Question about The Office Equipment & Supplies
Can the cover of the ML100 typewriter be removed so that I can reattach the spring inside the machine?
  • 19 Answers
SOURCE: BROTHER ML100
Ok,there could be two possibilities ,1, The daisy wheel may not be seated in properly. Of course I assume that the print side of the daisy wheel is facing the platen and that when the typewriter is switched on the print unit makes its customary re-setting motion and that the daisy wheel spins around at the same time. if this does not happen make sure that the lock-in lever for the daisy wheel is pushed home.. I am sure that you do all these elementary things so the only other possibility is the the hammer seleniod is not fully functioning and would have to be re-placed....Good luck!
Posted on Nov 15, 2007
SOURCE: ibm Selectric III typewriter
To Tholloway;
The problem is in the shift clutch. Unless you know how to remove the upper case there isn't a lot you can do.
DickyO
Posted on Jul 18, 2008
Geno111
  • 183 Answers
SOURCE: Typewriter is an ML100 Standard Brothers Typewriter
repost if you are still having this problem
Posted on Nov 01, 2008
typewritrman
  • 32 Answers
SOURCE: remove a label stuck to the metal floater behind the pleten myself
Take a quarter piece of typing paper. Soak it in paint thinner. Roll this down where the label is stuck. The paint thinner will dissolve the adhesive on the label but will not harm anything in the typewriter.
Posted on May 17, 2009
  • 44073 Answers
SOURCE: brother ML100 typewriter. How can I type a Spanish n?
The tilde is a special character not available on a standard typewriter keyboard.
Posted on Feb 16, 2016
Brother ML100 typewriter. How can I type a Spanish n?
Feb 16, 2016 | Office Equipment & Supplies
How do I put the pinwheel back in
Remove the ribbon, pull the release lever (I believeit is black and and to the right of the P/W), drop theP/W in with the tab to the right, close the lever.
DickyO
Jan 24, 2013 | Brother Ml100 Standard Electronic...
Where do I find a cartridge for a Model ML100?
We have them in stock.
DickyO
Cleveland Business Machines
216-241-0027
sales@cbmohio.com
Sep 13, 2011 | Brother ML-100 Typewriter
Typewriter ,brother ML100 STANDARD : I CHANGED THE DAIZY WHEEL AND PRINTING REBBON. THE PRINTER IS NOT COORDINATE WITH TYPING KEYS WHEN I TYPED. EXAMPLE , IF I TYPE B , A DIFFERENT PRINT INSTEAD .
Turn the machine off and allow it to rehome itself. If that doesn't help the printwheel homing pawl is probably broken. you will need a tech.
DickyO
May 04, 2011 | Brother GX-6750 Typewriter
My typewriter does not print. I do not have a manual or instructions for this typewriter. Is there a code I will need to insert in order for it to print...delayed or otherwise? Thank you!
Check that the daisy wheel is properly installed and if the ribbon has been used up. Try pressing and holding CODE and then press Reset. (This needs to be done after the daisy wheel, correction tape or ribbon is replaced.)
The daisy wheel has a protruding ear that should be on the top right. To remove, open the cover, pull the lever towards you and lift the wheel by that ear. To reinsert, insert the wheel in the slot and press down gently. Then slide the lever forward to lock the wheel in place. Then close the cover and reset the carrier (CODE+Reset). Make sure that the ear is to the top right when you reinstall the daisy wheel.
The amount of ribbon left can be determined by looking through the viewing hole on the right hand side of the cassette when the cover is open.
The manual is available here: http://www.brother-usa.com/manuals/default.aspx?PGID=10&R3ModelID=ML100 as a PDF.
I hope this helps.
Nov 09, 2010 | Brother ML-100 Typewriter
How can I get printer ribbons for this Brother ML 100 typewriter? Can you give me the code #?
The Brother ML100 uses the BRT 1030. There are several supplies available like the lift off tape, the daisy wheel and of course the printing cassette.
check it out:
Brother ML100 Typewriter Supplies
Good luck and if you need anything you can always call or email.
Duane ONeil
www.FJAproducts.com
800-982-9989
bc.cbi?cbdid=423141670777502444&wdid=1041068402873934082 8 to 5 (pst) Mon-Fri
Sep 15, 2009 | Brother ML-100 Typewriter
Remove a label stuck to the metal floater behind the pleten myself
Apr 24, 2009 | Brother ML-100 Typewriter
Aug 28, 2008 | Brother ML-100 Typewriter
Striker Sticking When Erasing. Brother ML100 Typewriter
Sounds like the gears you cleaned may be dry and sticking, spray a little WD40. or that gear on the right side is still out of time. I think there is a spring clutch in the gear train which may be bad. One secret to repairs is to perform the same actions that you want the typewriter to do by hand and watch closely. You may see something not movving, or moving slow that under power you won't see.
Aug 14, 2008 | Brother ML-100 Typewriter
Make sure that the correction tape is place in the guides one on each side small metal guides, remove ribbon to see, it should be behind ribbon guide (closes to you). Dry lift-off tape only(#3015)
Dec 05, 2006 | Brother ML-100 Typewriter
26 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
