Question about Garden
I took the carb apart yesterday checked solenoid and blew it all out with air compressor. It still will not start. What would you suggest to do next?
  • 202 Answers
SOURCE: lawnmower starts but won't continue to run
if you are getting no fuel to the plug you either have a stuck float, plugged fuel line or filter. does the gas reach the carb bowl? does the mower have a fuel pump? if so the diaphram might be bad.
Posted on Jul 08, 2009
  • 148 Answers
SOURCE: GAS LEAF BLOWER WILL NOT START GETTING FIRE
Maybe your carb is out of adjustment. The easiest way to readjust is to turn the screws all the way in and start the blower. While it's running start to back the screws out until it runs nice and smooth and you should be all set.
Posted on Jul 24, 2009
SOURCE: Same problem -- won't start
Are you getting gas from the tank to the carb?
Maybe pluged fuel line...
Also pull bowl off carb and pull out main jet if it has one and make sure that you can feel the compressed air coming thru the main jet, plus also check idle cirurt the same way...
Posted on Sep 12, 2009
  • 653 Answers
SOURCE: howdy, my 2000 rm250 has been sitting for about 8
Does it have fuel filter that you can replace?
Posted on Mar 28, 2010
woobie dog
  • 1273 Answers
SOURCE: Yard Machines 22" push mower
Hello, W/D here.
2 suggestions: 1. Check the fuel cap for pluggage, paying particular attention to the pinhole vent in the cap, and 2. Clean the air filter. A plugged (or nearly plugged) filter can also cause these symptoms.
Best regards, --W/D--
Posted on Feb 14, 2011
I am completely stumped....Pressure Washer will not start I feel like I have tried everything. Please help
buy a new carburator on ebay for 20.00,the diaghram and all the rubber hoses are shot,that is what ethanol does,eiher try a rebuild kit or wait 2 days for a new one
May 07, 2015 | Cars & Trucks
Starts up fgor few minutes then shuts off
Clean or replace air filter. Ensure oil is full. 30w. Remove bowl from bottom of carb & clean. Clean carb.
Sep 07, 2013 | Cub Cadet Garden
I've got a little southland tiller and the thing
Remove the air cleaner and spray carb cleaner into the throat of the carb then try to start. If it starts right up for a second then its a fuel problem and the carb will need to be rebuilt, also check the fuel lines and filter. If it wont run for a second on the prime then you have an ignition or compression problem.
Sep 24, 2012 | Garden
Toro 20056 no start
check for movement of the solenoid on the bottom of the carb and also check for power
May 21, 2012 | Garden
I have a Poulan 550 158cc Push Mower. Two Model #'s 96132004200 and PR0550N21RH3. Two Serial #'s 0901075421770 and 011309M001762. The mower will run if primed then dies. The carb. is on the tank. I...
does it have fresh gas in it, If so time to rebuild the carb, even though you blew through all holes there is a diaphram inside the carb that pumps gas to it, so I suggest you take the carb apart and clean inside out and replace the diaphram, the way you describe it only runs on primer, tells me the carb is not getting fuel. Good Luck
May 14, 2011 | Poulan Pro PR550N21R 21Inch Briggs ...
4.5 HP Briggs engine, runs ok for about 10 minutes then starts sputtering and then dies. I drained fuel tank, installed fuel filter and took carb off and blew out with air compressor. Worked fine for...
where did you get the "new" fuel from?
You may have a sticking float -- I did not read where you said you "CLEANED" the carb, but only "blew it out..." you might need to get back in there and give it a cleaning to remove any varnish build up from the fuel...
Best regards
Ck
Feb 14, 2011 | Mtd 22" Yard Machine Push Mower
CRAFTSMAN 42" kolher 15.5 hp. will start but have to leave the choke on or set it to idle.when running it surges. disconnect fuel line and crank it over and seams to be getting enough gas. but look at fuel...
Check the electric fuel solenoid make sure there is voltage to it when engine is running.This model may have 3 relays on the engine harness and one of them is tied into the fuel valve try switch relays.Also check connectors on ignition switch sometimes one terminal can get corroded and cause problems.Also check the plunger on it to be sure it is moving freely.Also the fuel filter is usually half full,there is almost always some air in it.
Aug 01, 2009 | Craftsman Garden
Lawnmower starts but won't continue to run
Jun 30, 2009 | Garden
Apr 30, 2009 | Garden
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
