X^2+y^2=9 y=2-x solve simultaneously
How do you solve this simultaneous equation? 78-y+y=1
Search how to solve 78-y+y=1 on google. Or check youtube for the visual answer.
thanks for using FixYa
Feb 19, 2017 | Office Equipment & Supplies
How to solve simultaneous equations?
This calculator does not have a utility that solves equations of any type.
Nov 05, 2012 | Casio FX82MS Scientific Calculator
Multiple equation solver
There are a few routines to solve simultaneous LINEAR equations that are embedded in the Operating system of the calculator.
  1. solve(
  2. Simult(
However if you are looking for the simultaneous equation solver application, you can download it from the TI website. Here is the link
If you need download and install instructions, you will find them here.
Aug 01, 2010 | Texas Instruments TI-89 Calculator
Solving simultaneous equation with scientific
Let us assume you have two simultaneous linear equations :
a_1*x+ b_1*y+c_1=0
a_2*x +b_2*y+c_2=0
where a_1, a_2, b_1, b_2, c_1,c_2 are coefficients (numerical or algebraic).
The problem is to obtain the particular values of the unknowns x and y for which the two equations are both satisfied: If you substitute the particular values of x and y you find in any of the two equations you discover that both equalities are true.
A small system of equations like the one above can be solved by some very simple algorithms (elimination, substitution, combination) which can be carried out by hand.
The solution of large systems of linear equations can be sought by making use of the concepts of matrices (plural of matrix), determinants, and certain rules called Cramer's rules.
Due to its repetitive nature, the algorithm ( a well defined, limited sequence of steps) is suitable for a calculating machine (computer or calculator).
Certain calculators have, embedded in their ROM, a program that solves linear systems of simultaneous equations. Usually you are asked to enter the values of the coefficients a_1, etc. in a set order, then you press ENTER or EXE (Casio) . If a solution exits (not all linear systems have solutions) the calculator displays it.
Hope that satisfies your curiosity.
Aug 12, 2009 | Sharp EL-531VB Calculator
While trying to access mails in lotus domino server using outlook express from more than one computers the following error occurs - "POP3: 11:34:49 [rx] -ERR The system was unable to log in. Maildrop...
Please do not login simultaneously on both the applications.
Apparently, your POP3 server does not allow simultaneous logins to the same email account. Unless you can prevent it, your program should wait a short time and re-try.
Jul 31, 2009 | Computers & Internet
Caps lock and scroll blink simultaneously
Your laptop is still under warranty. I suggest you return it for repair or exchange because if you try to fix it you most likely void your warranty.
Jul 01, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Keyboard problem
In my HP laptop new one keyboard keys A S D F & J K L& enterkey are not responding but G & H in this line are working properly. how can i solve this problem?
May 04, 2008 | HP Compaq nc6220 Notebook
Toshiba e-studio163, its come c44 error codes always... i replaced new thermistores, but the problem not solved.. if this have any reset code pls any one tel me...
turn off wich power press 0 &8 simultaneously
turn power wsich then wait one minut enter 400 then press Start press 0 then press Set press 0&9 simultaneously
or turn off power wisch
Apr 02, 2008 | Toshiba e-Studio163 Copier
26 people viewed this question
k24674
jasbo
jasbo
