Question about Electronics - Others
I have an F5 converter, but it does not turn on and now I need to replace it and load the parameters, where can I buy it? And someone can help me to copy the parameters of previous converter.
Sir i have keb f5 inverter i need default parameter i am trying to external run but i do not have parameter.
There are over 1500 parameters in the inverter. These have been setup by the manufacture of the machine so that the machine functions the way it was intended to in a safe trouble free manner.
Before one defaults the inverter you should always use the COMBIVIS software to obtain a complete upload of all the parameter values. This way you can always get back to the settings before the inverter was set to default.
Also with the COMBIVIS software you can access all the parameters in the inverter. With the software the Fr parameters are where you would find how to reset the inverter to default values.
Dec 11, 2013 | Inverter KEB COMBIVERT F5
Sir i do not have default parameter
What default parameter are you looking for.
There are many parameters in the F5 inverters. Best source of information as to how the unit is programmed is to obtain this from whom you purchased the inverter from.
Hi, We have KEB F5 inverter on our machine model
If you are connected to the inverter with COMBIVIS, go to parameter FR.01 and enter a value of -4. This will set all parameters back to factory default.
You may be having an issue with the inverters software verison. As long as the inverters are the same part number, you should be able to download the parameters without any issue. There may be some unknown parameters but you should be able to hit ignore and keep on downloading.
Oct 26, 2013 | Inverter KEB COMBIVERT F5
Internal program error
There are many differences between the F5-C control and the F5-B control, but basic functionality is the same. Just looking at the control terminal strip will show you some of them.
You also have two physically different sized inverters. The C control is in the G housing and the B control is in the E housing.
Sep 04, 2013 | Inverter KEB COMBIVERT F5
I use KEB 18.F5.CBG340A (22,0 kW) "Compact"inverter , to run this inverter whose parameter must be set from cp mode and application mode
The CP mode parameters are a small list of parameters that are mapped from the application parameters. Not knowing what you are trying to do with the inverter, it is very difficult to tell you what needs to be programmed.
90% of the machines that us the KEB inverters use the application parameters to gain the full functionality of the inverter.
The machine manufacture whom built the machine that the inverter is installed in should be able to provide you with parameter settings.
There are instruction manuals on the KEB site.
www.keb.de
www.kebamerica.com
I fit a new keb f5 inverter which parameter set to run motor
Pretty general question. If it is a replacement inverter, best source would be to upload parameter values from original inverter with the COMBIVIS software.
Otherwise I would suggest downloading the manual from the KEB web site.
Aug 24, 2013 | Inverter KEB COMBIVERT F5
Inverter KEB COMBIVERT F5 parameter
The manual that came with the inverter has instructions on how to go from mode to mode.
If you do not have the manual, these can be downloaded from the KEB web site.
Jul 21, 2013 | Inverter KEB COMBIVERT F5
Fault
at the first i want to know the error message appear after switch on the power on the drive with out any load or with load .
Jun 26, 2013 | Inverter KEB COMBIVERT F5
When inverter fitting, some parameter are set please name these parameter
What F5 inverter are you asking about? There are many different control stages and each has different default parameter settings.
Nov 14, 2010 | Inverter KEB COMBIVERT F5
Hello I'm use keb f5 inverter. I have to return to the factory parameters. How I'm do it?
It is strongly suggested to contact the OEM of the machine that this inverter is being used on to obtain the actual parameter settings that are required.
Oct 11, 2010 | Inverter KEB COMBIVERT F5
Electronics - Others Logo
133 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
