I have been told I must put a dead rat in the pit so it may decompose and keep the bacteria going and that I must not put any chemicals that may kill the bacteris. Is it true?
    Top Expert:
  • Washing Mach... Master
  • 24,726 Answers
I wouldn't in my washing machine!
Posted on Apr 18, 2017
My 2007 hyundai azera has a dead animal smell i changed the cabin filter and it still stinks
If you described the smell as old socks it could be sick car syndrome.
Bacteria grows like crazy in the damp environment of the air-con evaporator that is buried in the heating and ventilation system, particularly in the damp days of autumn and early winter.
Products are available to treat the problem though they aren't cheap. Ask for details at any good car accessory shop or air-con specialist.
Dec 16, 2017 | Hyundai Cars & Trucks
How do you unclog a septic tank?
It Differs how it come what child ceptic tank a cesspool That it will not be working by the use of chlorine the chlorine kill the bacteria which are responsible for the normal operation of the process.
A septic tank is emptied by a sludge gulper and then must simply be stopped unblocking because the pit stops working
A dead bird or other animal brings bacterial action back or another piece of meat, then the well will again usually a good season function differently remains overflowing cesspools are made this way,
May 19, 2016 | Plumbing
Morphy Richards iron smells bad.
Do you use distilled water in your iron. The filters may have bacteria on them, especially if the filter does not get very hot. Bacteria thrives in dark, wet environments. The bacteria has moved away from the filter into the iron, so changing filters would not help much for very long. I would buy a new iron that does not use filters and only use distilled water in it. Distilled water stops mineral deposits from forming inside the iron.
Dec 05, 2015 | Morphy Richards Irons
How do I moisten it so it is not dry
Depending on how much tobacco you want to re-hydrate, get a terra-cotta pot and break it into pieces and soak a piece (or several pieces) in distilled water. Put the soaked chunk(s) in a plastic zip-lock type bag with your tobacco. Leave it overnight and check the tobacco for moistness.
Be sure to use distilled water and a new pot to start. It might be a good idea to boil the terra-cotta in water for ten minutes or so in order to kill bacteria. Using tap water can introduce bacteria and chemicals (chlorine) into your tobacco. You do not want that.
The terra-cotta will prevent soaking your tobacco with too much water and causing mold.
Apr 07, 2015 | Cooking
How can I get rid of unpleasant odors in my home?
Proper maintenance of your home and HVAC systems are crucial to air quality. By timely changing the purifiers and by checking it on regular intervals can help you to breathe fresh air and to stay healthy. The most commonly used purifiers are summit air purifier, cloud air purifier and many more. Know more
Sep 30, 2014 | Home
Turn the key and it will not start
cold weather kills batteries this time of year...heres why..most batteries are a chemical factory..the acid and water separate as the battery discharges..also the chemical process is lessened when the air temps go below freezing by around 50% or more depending on the age of the extreme cold areas, external heat sources are required to keep engines warm enough to alaska for example,the batteries are taken out entirely and put inside to keep warm..sometimes a fire pit is used to warm the engine from below (red hot coals no flame)..also in very cold weather, the engine oil will get very some cases the oil will actually glue the engine semi solid..locking it up..if its a cheaper oil that whathappens..I like 20 miles north of st louis in illinois and when it gets below 30 degrees outside i place a under cabinet 350 watt heater(used for keeping food warm to serve) upside down under my engine overnite..this keeps the block warm and the oil thinned out..and works very well for car will start whe no one elses will in my neighborhood..hope tyhis helps you..
Feb 09, 2013 | 1991 GMC Sonoma
Is using termite control around my garden dangerous for my family?
Any use of chemicals poses some level ofrisk, but with the right precautions it doesn't have to be dangerous to yourfamily. Read this article to get more information about Termite/carp/ antkiller products and their risks.
Jul 17, 2012 | Bonide Termite/Carp. Ant Killer Conc. 1...
No spark
there are 2 wires that go to the kill switch. bare them both and put a jumper between the 2 to insure insure its not a switch falure. if you get spark, get a new switch or continue with the jumper. be sure to keep the bare wires from touching metal or youll just ground it out again and it wont start
Feb 11, 2010 | Pit SSR 110CC Pro Beginner Bike
Odor is present within washing machine. It smells stale.
Run a load of whites and make it fairly strong with bleach. Bleach is essentially nothing more than chlorine (sodium hypochloride). It kills bacteria very efficiently and will kill the bacteria causing the smell in your washer. I do this at least once per month to keep the system cleaned out and I don't have a smell even if my wife forgets to take the load out for a long time. Beware, however, that if you have a septic system, the bleach may kill off the good bacteria that digest the nasty stuff in your septic tank and drain field. Thus, it's always a good idea to add septic system bacteria once a month. You simply flush it down the toilet. You don't need to worry about this if you are on a public sewer hookup. Hope this helps.
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
