Question about Samsung Refrigerators
Samsung french door RF267AERS FREEZER IS NOT WORKING BUT THE TEMP ON FRONT SAYS -4
  • 9 Answers
SOURCE: I'm getting frost in freezer of my Samsung french
i would check the magnetic seal around the door to make sure it is not letting air in ...this is the cause of the over freezing.
Posted on Jul 13, 2009
  • 1891 Answers
SOURCE: Samsung French Door Refrigerator not cooling
it's only 4 weeks old ./ don't mess with it it has a warranty you may void it if you work on it . it is probably in the main digital control in th fresh food .. but i would call the seller and they can set up a service for it .. mm
Posted on Dec 24, 2009
SOURCE: Front ice/water dispenser stopped working.
I had the same problem. Turned out to be a microswitch under the lever used to activate it. The microswitch fell from the original position so it wasn't turning on anything. I tried gluing into position but the fumes from the crazy glue messed up the switch and I had to replace the whole rig.
The part is under the control display. You can pry it open from the left side.
Posted on Jun 04, 2010
SOURCE: Fridge temp set to 38 is blinking,,reset unit
I had a similar problem, paid a technician $90 to tell me to defrost the entire unit for 15-20 hours, and now it works like new. It is supposed to self defrost, but with poor circulation in the freezer (simply caused by too much stuff in there) the unit frosts up. This caused a rising temp in the freezer leading to inconsistent temps.
Anyone reading this with a similar issue, save your money and defrost it overnight. You should see a pool of water in the bottom of the freezer after defrost if this was the problem.
Posted on Aug 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: Temp control is displaying Er and FF code
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
How do I keep interior lights from turning on when I open doors?
Best way and will make sure they don't kill your battery is to remove the bulbs.
Dec 04, 2015 | Samsung RF267AERS French Door Refrigerator
Ice buildup in frig above evap coils. Defrost coils seem to work, at least on manual. Samsung mdl RF266AES/XAA
If the defrost element is working the you have to totally defrost the evaporator, kick it back into life & all should be ok. Air intruding into freezer could be the cause of the frost, make shure the seals are ok & in place, make sure the doors are closing all the way.
Nov 20, 2013 | Samsung RF267AERS French Door Refrigerator
How to install main board on a Samsung RF267AERS
Samsung RF267AE Service Manual This manual is provided by www.manualslib.com. This technical link is what you will need to efficiently follow the process from start to finish. A new member simply signs up. The site is wonderful. A member can upload any data to it, that, you consider can be needed in the world community. Fixing is not repairing. In order to to either, formal information is the key to a pleasant revival.
Feb 08, 2013 | Samsung RF267AERS French Door Refrigerator
Samsung rf267aers won't make ice
26 cu ft French Door Refrigerator Here is a refined site that has a variety of sensible answers for your product. This will save a service call and you can even obtain live support. Good Luck.
Dec 29, 2012 | Samsung RF267AERS French Door Refrigerator
Rf267aers leaking water
Your going to need to empty out the fridge, take the shelves out, and then remove the rear wall inside to gain access to the evaporator area. Once you can see the evaporator look directly below it and you'll noticed a trough of sorts that should have a drain hole in the middle of it. More than likely this is clogged and needs to be cleared so water can flow smoothly out of the machine
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 15, 2012 | Samsung RF267AERS French Door Refrigerator
Dec 24, 2009 | Samsung RF265AA Bottom Freezer French Door...
My refrigerator is too cold
sounds like you have a defective temparture sensor
Apr 07, 2009 | Samsung RF265AA Bottom Freezer French Door...
Samsung refrigerator
There is a screw down foot in front of each forward wheel under the fridge. You can access this by looking under the front corners.
Dec 21, 2007 | Samsung RF265AA Bottom Freezer French Door...
Refrigerators Logo
113 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
