Question about Christie RoadRunner L6 Multimedia Projector
When I press the button to turn on the L6 the lamp(s) come on for a moment then go off. The unit then returns to ready after a few seconds. I have the same problem on another L6 and when the lamp(s) come on then go off the green ready light blinks. Any help would be greatly appreciated.
  • 2,237 Answers
May be a ballast/power supply issue. it take a lot of juice to strike the lamp, and it may be draining what little power it has.
Posted on Jan 06, 2010
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    How to reset lamp timer on panosonic PT56DLX75
    NOTE: If the "Please Replace Lamp" message is displayed, press [RETURN] or [EXIT] on the remote to remove the message. 1. Turn the unit ON. 2. While pressing the [VOL-] button on the unit, hold down the [SPLIT] button on the remote at the same time for more than 5 seconds. 3. When the reset procedure is completed, the following message is displayed on the screen: "LAMP TIME WAS RESET TO 0".
    Mar 11, 2014 | Panasonic PT-52LCX65 44" HDTV
    Is not working more
    Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
    How do I reset the lamp time?
    The following is directly from the service manual for the PT50LC14
    Lamp Time Reset Procedure: Be sure to reset the Lamp time to "0" after replacing the new Lamp.
    1. Plug in the AC Cord, and turn on the power by pressing the POWER button.
    2. Press and hold the VOLUME DOWN button on the unit and the SPLIT key on the remote together for over 5 seconds in power on condition.
    When the reset is finished, the display appears and the LAMP LED goes out
    Jun 27, 2010 | Panasonic PT-50LC14 50" Rear Projection...
    Turn on the roadrunner L6 the preparation display
    This is an indication that either the lamp is bad or the ballast is bad. I would try a new lamp first. Also, there are air flow sensors in the lamp area that should be cleaned. If you have access to compresed nitrogen, try blowing out the entire unit to remove all dust and debris. Check to be sure that the fans are turning freely as well.
    Please keep us posted.
    Dan
    Mar 03, 2010 | Christie RoadRunner L6 Multimedia...
    Starts to power on,then shuts down
    Have you checked the filters? I have a Sanyo PLV-75 and had a similar problem.  The normal fan would come on when the unit was first started, then after a few seconds the secondary fan came on and then the unit would shut down.  Called tech support and they asked if I had cleaned the filters. I did it, and it worked great.  Check the manual for where the filters are and hit them first before getting a new bulb.  Hope it helps!
    May 24, 2009 | Sanyo PLC XF10NZ Multimedia Projector
    Sanyo PLC-XU33 image displayed for 10 seconds then turns off
    Owner decided to upgrade to a newer projector. Lamp was too expensive.
    May 07, 2009 | Sanyo PLC XU33 Multimedia Projector
    Indicator lights on, no function, no fan, no lamp
    Press the MENU button to display the "MAIN MENU", and then select "OPTION".
    Press the ENTER button to display the "OPTION" menu, and then select "LAMP RUNTIME".
    Press and hold the ENTER button for approximately 3 seconds.
    The "LAMP RUNTIME" will change to "TIME RESET [POWER OFF]".
    Turn off the power and disconnect the power cord.
    This will reset the cumulative usage time for the lamp unit to "0".
    Oct 11, 2008 | Panasonic PT-LB20U Multimedia Projector
    How to reset Time clock on NEC MT830+ Projector
    change the lamp even if the old lamp
    use original nec remote contro
    l6. After you install a new lamp, select the lamp Usage icon and press and hold
    the "Power On" button on the remote control for ten seconds to reset the
    lamp time clock to zero.
    NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
    press the "Power Off" (not "Power On") button on the remote control for ten
    seconds
    Sep 20, 2008 | NEC MultiSync MT830 Multimedia Projector
    HLN4365W
    Lamp.
    POWER button.
    When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
    Mar 14, 2008 | Samsung HLN4365W 43" Rear Projection...
    Christie RoadRunner L6 Multimedia Projector Logo
    134 people viewed this question
    Top Christie Office Equipment & Supplies Experts
    jasbo
    jasbo
    Lawrence Oravetz
    Are you a Christie Office Equipment and Supply Expert? Answer questions, earn points and help others
