Question about Geneva Audio Players & Recorders
I have just bought a Geneva Lab Model L and would like to add more speakers- do I use the line-in or air plug - please help.
I'm looking for a male to male monaural audio cable to connect my Labtec LCS-3210 speakers. I bought these speakers 20 to 30 years ago, and the last time they were hooked up, they still played...
http://www.ebay.com.au/itm/DIY-6-5mm-Male-Plug-Mono-Audio-Adapter-Connector-Gold-/170560976732?pt=AU_Electronics_Accessories_Wires_Cables&hash=item27b639f75c
Ebay $1
You might get these on Ebay im not sure which country you are in this might guide you to one
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Jul 11, 2011 | Labtec LCS 3210 Computer Speakers
Hello. Just bought a pl990 and trying to connect it to creative speakers for the meantime. Im using a female rca plug but the sound wont come out in the speakers, nor is it working on my pyramat chair or...
The problem is that the output signal from a phono cartridge is very low. A turntable is meant to be plugged into a receiver or amplifier with a turntable input designed for that level. An auxiliary input on an amp is made for a higher "line-level" input. To use a turntable with a line-level input you need a preamp (here's a typical model at Amazon.com) to boost the signal to the amplifier. Then you'll be able to play your records and hear them.
Jul 02, 2011 | Pioneer Audio Players & Recorders
Hello. I just bought your spa4310 speakers and I linked correctly the subwoofer to my computer (Acer with realtek drivers) and the speakers (red plug to red socket - white plug to white socket). The...
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Jun 09, 2011 | Philips Audio Players & Recorders
I need audio device for my computer to perform my sound
You probably need the device-drivers for either the audio-circuitry on your computer's motherboard, or for the add-in audio-card.
The speakers are just speakers -- they receive "line-output" signals, amplify them, and move the air inside the speakers to make air-pressure variations, which you interpret as "sound".
So, what manufacturer of computer?
What manufacturer of motherboard?
What model-number of motherboard?
What Operating System?
If there is an add-in sound-card, what manufacturer, and what model-number?
Oct 09, 2010 | IBM Audio Players & Recorders
My gateway died and I am trying to move them to my Dell but get no sound. Power light is on.
Double check the connections (the line input from the speakers, usually green plug, must go at the line out of the computer, usually green plug). Also check possible muted audio, In case the problem stays, post me back your Dell model to locate the audio drivers for you.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 26, 2010 | Boston Acoustics BA735 Computer Speakers
Connecting NAD 2600a amp.
Never connect incompatible connections. Speaker outputs are for speaker inputs. Period.
The various inputs on this or most any amp are for Line Level signal with the exception of anything explicitly labeled "PHONO" as that would be for a non-preamplified turntable ONLY.
From what I have found online, Lab-In was a NAD feature that restored the frequencies that were rolled off when turntables were being used in the (assumed) preamplifier that fed this amp.
http://web.295.ca/~peak//audio.html
"NAD belleived at the time that practical PHONO stages and the preamp and power amplifier stages be rolled off at subsonic frequencies to prevent subsonic wow and flutter from Turntables and supersonic frequencies (EMI/RF/Radio) signals from getting into the system in the first place. Their notion was that if your ears cannot physically hear it, then why amplify it. For the PURIST, there were a set of LAB IN amplifier inputs with more extended response called "LAB IN" inputs"
Use the Lab In's UNLESS you have a turntable source.
Aug 22, 2009 | NAD Audio Players & Recorders
Connecting speakers to Computer
In most cases the woofer plugs into the speaker which contains the power adapter plug, the green plug goes into the PC's audio out (usually a green plug on the back of the unit). When the USB is plugged into the machine the OS should plug and play the new hardware and may ask you to insert a driver disc if applicable.
After the OS has identified the new hardware and installed it you should be able to test additional audio out plugs if you are unable to hear sound from your first choice (again, ideally the green plug). There should also be a line out plug which may work for your purposes also.
If you are still having issues please post the model of your speakers so that we may look them up...
Feb 25, 2009 | Dell Vostro 220 Desktop Computer
It's usually the green plug that you hook up speakers to. If you look closely at the sound card area of your computer, you will see little pictures telling you which one is for the mike, line in & speaker.
Feb 14, 2009 | Acer Aspireā„¢ T180 PC Desktop
Top Geneva Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Geneva Audio Player and Recorder Expert? Answer questions, earn points and help others
