Question about Vigoro Garden
What do I set my vigoro 4300 drop spreader at for Vigoro weed and feed
SOURCE: vigoro water timer 196 036 water timer programming
every x days vs every x hrs. (once a day or every 12 hours)
Posted on Jun 29, 2009
SOURCE: I have lost the directions to my vigoro 196 036 water timer
When the bar is on the program is set. You can also tell by pressing any button to change the time etc. When the program is on it will not change.
Posted on Jul 06, 2009
  • 31 Answers
SOURCE: I have an EZ Spreader by Republic pull behind for
Go to this web page to get all settings......
Once there I would save the file and print it out for future use....
http://www.scotts.ca/media/media/pdf/spreader_settings.pdf
Posted on Sep 19, 2009
SOURCE: I have a Scotts Accugreen 3000 Drop Spreader. How
I found drop-rate tables at http://www.vigoro.com/ProductCategories/WeedInsectControl/SummerFertilizer/ProductDetails/Spreader+Settings.htm and http://www.bayeradvanced.com/media/productlabel/502840A_label.pdf. I don't know how accurate they are, but they are consistent with one another so I'm using them :)
Posted on Mar 21, 2010
  • 25 Answers
SOURCE: IS there a place that lists spreader settings for
If the product you are planning on applying has a spreader setting for a Scotts AccuGreen, or  specifically for the AccuGreen 3000; you can use that recommendation in your Turf Builder Classic Drop Spreader.  If they do not have a suggested spreader setting for the Accugreen, or  Accugreen 3000 settings then this question would best be answered by calling Scotts directly @ 1-800-543-8873. One of our associates would be happy to assist you further.
Posted on Feb 23, 2011
I have a scots edge guard spreader and need to put on weed and feed at 4 lbs per 1000 sq feet what setting on spreader should I use
Hi Mike:
The setting will depend on the size of the weed & Feed pellets.
The package usually has setting instructions on it.
If all else fails, the rate is 1 lb per 250 square feet.
Mark out an area about 10 ft by 25 ft long.
The spreader cast is about 5 ft, so down and back should use 1 lb.
Set the spreader at a minimal rate and see how far 1 lb goes, then adjust the setting accordingly.
May 22, 2015 | Scotts Garden
Need to known how to set the timer do not have a manual we have the VIGORO deluxe water timer, they are about two years old.
I do not know how to set the timer, but can offer possible source for manual.
VIGORO timers can be same as Melnor:
Match up image with your timer and then download manual.
Water timers last 1 or 2 seasons. There is no repair for broken water timers.
http://www.melnor.com/instructions.php
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 12, 2011 | Hardware & Accessories
How do I get free instruction for Water Timer Vigoro Duo- Deluxe Water timer # on front top lefte is 225-379 # on back is 0708
The vigoro duo delux might be same as Melnor 3100
Open following links:
http://www.melnor.com/instructions/3100_InstructionSheet.pdf
Take a moment and rate answer:
Sep 02, 2011 | Hardware & Accessories
I need instructions to the Vigoro- Duo Deluxe water timer 9 volt battery operated # on back is 0708..# on fromt top left is 225-379 Purchased at Home Depot I has5 to 6 cycles that can be programmed. I...
What is the best setting for weed & feed for the first time? I just bought the equipment I bought a sack of weed killer & feed. I don't have any ideas as to what level of setting I put the...
The recommended settings for your type of spreader should be listed on the package of the bag of weed and feed you have. There should be a rate chart on the bag. If not, put the setting on your unit on the middle setting, that way, you are not using too little and not using too much.
Apr 09, 2011 | Scotts Company SCOTTS SEED EDGEGUARD MINI...
I have 2 Vigoro 196-036 watering timers. Why does water come out of the three holes near the battery compartment on one of them?
It comes out of the holes because the water goes in the holes. That might sound dumb but Vigoro designed these only to be in dry conditions, such as attached to the water line. I used them for sprinklers, but the water poured into the timer so bad it shorted it out in a week. I did find a vigoro timer with no holes and a sealed unit, and they work great. But I can't find them anymore.
Aug 25, 2010 | Hardware & Accessories
As the cyclone brand spreader is "gone" from use, what are the equivalent settings to currently match spreading rates as listed on fertilizer bags for spreaders currently in use.
CYCLONE ROTARY
2.0
EARTHWAY ROTARY
6.0
EV-N-SPREAD
6.0
K-GRO ROTARY
.75
ORTHO ROTARY
.75
PRECISION ROTARY SB50
1.50
RED DEVIL ROTARY
1.50
REPUBLIC EZ ROATRY
.75
SCOTTS SPEEDYGREEN 1000,2000,3000
2.12
SCOTTS BASIC BROADCAST
2.12
SCOTTS EDGEGUARD BROADCAST
2.12
SEARS ROTARY
.75
TRUE TEMPER ROTARY
1.5
VIGORO ROTARY
1.50
SCOTTS STANDARD ROTARY
2.12
CRAFTSMAN
6.0
SCOTT’S EASY GREEN
25
SCOTT’S HANDYGREEN
__________________________________________
Drop Spreaders:
K-GRO DROP
2.25
ORTHO DROP
2.25
REPUBLIC EZ DROP
2.25
SCOTTS ACCUGREEN 1000
3.0
SCOTTS ACCUGREEN 2000
3.0
SCOTTS ACCUGREEN 3000
3.0
SCOTTS DROP PF1, PF2, PF3, PF4
3.0
SEARS DROP 2.25
Apr 29, 2010 | Scotts Company Scott'S& Lawn Pro Spreader...
Conversion Tables---- I have an Earthway broadcast spreader--need to know if there is a chart that converts Scott's settings located on the back of all Scott's fertilizer bags to Earth way settings?
Mar 16, 2010 | Earthway Ev - N - Spred Model 2050p Estate...
Feb 15, 2010 | Scotts Company Scotts& Accugreeen 3000...
Garden Logo
57 people viewed this question
Top Vigoro Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Vigoro Garden Expert? Answer questions, earn points and help others
