Question about Dymo Office Equipment & Supplies
Hello~ We have a Dymo LabelWriter 450 label printer. It started taking a long time to print. It use to be quite fast but lately has been taking forever before it finally prints anything. Suggestions?
SOURCE: Dymo Twin Turbo Labelwriter not printing stamps
This is the response from dymo stamp. I did as they said and am now printing stamps again.
We have seen this cause problems with the .NET framework Microsoft uses and Dymo Stamp uses. Follow these steps to correct it Step 1: Download Microsoft Windows Installer CleanUp Utility
1. Visit:
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
2. Save the file on the Desktop.
3. Please double click the msicuu2.exe file to install it on the computer.
Step 2: Remove .NET Framework
1. Click Start -> (All) Programs->Windows Installer Clean Up.
2. Please locate and remove Any .NET Framework 2.0 software.
After that, please perform the following suggestions to reinstall .NET
Framework 2.0 and its updates. Step 3: Reinstall .NET Framework Version 2.0 SP 1
Please download and install the following
Microsoft .NET Framework 2.0 Service Pack 1 (x86
http://download.microsoft.com/download/0/8/c/08c19fa4-4c4f-4ffb-9d6c-150906578c9e/NetFx20SP1_x86.exe
Note: When the "File Download" window appears, please click Save, and follow
the directions to save the file on the Desktop. After downloading all the
setup files, please double-click on each one to install them.
Posted on Apr 28, 2008
  • 60 Answers
I would uninstall the software and reinstall it from this link: http://www.labelcity.com/resources/labelwriter-drivers-downloads.shtml
-Ernest
Posted on May 01, 2008
SOURCE: New labelwriter 400 turbo will not print under windows 2000
I had the same problem and accidently discover it was something very simple...at least in my case. I noticed the power cord connection was very good.. I notice the light on the transformer (cord) was sometimes green then it would go out. When I unplugged and then put some force into reconnecting the printer worked. Hope that helps.
Posted on Oct 06, 2008
SOURCE: printing error print system exception error
I had this problem with the LabelWriter 450 Turbo and it was a .Net Framework problem.
1. Uninstall the Dymo Label software
2. Click this link to download .Net Framework 4.0 http://www.microsoft.com/downloads/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
3. Reinstall latest version of your Dymo Label software (w/o printer connected to PC)
4. Reconnect label printer when prompted by installer
This should fix the problem
Posted on Jun 09, 2010
My dymo 450 turbo prints only 1 label even i order to print 10 labels. I use mac(10.11.5) and dymo label(8.5.3). updated last version.
Double check that your using correct printer driver.
Completely remove restart computer with printer discontente,then reinstall the printer.
Jun 29, 2016 | Dymo LabelWriter 400 Turbo Thermal Printer
I have a dymo 450 and it keeps printing 2 labels each time. Is there a setting off?
Make sure you use genuine DYMO labels, not compatible ones. Also, make sure you select the right size in DYMO Label.
You may have to disable bidirectional support: right-click the printer > Printer Properties > Ports > uncheck the option. ^CM
Sep 26, 2013 | Dymo ® LabelWriter® 450 Series PC...
Dymo LabelWriter 450 Twin Turbo - Until recently worked fine from both sides. Suddenly, no longer printing from left - prints half a label, then stops, then error message says Out of Paper, the blue light...
See if it still happens using a fresh label roll. From the Dymo 450 User Guide the common causes of poor print quality issues.
Poor print quality is most frequently caused by one of the following:
• An old roll of labels
• Labels made by a manufacturer other than DYMO
• Labels where the thermal coating has been compromised
• A dirty print head
First, make sure you are using DYMO-branded labels. Do not use third-party labels because the thermal coating on other labels has a different sensitivity than DYMO-branded labels. Also, the perforated holes between the labels made by other manufacturers are frequently not detectable by LabelWriter printers.
If the print quality becomes faint, small dots of white appear scattered through the printed characters, or light and dark patches of printing appear, you are probably using a faulty roll of labels. Try using a different roll from a fresh box. If the second roll prints correctly, the problem is with the first roll of labels.
Another possibility is that the LabelWriter print head needs cleaning. Every LabelWriter printer comes with a cleaning card. See "Caring for Your Printer" on page 17 for information about the
LabelWriter cleaning card.
Sep 13, 2013 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo 450 prints too many lables
^CM
Nov 23, 2011 | Dymo ® LabelWriter® 450 Series PC...
We have recently printed and applied hundreds of asset sticker labels on our Dymo LabelWriter 450 and they have all faded! Is there a solution to this? or is the Dymo LabelWriter only useful for temporary...
LabelWriter labels are sensitive to sunlight. The coating is what allows to burn text onto them because LabelWriters do not use ink.
They are not supposed to fade easily so it may have been an old roll. Please contact our help desk for a resolution (see dymo.com for contacts).
^CM
Feb 10, 2011 | Dymo ® LabelWriter® 450 Series PC...
With Dymo Labelwriter 450, Can labels be printed in WORD without going through Dymo V8 software? I can print in Word but labels come out in portrait format and not landscape
They can. You may want to use the Word add-in for this. Please contact our help desk for further information (see dymo.com for contacts).
^CM
Jan 21, 2011 | Dymo ® LabelWriter® 450 Series PC...
Printing error print system exception error
Dec 24, 2009 | Dymo LabelWriter Thermal Printer
Dymo Labelwriter 450 Turbo errors
450 label is stuck in machine. How can I fix this problem?
Dec 11, 2009 | Dymo LabelWriter Thermal Printer
27 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
