lifting it up past the switch actuator,it decided to go again only when i started adjusting the potentiometer.
I started with some help from my son,when he adjusted the incline button on the panel it may have went up to 8 or 9 incline and then decided to keep going...
i switched it off in time before it loosened itself off the machine..
I adjusted the pot up and down slowly clockwise and anti clockwise hoping to get it set right but it drove me bananas..it does do each section from 1 to 2 ..3 to 4 etc but when it gets past 6 it keeps going too far incline and doesnt stop!!
i measured the pot and it seems fine..goes from 0-10ohms ok..
i need to know if there is a set up procedure
I am assuming also the two micro switches are emergency or am i wrong..
i have sent you some exrtra photos of it and I d appreciate if you could help me out..i cant run on it when its dead flat (seemingly your'e not supposed too ..)
Ive set it above the end line at the bottom so hopefully i can run better at this stage but id like to get it going for myself..
please help
Posted on Jul 26, 2015
What is fault code E03 on Raebok Z8 Run treadmill
E03: This indicates a fault with the mounted speed sensor on the drive motor. Contact technical support.
Official Reebok Fitness
Mar 02, 2017 | Exercise & Fitness
Error code E-02 on a reebok z8 treadmill
Hi. Have error code e2 on reebok z8 can you advise what this is.
Thank you.
May 31, 2014 | Reebok Exercise & Fitness
Reebok z8 error E03
I can not adjust my tension on my machine
Feb 27, 2014 | Exercise & Fitness
Reebok Treadmill error code 5
Exactly same just happened to my brand new Zr9 (error 5). Reebok said they would replace the motor or complete tredmill or my money back. Undecided as to what to do but thought i was buying a reliable bit of kit ??? They do cover it with 2yr warranty and it is really nice use, will research a bit more before deciding.
Feb 20, 2014 | Reebok Exercise & Fitness
My Reebok Z8 Treadmill says 'E-02' on the display screen. It is constantly beeping and fails to work, How can I fix this?
Run the software calibration for easy diagnostic, and fix it. The speed sensor, can be dirty or faulty, test with s.calibration. see the diagram attached.Read you owner manual or go HOOD cover motor and follow the instruction.
Oct 23, 2013 | Exercise & Fitness
What are the error codes for a reebok treadmill
go to the website from Reebok and download the manual for to see the error codes or get the support.God bless you
https://www.iconservice.com/CustomerService/manuals.do?dr=RB
Oct 18, 2013 | Reebok Exercise & Fitness
Reebok z8 won't turn on
see the video and fix it. see too the block diagram
God bless you
Jan 19, 2013 | Exercise & Fitness
Z8 reset
1)adjust the reed switch, clean , and tight the wires connector very welll, see the diagrams
2) Tight the ribbon cables, from keypads. tight the display board vs lower board.
3= Try again and proof.
God bless you
Jun 14, 2012 | Reebok Exercise & Fitness
Z8 is showing L5 cant seam to fix this
Dear Sir:
I will try to help you, please use the steps with patience and carefully: You must need some basics tools; Included Dvom (Digital Voltemeter).
Instructions Things You'll Need for to Reset Code:
  • treadmill (all models applicable)
1.
    • 1
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
    • 2
Press the "ENTER" button three times to access the treadmill's error log.
    • 3
Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
    • 4
To view the treadmill
Oct 19, 2011 | Spirit Fitness Z8 Treadmill
Reebok treadmill Z8 error E-01
Dear Sir:
E.CUADRA
Sep 28, 2011 | Exercise & Fitness
Exercise & Fitness Logo
64 people viewed this question
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
