Question about Olevia LT42HVi 42 in. LCD Television
Remote code for dish remote
Have to use two remotes, cannot find code #'s
Re: remote code for dish remote
According to DISH use CODE 506, but I tried it and it doesn't work! :(
Posted on May 22, 2008
Everyones already been to the dish site, thats where the codes dont exist, dickwheat dont post unhelpful tips
Posted on May 17, 2008
Posted on Jan 31, 2008
Codes do not work
Posted on Dec 14, 2007
I spent an hr with tech support...the blue button remote is incompatible with olevia 42" work around known at this point...2 remotes sux
Posted on Oct 25, 2008
  • 203 Answers
Dish network has the codes listed on their website for their remotes. Go Here on the Dish website. It give directions on setting the code up and has links to the code lists for the different remote types they have.
Posted on Nov 21, 2007
2 Suggested Answers
  • 298 Answers
SOURCE: remote control code
Dish Netork does not have the code for Olevia
but you can scan for the code using the infformation
Remote Code Power Scan
If your brand is not listed, use the following procedure to scan through all codes.
If you start the and do not press a button within 20 seconds, the remote will end the scan automatically.
1. Turn ON the unit you want to program the remote to control.
2. Press the Mode button on the remote until the appropriate mode light is flashes
3. Press the Address button. The mode light will start flashing slowly.
4. Press the Power button. The mode light will stop flashing and stay lit.
5. Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
6. When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
7. Press the Address button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
8. Turn the device back ON by pressing the Power button.
9. Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
10. If the other buttons work, follow the current settings procedure below to determine the current remote settings.
11. If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
12. The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Posted on Nov 23, 2007
  • 356 Answers
SOURCE: remote code for dish network remote to control olevia tvs
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
We cannot guarantee our remotes will work all other devices. If this does not correct the issue, unfortunately our remote will not work for that device. We apologize for any inconvenience this may cause.
Lone99star. Please rate this solution.
Posted on Feb 14, 2009
0 characters
3 Points
Dish Network Remote Codes? Can't seem to get the few I have to work the dish remote
If your remote is a learning remote (has a little black glossy square on the top left side of the remote) you don't need a code, you just need the original remote. Place both remotes on a table, or other flat, sturdy surface, with the original TV remote facing the square on the DISH remote. Make sure both remotes have functioning batteries. On the DISH remote, hold down TV until the button blinks three times, then hold down record (for 5+ seconds) until the TV button lights up and stays on. Then, slowly, for each key you want to use, hit the key on the DISH remote (TV light blinks) then the corresponding key on the original remote (TV light blinks). For example: DISH Volume Up, TV remote Volume Up. When you are done learning all the keys you want to train, hit SAT. The TV light will blink three times, then the SAT light will light up for a moment. Try the DISH remote on your TV functions.
Nov 15, 2013 | Emerson LC320EM8 32 in. LCD TV
Dish network remote control and akai tv
Not likely the Dish remote will have that remote code at all in it--some of those sets were made by Samsung so try those codes also.
Jun 01, 2012 | Akai PDP4294 42 in. EDTV-Ready Plasma...
I have no sharp remote, but was told it can be programmed with the dish remote. how?
The best thing would be to get the original remote and use it. The Dish remote like most remotes will have an average (some more) of about 50 different codes---contact Dish or Google the model number of the remote to if possible get an owner manual which will have instructions and a list of possible codes.
Most of these and all remotes have a search mode where you can try every single code the remote has one at a time to see if any will work.
A original remote will have many features the Dish remote will not be able to do.
Not all remotes will program for all sets and or all functions.
May 04, 2012 | Flat Panel Televisions
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
My new remote that came with the tv does not allow me to change channels, but my dish remote still allows me to change channels
Your dish remote is the only one that is compatible with the dish receiver. You're going to have to program all the functions you want to use to the dish remote. They are usually set up for all the normal functions, volume, power, dvr etc.
Dec 08, 2010 | Element Electronics PLX4202B 42 in. Plasma...
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Need code for 32in.olivia tv
Remote manufactures and service providers continuously add support for new TV products. If you have the following Satellite or Cable Systems, try these remote codes for Olevia HDTVs.
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, TiVo’s, DVD, Blu-Ray or even HD- DVD players. The learning remote is available at 866-965-3842
Dish Network Remote Codes 506 or 127
could try Dish Network..Remote Codes 506 or 127
Satellite TV Systems Dish Network Remote Codes 506 or 127
May 23, 2009 | Syntax Olevia 537H Television
Need Dish DVR ViP722 remote code.
If you are looking to have the Dish remote operate your TV, just do a random search for your tv. First, hold down the tv button on the dish remote until all the rest of the light up. Next press the tvpower button on the dish remote. Next, press the channel up button (this is the up arrow button) until the set turns off. When it does turn off, press the # key at the bottom right of the remote. The tv button will light and flash twice. That's it. Your done. Hope this helps.
Feb 20, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Remote code
I had the same problem with a Viewsonic N3735W LCD TV and Comcast Customer DVR 3 Device remote. I contacted Viewsonic and they gave me 11454 which works.
Dec 19, 2008 | ViewSonic N3735W 37 in. LCD TV
Universal remote
All you need to do is a manual code search on the dish remote. If it does not respond with the manual code search,the remote your trying to use cannot be used for this TV set,or you will need to upgrade to a differant Dish remote as the code is not programmed into the remote. What happens when you do a manual code search is one by one the remote sends out every single code that is programmed into the remote. Good Luck
Dec 23, 2006 | iLO 2600 Television
Olevia LT42HVi 42 in. LCD Television Logo
1,676 people viewed this question
Top Olevia Flat Panel Televisions Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you an Olevia Flat Panel Television Expert? Answer questions, earn points and help others
