Question about Sewing Machines
2 Suggested Answers
SOURCE: cannot transfer designs from customiser
removed customiser 10000 & installed customiser 10000 plus both programs conflict with each other you can only run 1 program.
Posted on Oct 07, 2008
Need help using flash stick to download embroidery designs from computer and what they are jef, emb,
.Jef and .Dst will work on a Janome machine. You can buy designs per the hoop sizes for your machine. Buy, download, and transfer received file to a USB drive to transfer deign to machine.
Embroidery Services
San Diego, CA
May 28, 2016 | Janome Memory Craft 9000 Computerized...
How do I transfer embroidery designs onto the expressive 900 machine without the digitizing software? Can I even do this?
You can purchase design and send them directy to your sewing machine. It has direct connect PC . Which means you can connect it directly from your computure and transfer designs to your sewing machine. Also you can purchase designs in your format from different web sites. They will E mail them to you. Then save them to a USB stick. You can load them from a USB stick into your sewing machine .Look for 2 gig USB sticks ,because when you use larger ones it takes a long time to load the designs. The only drawback to not owning sofeware is you will not be able to see the designs if you chose to save them on your computure. Embird has a 30 free trial and is reasonable priced. It give you the ability to convert designs from other formats and use them in your machine. It will open zipped designs and acts as storage unit for your designs. I do not represent them but i found that it is less expensive than many companies and works well.
Nov 16, 2014 | Sewing Machines
My XP computer and my Windows 7 do not have ports for a disk so that I can transfer designs for the Designer I. What do I need to do to be able to transfer these designs? Is that what a reader/writer...
If your computor doesn't have a floppy drive, you can buy an external floppy drive that will just plug into one of your USB ports on your computor. You can probably pick one up for about $30.
Apr 28, 2011 | Husqvarna Designer I
I have a #1 machine
If you purchase a reader/writer unit with a rewritable memory card in the format for your machine, you will not need additional cards.
Copy the designs from the CDs to the hard drive or insert the CD as you need to access a certain design and then copy the selected designs to the memory card.
The card can only store a certain number of designs and then you reload when you want a different design.
You can get this unit from a sewing machine dealer, but they are less expensive on-line.
Always check with the vendor before purchasing to be sure the unit will work with your brand/model and machine embroidery format.
Apr 10, 2010 | Husqvarna Viking 1
I have purchased a Janome 9700 embroidery machine and it came with a disc of designs (jef format) . I have downloaded the designs on to the memory card and can view them via the computer but they do not...
Since you are able to view them from the ATA (Compact Flash) card on your computer and the designs are in *.jef format you should be able open them on your machine. Make sure you have selected to view designs from the ATA memory card and not the ones stored on the machine or from the External Card Reader box.
There is an additional program called Customizer that you can import designs, edit, and transfer them to your ATA card. Mine was part of my package deal when I purchased by 9700.
Oct 21, 2009 | Janome Memory Craft 9000 Computerized...
Transfer designs to my blank memory card
You need a a Reader/Writer box with a blank Janome memory card (PCMCIA) and Cusomizer software. With that you can move your downloaded .sew designs into Customizer and on to the card via the Reader/Writer box provied that they are within the allowable size constraints.
Jul 19, 2009 | Janome Memory Craft 9000 Computerized...
Cannot transfer designs from customiser 10000 gigahoop designs to memory craft 10000 sewing machine. i have no problems transfering designs to machine from easy transfer.
Oct 05, 2008 | Janome Memory Craft 10000
Downloads to iMac
Google "BriTon Leap" for solutions for using your iMac. They have programs called Embrilliance, which works with iMac
Mar 12, 2008 | Brother SE-270D Computerized Sewing...
Cannot get Janome 10001 to read via USB direct link from computer
here's how I do it.
1. Get the design into jef or sew format (the only kinds janome reads). You probably already knew this, but some newbies try to use pes or art files.
2. Save it onto your computer (and remember the name of the file). I have a folder in my computer labelled "embroidery files" and then have subfolders dividing up those designs - such as animals, flowers, fonts.
3. Hook your sewing machine up to the computer via the USB cable.
4. Pull up your Janome "Easy Transfer" program (it came as a CD with your machine - this is NOT the customizing software).
5. Use that program to find your embroidery file. It's not going to show sew and jef in the same file - you'll have to switch back and forth.
6. On your sewing machine, click on the bottom button (under the screen) that shows the computer to the sewing machine (the third one).
7. Now click on the computer software "write to machine" or whatever it's called (it will be on the top tool bar).
8. Your file will be written to the sewing machine's memory and organized by the embroidery hoop size (A, B, C).
9. It will stay in the sewing machine memory until you use the cable hookup to delete it (reverse of the writing).
10. The 10001 software ate lots of the resident memory in the sewing machine - you can't store as many designs in it as the 10000 would allow. That's perfectly ok, as it only takes a few moments to move designs in and out of the machine.
To be perfectly honest, I vastly prefer doing the USB cable transfer to using the memory card jammed into the card reader deal. It's easy and quick.
Oct 30, 2007 | Janome Memory Craft 9500 Computerized...
Sewing Machines Logo
22 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
