Question about Elkay Refrigerators
Elkay LZ08S water fountain red light indicators stay on after the filter has been replaced with a new filter. How do you reset the indicator lights?
SOURCE: Daewoo refrigerator water filter red light still on after replacing the filter
Press and hold "ICE MAKER LOCK" button, and while holding it shortly press "LOCK" button, and the light will change to green LED.
Ivan
Posted on Nov 12, 2007
SOURCE: Water filter indicator light
On my samsung I needed to press the ice timer and ice mode together for 3 seconds.
Posted on Mar 29, 2008
SOURCE: Water filter light on refrigerator
Found this site and the fix worked for mine. You need to press a combination of buttons and this tells you which ones
http://www.partselect.com/water-filter+reset-change-filter-light+repair.htm
Posted on Aug 08, 2008
  • 34 Answers
SOURCE: indicator light for Brita filter not working
I see this alot when I do installs...contact the Brita tech support
1-800-24-BRITA (US)
Posted on Feb 04, 2009
SOURCE: Water Filter Indicator Light on Maytag side by side
Hold light and lock until change filter light blinks
Posted on Feb 11, 2009
After replacing filter, how long before filter light goes off?
Filter indicator : The filter Indicator will be Red when you have used your water filter for 6 months, Reset the indicator (it will be Blue) after replacing the filter by holding the "Alarm/Hold 3 sec for Filter Reset" button for 3 seconds.
The above is how to reset the indicator
Jan 22, 2016 | Samsung RF4267HARS 27 cu.ft. French Door...
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
I am replacing the water filter how do I reset on the outside door
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Thanks, Sea Breeze
May 17, 2010 | Jenn-Air JCD2295HES Side by Side...
Red light stays on after changing the water filter and running about 2 gallons through it
Light (select models)
To Reset Indicator:
successfully reset.
Nov 27, 2009 | Maytag MZD2665HE Side by Side Refrigerator
Change filter light
To Reset Indicator:
successfully reset.
Sea Breeze
Nov 25, 2009 | Maytag MSD2650H Side by Side Refrigerator
Water pressure is low on the elkay fountain
if you mean the amount of water that comes out of the bubbler head....you can adjust that by accessing the push button cartridge and turning it to adjust how far it is pushed.
Oct 18, 2009 | Elkay EZS8-L Single-Level Wall Mount Water...
Changing light after installing new water filter
(select models)
To Reset Indicator:
• Press and hold both the LOCK and WATER
successfully reset.
Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Water Filter light still red after new filter installed
You have to reset the light by pressing and holding the touch pad for 3-5 seconds. It doesn't reset on its own when you replace the filter
Dec 08, 2008 | Samsung RS2630SH Side by Side Refrigerator
I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
Aug 01, 2007 | Whirlpool S20DRSS33 Side by Side...
Refrigerators Logo
Top Elkay Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Elkay Refrigerator Expert? Answer questions, earn points and help others
