Question about Car Audio & Video
Code 172 ego code - Car Audio & Video
emissionwiz
  • 75822 Answers
SOURCE: 1995 Ford Bronco 172 EGO not switching lean bank1- jerks when run
Have u checked for vacuum leaks or poss leaking EGR valve? use carb spray around the upper intake manifold where it bolts to the lower manifold, spray vacuum lines where they are connected to the engine vacuum ports, the idle speed will change if u hit a leak, as far as the EGR valve goes see if it gets hot at idle, if it does it is leaking, if all checks ok replace the O2 sensor, but i suspect u will find a leak at the upper intake plenum.
Posted on Jan 10, 2009
  • 46 Answers
SOURCE: ford 4.0 v6 misfiring
yes an o2 sensor can cause the mixture to go lean or rich. But you have another culprit also a knock sensor can cause this also. for the miss this is more of what the knock sensor would control. Hope this helps you
Posted on Jan 18, 2009
warlock61
  • 659 Answers
SOURCE: CODE 172 ego not switching lean condition
it is possible you have a leaking injector on that bank. how does the vehicle run?
Posted on Jan 29, 2009
  • 21 Answers
SOURCE: 172 EGO not switching lean
p0172 means bank 1 of your engine is rich. Need more info on vehicle make model year ect. Could be a sticking fuel injector or on a single bank engine (4 cyl or inline 6 cyl) too much fuel pressure or mass airflow malf.
Posted on Sep 18, 2010
SOURCE: check engine lite on and
Replace the one or two O2 Sensors, that are the closest to the motor,
if they have 80,000 miles or more on them
If you have no idea how old the rear ones are,do them as well
Rock Auto.com --- for ALL your parts
Quality parts & best prices
You will never go to an auto parts store again.
Posted on Sep 20, 2011
Check engine lite on and off. Eratic EGO 172 code ??
Sep 20, 2011 | 1995 Ford Aerostar
How to enter radio code,which i have,into Renault radio fitted to a T35 van year 2001it has a steering wheel remote OE
PHILIPS RENAULT CODE ENTRY INSTRUCTIONS
FOR CARS WITH A STEERING WHEEL REMOTE CONTROL
(Note :If you don`t have the [ ¬ ] button then push the thumbwheel in and some will have an [ A¬ ] button )
Turn on the radio and the display will show 'CODE'
Use the Steering Wheel Remote Controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit Press the [ ¬] button then rotate the thumb wheel for the correct second digit Press the [ ¬] button then rotate the thumb wheel for the correct third digit Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit If the correct code is now shown on screen, press and hold the [ ¬] button for up to 10 seconds to store the code
Jul 08, 2011 | Car Audio & Video
Renault coupe sport i have the code for this radio but unsure how to input the code for to get it on
Philips Renault Code Entry Turn on the radio and the display will show 'CODE' Use the Steering Wheel Remote Controls for code entry. Press the [ ¬] button then rotate the thumb wheel for thecorrect first digit Press the [ ¬] button then rotate the thumb wheel for thecorrect second digit Press the [ ¬] button then rotate the thumb wheel for thecorrect third digit Press the [ ¬] button then rotate the thumb wheel for thecorrect fourth digit If the correct code is now shown on screen, press and hold the [ ¬] button for up to 10 seconds to storethe code
Mar 18, 2011 | Car Audio & Video
I have the code. for my renault megane coupe. but how do i put the code in
Philips Renault Code Entry Turn on the radio and the display will show 'CODE' Use the Steering Wheel Remote Controls for code entry. Press the [ ¬] button then rotate the thumb wheel for thecorrect first digit Press the [ ¬] button then rotate the thumb wheel for thecorrect second digit Press the [ ¬] button then rotate the thumb wheel for thecorrect third digit Press the [ ¬] button then rotate the thumb wheel for thecorrect fourth digit If the correct code is now shown on screen, press and hold the [ ¬] button for up to 10 seconds to storethe code ===================================
Jan 20, 2011 | Car Audio & Video
Cant program radio code renault scenic
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Philips Renault Code Entry
Apr 11, 2010 | Car Audio & Video
Radio code for model 22dc278/62b prod fd0201480096261 toa559rn278f10096261
Your code is 0484
Use the steering controls for code entry.
Sep 12, 2009 | Vehicle Parts & Accessories
Jan 29, 2009 | 1993 Ford Taurus
Ford 4.0 v6 misfiring
Jan 17, 2009 | 1994 Ford Explorer Limited
Dec 06, 2008 | 1995 Ford Bronco
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
