Why UPS automatically turns off when powercut? How to fix it?
  • Computers & ... Master
  • 7,842 Answers
Probably needs a new battery
Posted on Apr 18, 2017
Cant get oven to Work after powercut, display says "stop". Can any one help?
You need to reset it by the looks of it. Try pushing and holding in any programme buttons / knobs for 5 sec or so to re set the thing. Even turning off the main power switch at the wall for sev min if it has one. another posibility is that the powercut has produced a surge or spike that has damaged the onboard "computer" -hopefully not.
Oct 03, 2013 | Ovens
The battrey leds stay flashing i changed battries also the led still flashing
Automatic: The UPS performs a self-test automatically when turned on, and every
two weeks thereafter (by default). During the self-test, the UPS briefly operates the
connected equipment on battery.
Manual: Press and hold the button for a few seconds to initiate the self-test
REPLACE BATTERY LED ILLUMINATES
Replace Battery LED flashes and
short beep is emitted every two
seconds to indicate the battery is
disconnected.
Check that the battery connectors are fully engaged.
Weak battery. Allow the battery to recharge for 24 hours. Then, perform a self-test. If the
problem persists after recharging, replace the battery.
Failure of a battery self-test. The UPS emits short beeps for one minute and the Replace Battery LED
illuminates. The UPS repeats the alarm every five hours. Perform the self-test
procedure after the battery has charged for 24 hours to confirm the Replace
Battery condition. The alarm stops and the LED clears if the battery passes the
self-test.
Sep 09, 2011 | APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS...
Sir, My PC is starting problem, 1.Starting UPS - ON the system starts automatically without swith ON. 2.After Starting the keyboard & Mouse get stuck 3.after Restart the the keyboard & Mouse...
The UPS may not be sufficiently stable on power-on to run a PC immediately.
Try going into the BIOS setup after the restart and look for the option that has the computer "Start up automatically after power failure." Turn this off. That will take care of problem 1.
If this also takes care of problem 2, you may want to check whether the UPS has a problem. Start by plugging a couple of lamps with 100 Watt bulbs into the UPS outlets instead of the computer. Turn it on - the lamps should behave normally, not flicker or change brightness. With the lamps and UPS still on, unplug the UPS. The lamps should stay on with little or no change, and the battery warning light should not come on right away. If the UPS fails this test, its battery may need to be replaced or it has a regulator problem.
Apr 08, 2011 | Intel DG965RY Motherboard
I have HCL Beanstalk Desktop, Monitor - Samsung Syncmaster 794MG. I don't have a ups. I get frequent powercuts in here resulting in interrupted shutdown of the computer. Sometimes while playing a game...
You seem to have a corrupt display card. Is it on board or do you have a separate graphics card installed in your PC. Either way on restart graphics processor is not turning on. What does the Power and HDD indicator on the PC show during boot up. You could also have damaged the Hard Disk because of your abrupt shutdowns. You can open the side cover and try disconnecting the HDD power (Yellow, Black & Red ) cable and IDE ( 40 pin flat ribbon wire ) cable and try restarting. If your monitor starts up and shows BIOS page you have a faulty HDD. Also see if the processor fan is a working when you start the PC. If not you have a failed mother board. Are you getting the boot up RAM beep. If not before you do any of the above mentioned things Just pull out the RAM ( with PC unplugged ) and reinsert into the slot. It might get your PC working after all
Mar 08, 2011 | MSI Computers & Internet
Hi,do I have to keep my ups plugged to a wall socke all the time?
hi,
the unit needs to be plugged in all the time. the unit is or should be fully automatic. higher priced units have a usb cord so you can check their status right on the computer, does your ups have a usb outlet? you might want to take it up to a computer store and buy a usb cable and then you can control your UPS with your computer. manually turning the UPS on and off shouldnt hurt anything.
good luck
jm
Aug 01, 2010 | APC (BE500U-WEB) (BE500UWEB) UPS System
Miata engine turns over but won't start after short drive
installed my camara to ups . inform the procedure of taking photo fixed
Apr 02, 2010 | 2000 Mazda MX-5 Miata
I had a powercut, when power returned, computer would not boot
what you have to is to unlplug the cord then cut the computer on
Feb 14, 2010 | HP Computers & Internet
Belkin F6C800UNVPL UPS does not auto start
u have problem with ur automatic utility....
contact ur dealer or go to any ups shop.....
they will fix it in a very cheap cost man....dont forget to tell me u r problem solved or not
best regards & best of luck
Oct 03, 2007 | Belkin (F6C800-UNV-PL) UPS System
Computers & Internet Logo
David Payne
David Payne
