Question about Panasonic Televison & Video
Panasonic TC-P42x5 tv- power does not work. Red light does not turn on.
  • 8617 Answers
SOURCE: Panasonic TC-32lx60
I work for another site that sells service manuals and provides free tech support, and there is nothing in the manual about error codes. The power supplies would need to be troubleshooted. The manual is anew one but if you would like a copy send them an email and they will upload it to the website for you to purchase, they email all manuals that one was scheduled to be loaded to the site this weekend but they will upload it earky if youd like it. Heres the link.
Posted on Apr 29, 2008
SOURCE: 4 blinking lights
I fixed it myself!
I bit the bullet and ordered a replacement Power Board for AUS$290 and swapped it out myself.
Only took ten minutes, most of that time was removing and replacing the 101 screws holding the back panel on!
Working fine again now.
I did sit the two boards side by side and noticed the new one had moved some of the micro components from the back of the board to the front plus some other small component changes.
If your handy with a screw driver and have some technical knowhow I recommend having a go at fixing it yourself as it wasn't hard and probably saved $200 in service charges (all this assuming you are out of warranty!)
Posted on Oct 27, 2008
  • 718 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
  • 78 Answers
SOURCE: my TV just turned off and the power light flashes
thought I would post this here for everyone.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Posted on Feb 26, 2011
SD Tech
  • 14553 Answers
SOURCE: Panasonic Viera 65 inch tv shut off, will not turn back on. Red light blinks 7 times.
Power supply or related to it.
Posted on May 26, 2012
Power went out and tv not working. do I plug back in holding the on/off switch
Try a reset and if it does not work, has to be open and check power supply board and the other boards. Good luck,
Feb 16, 2016 | Panasonic TC-P42X5 42" 720p Plasma HDTV...
I did a hard reset on my tv Panasonic TC-P42X5 to come back on after a power outage. It worked!But NO VOLUME! I can't get volume to work. There is no sound, just picture.
Turn it off and wait about three days and see what happens. There were quite a few pannys sold a few years ago around 2011 where if the power was interrupted like that , they would not work normally until about three days later. Crazy, I know. But ...................
Sep 25, 2015 | Panasonic Televison & Video
Modle number tc-p42x5
The sudden drop in operating voltage may have caused the power supply to fail.
Mar 05, 2014 | Panasonic VIERA Televison & Video
How to reset a viera panasonic model#tc-p42x5
A tutorial on how to reset your TV at
Sep 20, 2013 | Panasonic Viera Tc-p42x5 42" Inch Flat...
Power light red no sound no picture
Red light is standby, it turns green when TV IS turned on. If the red light is flashing then there is a problem and number of flashers are a code to indicate a fault type.
Sep 19, 2013 | Panasonic TC-P42X5 42" 720p Plasma HDTV...
Panasonic tv
If the front panel indicator is on and pressing the power button does not produce results, there could be a blown fuse internally or something wrong with the power supply
Jan 10, 2013 | Panasonic TC-P42X5 42" 720p Plasma HDTV...
How to hook sound bar to panasonic viera 42 inch model TC-P42X5
The aftermarket audio/video cannot allow you hook your Tv and Dolbys stereos becauses of incompatibility issues.
Jul 24, 2012 | Panasonic Viera Tc-p42x5 42" Inch Flat...
Televison & Video Logo
41 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
