Question about Singer Sewing Machines
How to remove bobbin case from 638 singer zig-zag machine. replaced top gear, put case in and now need to adjust timing, can not get bobbin case out?
bargainbox
  • 1388 Answers
SOURCE: singer sewing machine will not zig zag
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Denatured alcohol is fine, surgical spirit too, different countries have different names or products, essentially alcohol with few impurities that will evaporate quickly with little residue.
Hope this does work for you, tho' as I said, it may take a little time to penetrate depending on severity........the same applies to the reverse mechanism of many machines when they seize.
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
SOURCE: How to set timming on Singer Touch & Sew 638 Sewing Machine
I have a timing problem with my Touch&Sew Singer model 638.
Jean
rlacasse@ntl.sympatico.ca
Posted on Sep 17, 2008
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
Zenqi
  • 208 Answers
SOURCE: I have a Singer Special Zig Zag Model 418. I can
More than likely you have a broken vertical shaft gear.
When you turn the handwheel you should see the sewing hook moving under the bobbin case.
If not, take it to a sewing repair person and it should cost somewhere around $100 to repair.
Posted on Aug 21, 2009
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_477_threading_diagram.htm
Posted on Jan 23, 2010
The zig zag stitch is on the bottom of the fabric instead of the top how do I fix this for a Singer sewing machine model 7015
singer has a manual that should show how to adjust the zig zag ,, but the manual is not free,, but it costs the less
Instruction Manuals
you may have to put your model number to get it
Dec 14, 2014 | Singer Sewing Machines
The top of my zig zag stitch looks great but the underneath does not look the same
the sewing machine may need to be taken in to a sewing machine
shop for a adjustment, just in case there is something wrong with
the gear or cam of the zig zag,,
but first try changing the needle
and checking the thread tension
make sure the bobbin is wound correctly and also turned the right
way in the bobbin case
make sure the bobbin is not warped
Mar 24, 2013 | Sewing Machines
Singer 403a-When using zig-zag cam the thread will back lash behind the bobbin case. The stitching is locked. when I cut thread and remove the fabric, I take the cover off the bobbin area and there is a...
Somewhere in the bobbin area you more than likely have thread, dust or lint you can't see. Oiling it is not going to help. Trying using a flashlight with a magnifying glass. Take the bottom off the machine and look from the bottom and up into the bobbin area, especially the hook.
Jul 05, 2017 | Singer Sewing Machines
Aug 20, 2009 | Sewing Machines
Aug 16, 2009 | Singer Quantum XL-5000 Computerized Sewing...
How do i set thread tension on a 306W Singer Zig-zag? Bottom thread all loopy.
Top tension about 4 or 5, make sure the presser foot is up when you theread the machine, make sure you can just pull the bobbin thread through with some slight resistence, if it is too tight slacken the screw on the bobbin case a quarter of a turn at a time anti clockwise.
May 05, 2009 | Singer 8280 Mechanical Sewing Machine
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
