Question about Philips Televison & Video
Philips lcd locked on digital channel remote will not change channel although tv light flashes when remote pressed
  • 188 Answers
Press TV/DTV button on the remote.
Posted on Jul 24, 2009
Philips tv digital disappeared
There may be a firmware upgrade needed here--ask Philips what is available for this model.
Jun 13, 2012 | Philips 37PFL5332D 37 in. LCD Television
How to program philips universal remote
  • Turn on your TV (or other device). You will have to do this manually until you program your Philips remote control.
  • Look for the "Setup" or "Code Search" button on the Philips remote control. Which button your remote has will depend on the exact Philips remote control you are using. This button may be a different color or may be labeled.
  • Hold either the "Setup" or "Code Search" button for about 10 seconds. If your remote has a light, the light should begin blinking. If there is no light, you can just count to 10 and then let go of the button.
  • Press the "TV" button on the remote to program the Philips remote to your television set.
  • Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television
  • Dec 04, 2010 | Philips Televison & Video
    Need to how to set remote philips TV an DirecTv
    there are several. try each one seperate.
    1. press and hold setup button until the red light stays on.
    2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
    3. enter one of the 4digit codes.
    note: if the code is valid the light will turn off if it flashes it is an invalid code.
    4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
    these steps will set up the first device and then to set up the second device just repeat the steps choosing the other device and the code for it.
    CODES: for the tv: 0514,1174,0062,0204,0184,0208,0205,0206,0207,0004,0189,0183,0019,0200,0081,1149,1154,0288,0456,0003,0008,0068,0075,0086,0087,0141
    for the direct tv: 1049,1766,1767,1768,0622,0632,0629,0623,0576,0586,0616,0613,0630,0634,0636,0638,0641,0652,0653,0657,0659,0607,0619,0537,0538,0539
    If none of the the codes work try following these steps:
    1.manually turn on the t.v.
    2.press and hold the setup button.
    3. press and release the tv button the light will blink once and then stay on.
    4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
    5. press and release the mute button to store the code the light will go off.
    Aug 28, 2009 | Philips Magnavox Learning Universal Remote
    Philips Flat TV locks up on one channel and won't change
    hi i need help cause my philips47pfl7704dif7 when i turn on the tv it just turn blue and wont let me change sources or channels . Help me.
    Jul 25, 2009 | Philips Televison & Video
    Zenith TVBR1352Z TV/VCR combo. I cannot get a code to allow my Philips/Direct TV remote to control the TV/VCR. All I really need it to do is control the volume
    Find and press either the "Up" or "Down" channel button on the remote. Continue pressing either button until the television channel changes. This may take several minutes. Once the channel changes, press the "Power" button on the remote to turn off the TV. Your Philips remote will now be programmed to your television.
    Jul 09, 2009 | Zenith TVBR2562Z 25 in. TV/VCR Combo
    PHILIPS 32PF7331/12 LCD TV
    Press tv on sky remote then press help ,channel list appears . goto tv set use onset channel change button to scroll to hd channel .press volume up button onset to select.
    Sep 28, 2008 | Philips 26PF5320 26 in. LCD Television
    Code for apex tv through philips universal remote
    Go to www.urc.philips.com/
    Follow the steps..its easy. It will ask for the model of your remote which you will find where your batteries are located..The code I used for my APEX tv was 0023.. to load the code first hold the setup button until the red light stays on..then press tv or whatever mode you are setting up..then enter the code and if the red light goes off it is the right code and you should then press channel up to see if it works...If this code doesn't work the site above offers other codes.. Hope this helps!!
    Aug 30, 2008 | Apex Digital ADV3800 DVD Player/VCR
    How can i program my rc16 direc tv remote control to my philips tv
    1.Press menu on your remote and then go to settings and press select on setup.
    2.Go to remote and then go to reset remote.
    3.Press and hold MUTE and SELECT until the light above the mode on tv switch on the remote flashes twice.
    4.Enter the code using the numbers on your tv.
    5.you have cleared AV1,AV2 and tv modes.Move the switch back to DIRECTV;press select on done.
    Jul 10, 2008 | Directv RC23 Remote Control
    Philips universal remote codes for symphonics tv
    Manually turn on the device you want to control
    1. press and hold the CODE SEARCH button til the light stays on release the code search button
    2. Press and quickly release the desired button ( TV, DVD, etc ) the red light blinks off once
    3. Press the CHANNEL UP button repeatedly ( up to 300 times ) til the device changes channel and stop
    (the red light will blink off after each time the channel up button is pressed )
    4 Press the MUTE button to set the code
    hope this helps
    Nov 23, 2007 | Televison & Video
    Televison & Video Logo
    106 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
