Question about Neff Dishwashers
Have a Neff dishwasher S16P1F with a faulty drop door
5 Suggested Answers
SOURCE: neff integrated dishwasher
there are some screws inside the door, around the edge. These would be the first to undo then I think the door would have o be pulled up slightly to relaease.
Posted on May 05, 2008
SOURCE: adjusting the door on a neff dishwasher
I have the same problem with my newly installed Miele integrated dishwasher. The door does not stay open when you are trying to load dishes. I heard that there is an adjustable internal mechanism to adjust the tension on the door. But, I am still working on solving my problem.
Posted on Aug 17, 2008
  • 10865 Answers
SOURCE: Neff dishwasher door problem.
The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
Posted on May 21, 2009
  • 10865 Answers
SOURCE: Neff dishwasher door catch not corking, door does not close ?
look carefully at the catch and the latch as almost all can be adjusted with just a screw driver.
Posted on May 31, 2009
My Neff S5443X1GB/07 dishwasher stops after approx 20 mins of washing, the water is nice and hot but it needs the door opening and closing several times to encourage it to progress a bit further of th
If your unit has a round dial timer (like many washer machines) the timer may be sticking. If it has an electronic timer then the door switch may be faulty. Don't run this unit unless someone is nearby, if the door switch shorts out, you may have a fire.
Jan 02, 2015 | Neff Dishwashers
Deactivate childlock on fully integrated neff dishwasher
If door won't close and you don't have a child-lock, just push the door closed a lot harder than you normally would - NEFF manual says to do that, and it worked for me! I think it just forces it to engage and 'releases' the catch, as after that it closed with just normal pressure applied.
Apr 09, 2012 | Neff 24 in. S5456 Built-in Dishwasher
May 31, 2009 | Neff 24 in. S4456 Built-in Dishwasher
May 21, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Door spring does not work.
bryan,
I do not have a place to order parts for a Neff dishwasher, but I know these dishwashers have springs in each hinge that will wear out/break over the years.
Replacing those springs will stop the door from drooping open.
Good Luck!
Apr 05, 2009 | Neff 24 in. S5409X0 Built-in Dishwasher
I have neff intergrated dishwasher, but the door does not seem to stay on. It has two fixings at the bottom and two at the top. Any ideas?
When you open the dishwasher door you will see three screws along each edge. You need to remove the middle screws and replace them with longer ones that will go into the door front as well.
Feb 17, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Neff dishwasher trips the electricity
It could be faulty wireing in the dishwasher connection or you could have a leak in the washer causing the wires to get wet. I would have an electrician have a look at it.
Dec 19, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Neff intergrated dish washer
Drain pump is either faulty or blocked, follow drain hose back to d/washer pump is at the end, always isolate from power supply before attempting any work
Jul 24, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Neff integrated dishwasher
Mar 28, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Adjusting the door on a neff dishwasher
Mar 16, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Dishwashers Logo
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
