Question about John Deere Garden
John deere capacities
Jd 1550 backhoe
  • John Deere Master
  • 7,515 Answers
Repair your vehicle right away. Just click on the link I attach.
Best Manuals
Posted on Apr 20, 2017
What year is the following john deere backhoe 310G :t0310gx911769
You just go to the link I attached I'm sure you will get the solution of your problem.
Apr 25, 2017 | John Deere Garden
What's a hydraulic fuse on john deere 1550 backhoe
Here's the link and I'm sure you will get the solution of your problem.
Best Manuals
Apr 18, 2017 | John Deere Garden
Where is the serial number located on a john deere 510d i can find out the year of the backhoe
Diane, JD 510D VIN# Location: On older models plate is attached on outside of frame behind either left or right front wheel. On newer models VIN plate is attached just above left (Highway) side cylinder arm. Same location as Caterpillar. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Thread where is Serial number for 1977 John Deere 510 hoe
Serial number plate location for john deere 510d backhoe Google Search
Jun 20, 2016 | John Deere Garden
I have a john Deere 310sg backhoe that is showing a f-428 service code and also have an issue with the park brakes continuesly setting is this a simple fix. The computer was recently replaced
f-428 means the foot throttle pedal sensor is not calbrated
the software that's in the computer , this makes sense since u replaced the computer recently , to fix this its gonna require the JD tuning tool interface and software 4 it
I suspect the park brakes issue is sort of coming from a similar conflict in sensors on the transaxle or something
gone is the days that a new computer would self adjust its self when 1st installed , in fact if you read your owners book JD requires a yearly software update now
Apr 03, 2015 | John Deere Garden
I need a routing diagram for serpentine belt on a John Deere 310SE backhoe?
You should be able to get that by going to the website for Gates rubber and belts.
Sep 12, 2014 | Cars & Trucks
How to troubleshoot swing motor problems on a 1963 jd row cropper backhoe?
just like any hydraulic system there is A (IN) and a (OUT) on every cylinder and motor on tractor (even steering) loosten (NOT remove) the hose fitting thats on (A or In) to motor and attempt to move joint/device with controls if a steady drip of fluid is present then your problem is device (cylinder,motor) if no drip then follow hose up to power divider or solinoid or hand valve and attempt same procedure , keep moving up the line till you get a steady drip of fluid and last device in liine is the problem device , repair or replace it
ALLWAYS turn off motor and release pressure from hyd system before you attempt to completly remove any device from system for replacement , and note that booms and arms and heavy stuff will relax(fall) with no pressure in system , prepare for this to happen (blocking,chaining)
May 11, 2014 | John Deere 420,1020,2010,2020,2510,2520...
I have a 310SG john Deere backhoe and it loses power in 3rd and 4th gear on a hill I need help please.
I'm having the same problem with my jd 310. Did you ever end up finding a solution?
Dec 19, 2012 | Cars & Trucks
I'm getting hydralic fluid in my engine oil. I was told that it's coming from my power steering unit. It's a JD 400 tractor/backhoe. Would this be correct?
Jun 04, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
26 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
