Question about Garden
Tree with a 3 leaf with two pointed ones and one blunt straight across in the middle
Leaf curl on my Meyer lemon
Generally Meyer Lemon Trees need water every one to two weeks. ... If the leaves are drooping like they're too heavy for the branches, and turning dark brown or black the tree is getting too much water. If the leaves are crispy and dry or curl upwards this is a sign of under watering.
Meyer Lemon Trees: 7 Secrets for Loads of Fruit ' Fast-growing-Trees ...
Citrus Leaves Are Curling - What Causes Citrus Leaf Curl
Dec 29, 2015 - As far as fruit trees go, citrus tend to be the low-fuss member of the team; but when curling citrus leaves appear, you'll need to intervene. This article will help that. Click here for more info. ‎Citrus Fruit Brown Rot · ‎What Is Horticultural Soap · ‎What Are Psyllids: Tips On ...
Leaf Curl - Four Winds Citrus Problem Solver - Four Winds Growers If the leaves on your dwarf citrus are curling, there are three common possibilities: Some insect pests will cause some leaf curl. In spring, aphids might do this on soft new leaves. ... Overwatering can cause leaves to curl or cup INWARD.
Why Are the Leaves on My Meyer Lemon Tree Curling? ' Hunker > ... > Garden & Lawn > Pests, Weeds & Problems May 6, 2010 - Pests. A number of insects can cause leaf curl in Meyer lemons. The most common and likely is the everyday whitefly, but aphids, citrus leaf miners, and mites are also common culprits. Insects are a larger challenge to manage than over-watering.
Meyer lemon Leaf curl Google Search
Jan 29, 2018 | Garden
What caused fruit trees to have leaf curl
Hello May, please read these, they are a wealth of the info you need.. please mark as helpful...thanks
Fruit Tree Curly Leaf Treatment
Citrus Leaves Are Curling What Causes Citrus Leaf Curl
Leaf curl Wikipedia
Aug 01, 2017 | Garden
What causes leaf curl in lemon trees
The leaf-curl maggot. Spray the tree with Roundup (glyphosate)
Oct 14, 2014 | Garden
Leaf yellowing
You should move trees & shrubs in Oct or Nov
when they are about to go to sleep
Then in the spring do not fertilize that first year, at least
What NO ONE DOES is water them EVERY OTHER DAY
Yes- up until christmas & in the spring
They look good,it rains & their left to dry out at the roots
Aug 13, 2014 | Cars & Trucks
Why is my plum tree leaves are turning silver, how do I treat this?
I can only direct you the results of my search for 'PLUM TREE LEAVES SILVER' on the internet (AltaVista/Yahoo). Some pointed to for example
These only the first three results of my search, I hope they are of some use. This seems to be a well known condition. Other similar searches using different search engines will throw up different results in a different order. I suggest you take a look at someof them, because personally I don't know the answer to your question
Jun 08, 2014 | Garden
A land developer wants to find the distance across a small lake in the middle of his proposed development. The bearing from A to B is N14^0W . The developer leaves point A and travels 53 yards...
You'll probably have finished your homework by now if you worked on it instead of typing it in to FixYa. Besides, how much do you trust me?
Sep 25, 2013 | Optics
No power after a p10 component what can be the problem
What is a P10 component?
MLCC that is SMD/SMT?
(Surface Mount Device/Surface Mount Technology)
SMD Fuse?
I think it's a P.MOSFET,
Bare with me;
The above shows a Bottom view of the motherboard.
IF, this Acer Aspire 3000 motherboard is like yours;
(And even if it isn' on.....)
Set your mouse cursor in the middle of the photo.
Now use the Zoom In feature by moving the mouse from the middle, to where you want to go.
I'm sure you know the following, but others who may read this later, may not.
The white Socket S1 processor socket is at the Top/Middle.
Looks like this,
Come down from it to the whitish rectangular Heatsink.
Go across to the Right from it, to the SiS 302ELV Video Bridge chipset.
Turn left at the old Oak tree, and head south.
NO.....just wanted to see if you were following!
Go the Right side of the SiS chipset. Go to the Middle.
(Middle/Right side)
Go straight across to the large Power MOSFET.
Looks to have P015 silkscreened on the motherboard, under it.
(Can't make out last digit)
It is sitting Vertically. Length goes up, and down.
Now come straight down a little bit.
Stop at the Power MOSFET that is the same size. This one sits Horizontally on the motherboard.
Looks to have P010 silkscreened under it.
That isn't me, but that is the guy you need to talk to.
Mar 16, 2013 | Acer Aspire 3000 Notebook
Cheat in battle realms in lan games
Lotus Clan instant Yin point trick
Quickly build a Tomb of the Brothers and summon Lythis, one of the brothers of the crypt. Just have him attack a tree and watch yin points add up. This trick works well on a stage with lots of trees. (Note: This was fixed in later patches)
Unlimited Necromancer Spirit Warriors
1: Get a Necromancer(Serpent Clan)
2: Summon 3 of them
3: Save game, exit, start Battle Realms again, load the file and Summon another 3 of them
Instantly destroy enemy buildings
1st: Select an enemy building
2nd: Press ctrl+d simultaneously
3rd: Watch the building turn instantly into dust! This was fixed in the Battle Pack 2 (1.10j) version of the game.
New Lotus Clan Instant Tin Point Trick
You must create a Crypt of the Brothers to perform this trick. Then create either of the two brothers, Lynthis or Tausil. Select it and press f and attack the water and watch your yin rise without hurting mother nature.
Serpent Clan instant Yin point trick
Quickly train a unit into a Ronin and have him learn the Yin Blade battle gear. Take him near a tree and turn his Yin Blade on and force attack a tree. Watch your yin points rack up. This trick is good in a stage with lots of Trees.
Unlimited Brothers
For the Lotus Clan:
1. As soon as possible build the Crypt of Brothers.
2. Train all 3 Brothers (you can use the Yin Farming to make it easier).
3. Build 3 Watchtowers.
4. Put the 3 Brothers on the 3 Watchtowers.
5. Destroy your Crypt of Brothers (CTRL+D x2).
6. Rebuild your Crypt of Brothers.
7. Build the 3 Brothers again.
8. Remove the old 3 Brothers from the Watchtowers.
9. Put the new Brothers on the towers.
10. Repeat.
* Notice * The brothers only use Yin, Rice, and Water. If you destroy your Crypt of Brothers while the 3 Brothers are on foot, they will die with it. That is why if they are one the towers, they dont die. This also makes the computer think they are dead so it allows you to train new ones.
Jun 27, 2011 | Computers & Internet
Sound only w/1 straight red line accross the middle of the screen
try to replace the vertical ic and resolder the vertical section.
Sep 16, 2009 | Hitachi 36UX01S 36" TV
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
