Question about Troy Garden
Troy built zero turn mower will only run in circles
  • 1388 Answers
SOURCE: replace pullcord on troy built mower
Replacing the rope is not difficult but tricky. I believe that your model has a fuel tank on top of starter cover, empty fuel and remove tank to expose starter cover. Remove the starter cover and place it on your workbench with the plastic rewind spool visible and remove the old rope noting how it was tied. The rope is sold in various sizes from # 3 to # 6.5. Most mowers use a #4.5, with length of about 6 to 7 feet. You may not need this much but more is better. Now practice inserting the rope thru the hole where it comes out of the cover into the hole where it ties on the spool. Once you can do this you are ready to wind. The spool /spring winds when you pull the rope, that why it recoils when you let go of the rope. With that in mind, turn (wind) the spool in the same direction that it turns when you pull the rope. It should be getting tighter as you turn. Keep winding in the direction that it turns when you pull the rope untill it will not go anymore. It should be very tight. Now unwind one complete turn and align the hole of the spool to the hole in the housing and hold it there while you insert the rope from outside hole into the spool and tie knot. After the knot is tied slowly let rope rewind into the spool untill it stops on its own. You are done. You should have plenty of extra rope left to extend out to the handlebar. Enjoy
Posted on Jan 11, 2009
SOURCE: Troy Built 6.75 Self Propelled to Slow
You have to take off a part behind the gears and move it to a slot farther away. Mine was the same way. It's in the manual on how to adjust the speed to go faster.
Posted on May 30, 2009
  • 636 Answers
SOURCE: MANUAL FOR A TROY BUILT RIDING LAWN MOWER
Try this site it is called manuals online . Should find what your looking for , Free.
Posted on Jul 24, 2009
  • 279 Answers
SOURCE: Troy-Bilt Mower is running real slow.
If you can, check the flywheel key. If it is bent but not quite broken, it can cause slow operation. To do that, take the starter off the top of mower. Take off the big nut on the flywheel. Find a nut of the same size and place on the thread you took the nut off, but only a few turns. Hold the flywheel with one hand, lifting a little, and tap the nut with a hammer with the other hand. The flywheel should come off. Look at the key, it holds the flywheel to the shaft. If it is bent or broken, that is the problem. Replace it and go about your day! Good luck...Lee
Posted on Sep 25, 2009
  • 2926 Answers
SOURCE: my troy built lawn mower dies after it starts runs
Your high speed needle jet is most likely the cause. Remove the jet and clean it out. Keep in mind that there may be least one or two very small holes drilled in to the sides of the high spped jet, if so, be sure they are cleaned and not clooged.
Posted on Jan 17, 2010
Testimonial: "worked perfect tks"
Zero turn mower shuts doun when trying to go when engaging control arms
On my RZT50 Troy Built I have to engage the parking brake to start it and release it before I move the arms in over my lap or it shuts down.
Dec 10, 2016 | Garden
How do I replace the drive belt on a 2008 50" troy bilt zero turn mower
You didn't include a model number so here is a link to Troy Bilt where you can download the user manual.
At top right click on owner center and follow directions.
Mustang 50 XP Zero Turn Riding Lawn Mower
Sep 11, 2014 | Garden
Troy Bilt Mustang XP mower belt diagram
https://www.partstree.com/parts/troy-bilt/mowers-zero-turn-lawn-mower/17wfcacp011-troy-bilt-50-mustang-xp-zero-turn-mower-2013/mower-deck/
Aug 27, 2014 | Troy Garden
Troy bilt troubleshooting
what are you trying to troubleshoot? heres the troybilt link to get you started
http://www.troybilt.com/equipment/troybilt/lawn-mowers/lawn-mowers?facet=cas_f9_ntk_cs%253A%2522Zero%2bTurn%2bTractor%2522&sortBy=3?cm_mmc=Google-_-Mowers-_-Zero%20Turn-_-Sponsored&gclid=CjwKEAjwi6OeBRCCrZqp-qaQhhISJACrfbtAq_Hepy9R8IgJYw_E9HkmY0pum-PDxyoqjOrFfOWq-hoCAknw_wcB
Jul 17, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Troy bilt zero turn mower runs but does not move
Make sure the gears are engaged. There are 2 metal hooks on the rear of the mower, 1 on each side, if they are pulled out the mower is out of gear, make sure to slide them over so they retract back into the mower. If not the problem, sounds like either broken drive belts or the transmission isn't working properly.
Jul 02, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Mower: Troy Bilt 42 Mustang Zero-turn mower: The
Hello Donna,
I would remove the battery and have it tested at a local parts store. It sounds like the battery to me.
Sep 08, 2013 | Mustang Rzt 50" Zero Turn Riding Lawn...
Mower runs but blades aren't turning
You can get help at both of these places:
http://troybilt.custhelp.com/cgi-bin/troybilt.cfg/php/enduser/std_alp.php
http://www.mowersdirect.com/technical-support.php
Aug 03, 2009 | Troy Garden
Troy built lawn tractor won't start.changed plugs.
i have a troy bilt riding mower,i start the mower it only runs for 15 to 25 min's ,so i changed the coil to see if it would run long. but after a few minunts it stop again so i don't know if maybe it's my carb. what could it be.... help
Jul 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt zero turn
Hi please check all the wiring connections as you must have disconected the power soarce feeding the key switch to the starter.
Start around the engine then the battery, check the seat switch , brake/ clutch pedal , & the mower deck switches .
One wire is just disconnected or the connection is broken so check all connections by unconecting & reconnecting them as it may even be a corroded wire that has been disturbed when being cleaned.
Oct 26, 2008 | Troy Garden
Garden Logo
26 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
