Question about John Deere Garden
John deere oil capacities - John Deere Garden
  • John Deere Master
  • 7,515 Answers
If you want to solve your problem, click on the link I attach.
Best Manuals
Posted on Apr 20, 2017
Oil Capacity for a 1958 John Deere 420 row crop gasoline tractor.
If there is a way to check the oil Put in oil a little at a time Start a quart at a time till it's filled to where it's suppose to be.I have done that with old cars then write down the amount you put in..
May 24, 2017 | John Deere Garden
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
What is the oil filter part number for Generator engine serial number CD4045C037188?
your number 4045tf258 should be a industrial generator that number is the model number
John Deere 85 KVA 4045TF258 for sale Price 7 359 Year 2005 Used John Deere... notify john deere and use the model and serial number [i have 2 different numbers and are as follows RE506178 Oil Filter 1 RE5 9754;the first should be the new number and the other was the old ] just to make sure of the correct parts number for your unit
Aug 19, 2016 | John Deere 225 325 375 500 650 Alternator...
What type of fluids oil Etc are used in a 1987 JD 210C?
Kathryn,
Fuel Capacity 23 gal 87 L
Hydraulic System Fluid Capacity 16 gal 60 L
Oil System Fluid Capacity 2.2 gal 8.5 L
Cooling System Fluid Capacity 4.2 gal 16 L
Transmission Fluid Capacity 1.8 gal 7 L
Feb 22, 2016 | Garden
Oil capacity
oil capacity 1979 Ford Thunderbird 5.8 litre
Jan 03, 2014 | John Deere 020297 Gas Pressure Washer
Gas leaking from bottom valve and getting in oil on a John Deere 110 17.5
sounds like the needle valve in the carb is not seating also check the oil gas over flows from the carb into the oil change it a couple times
Apr 24, 2012 | John Deere Garden
Where's the hydraulic oil fill for a John Deere 3020? Is it next the seat? What's the hydraulic system oil capacity? What type hydraulic oill would you suggest?
The oil fill cap is just above the oil dipstick at rear of tractor.
the capacity of the system is 4.5 gallons.
Oct 08, 2010 | John Deere Garden
Changing oil in Biggs and Stratton engine
Use 10W30 weight oil. The capacity is 1.5 Quarts (48 ounces) with filter change. I highly recommend you use 100% synthetic oil in an air cooled engine. Change the oil and filter every 50 hours of use.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
John deer
Hi if you look on the side of the oil pan there should be a square plate with 4 bolts the oil filter is behind it its a paper one Fram C139PL and a new gasket comes with the filter. I hope this helps. M.L
Apr 13, 2009 | John Deere 3010,3020 Tractor Basic...
Garden Logo
35 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
