ETH 303 2017 memo - Computers & Internet
Can Rate Limiting Be Configured for an Eth-Trunk on a Modular Switch and How Can the Configuration Take Effect?
The modular switches(such as S2309TP-EI-AC) support rate limiting for inbound traffic on an Eth-Trunk. This function can be configured using the qos car command. After this command is executed:
· If the member interfaces of the Eth-Trunk are located on different LPUs, the configured rate limit applies to each interface individually.
· If the member interfaces of the Eth-Trunk are located on the same LPU, the member interfaces share the bandwidth specified by the rate limit. The bandwidth is distributed on the member interfaces randomly.
Jul 25, 2016 | Office Equipment & Supplies
Tip
How to wire Phono Jacks/Plugs and Power Supplies.
A, any, MONO Jack/Plug it is always wired the same. There are only 2 wires, one + Plus, Positive. and one, - Negative, ETH, GND. The Minus, GND, ETH, - Negative, always, logically, goes to the or Negative or "Case" ETH, Gnd, those terms all mean the same. Now the + Positive is always Plus,. If the connection is for a Coaxial Cable then, the inner core is Plus +, and the Shield is always - Negative, Gnd, Earth. All Jacks and Plugs wire the same. With a Phono MONO Phono Jack, the "Bulb End" is always Positive, the Case or Outer is - Negative. NOW, IF the Jack/Plug is a STEREO one, then with that type of Plug/Jack there is simply, Two + Plus Wires, and, Two, - Negative, Eth, Wires, these Two, Negatives, Earths all Contact together, and go to the Negative or Outer Connection. The Two + Plus Wires, go, One to each of the tip connection, of the Two Positive Connections, that go to the end, Bulb Tip A & Tip B, of the Stereo Jack./Plug.
For Power Connections the same is generally true, the Centre Conductor is usually Positive, while the other one is - Negative, case, eth gnd.
on Feb 18, 2010 | Computers & Internet
Why Cannot an Up Interface Be Selected as the Working Interface?
The reason is that this interface works in half duplex mode.
On a switch such as S5700-28P-LI-AC, S5700-28P-PWR-LI-AC, if the rate of an interface is the same as that of member interfaces in an Eth-Trunk, this interface can be added to the Eth-Trunk. However, if this interface works in half duplex mode, the Eth-Trunk will not select it as the working interface.
Jul 01, 2016 | Computers & Internet
How to recover deleted voice memos on iphon6
If you did not backup your iphone with iTunes or iCloud , the recovery software for iPhone users may help you retrieve the deleted data, you can get them back in few steps.
Tips to Retrieve Deleted Voice Memos on iPhone 6 5S
May 25, 2015 | Audio Players & Recorders
What is the easy way to transfer iPhone voice memos to computer?
The easiest way is to email the voice memo to yourself. You can do so by clicking on the memo, then click on the export icon, then select email.
If you are trying to save multiple voice memos, you can just back up your device to iTunes on your computer.
May 12, 2014 | Apple iPhone Cell Phones
Huawei MA5616 ETH port and GE0 port ?
This is a Telco DSLAM switch for an enterprise DSL ISP.
Here's a link to the manual. Read it. What the difference between ETH port and GE0 port for Huawei MA5616
Mar 25, 2014 | Computers & Internet
I need a audio driver for my computer
Download REALTEK PHRE10/100PCI ETH RJ45 100MB nc-r150201 Network Adapter Drivers
  • http://www.free-4all-download.com/REALTEK/REALTEK+PHRE10/100PCI+ETH+RJ45+100MB+nc-r150201+Network+Adapter+download
  • http://www.softitem.com/driver-intel-realtek-phre10-100pci-eth-rj45-100mb-network-adapter-frequently-asked-ques
  • http://www.alldriversfree.com/013/drv/realtek-phre10-100pci-eth-rj45-100mb-nc-r150201-network-adapter
Sep 19, 2011 | Intel REALTEK nc-r150201 Network Adapter
How can I recover accidentally voice memos from iPhone 3G
When you lose your voice memos in your iPhone, they can have a look at your iTunes first, maybe you've synced the voice memos to iTunes, and the voice memos can be found in iTunes folder. If not, you may need to restore your iPhone with iTunes to recover deleted voice memos. If you have updated your iPhone backup in iTunes, you will save the voice memos in iTunes backup as well, so you are able to get the lost voice memos back with iTunes.
recover-accidentally-voice-memos-from-oxaxc0rwhkhzilrwacqreyis-3-0.jpg When the restoring process is done, you will get the backup contents in your iPhone. The voice memos should have been restored to your iPhone as well. However, as is known, there is chance that the iPhone users will lose the newly added data in their device if they haven't updated their backup. At this moment, you will need a piece of iPhone data recovery software to recover deleted voice memos from iPhone backup.
http://www.leawo.org/tutorial/how-can-i-recover-deleted-voice-memos-from-iphone-6.html
Nov 01, 2010 | Apple iPhone 3G Black Smartphone
Memos soft resets device
Sounds like you may need to clean out your memos. Are you talking about the memo icon on the screen or do you have a memo button on the button panel. If you have a memo button, there may be something wrong with it, and you may have to use the icon.
Apr 01, 2008 | Palm TX Handheld
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
