Question about Garden
Suddenly no compression on Toro walk behind
I have a 2 year old Toro 6.5 hp walk behind mower that has been kept inside. Usually starts with one pull, even after winter storage. I was mowing and accidentally hit a piece of stone and it died, but when I pulled the starter it started right up on the first pull. I continued mowing that day for a long time and it ran great until I killed it when I finished. The next time I tried to start it, it wouldn't start at all and didn't even feel like it had any compression. Wouldn't start with plenty of oil and gas and a new spark plug and clean filter. When the spark plug is out, the piston is moving, but there still is no compression at the point where there should be. The blade is moving and there is no sign that anything is broken, but it seems that the valve is opening at the wrong time. Any ideas? If hitting the rock sheared the shear pin, why did it start back up and continue mowing great after that? The shear pin wouldn't throw the timing off would it?
  • gary711 Jul 25, 2009
    Yes, the mower does have fire. Plug is sparking very well.
  • Anonymous Mar 26, 2014
    It was stored over the winter, then was hard to start initially. It ran very rough, and kept cutting out. It eventually ran smoothly, but when I left it overnight, it wouldn't start. There is next to no compression.
  • 130 Answers
Yes the shear pin will throw the timing off.check it anyway it might be ok but then again you ever know.check for fire coil should be at 010.from frywheel it might slip check compresstion anyway with gauge then valve gap need manual for this if ohv check pushrods this could make bad compresstion if one is bent.let me know want you find out ok
Posted on Jul 25, 2009
What is spark plug gap on toro lawnmower model#20332?
Toro has your manuals here depending on year of purchase. If they don't mention the gap, I would use to the contact page to ask.
https://www.toro.com/en/homeowner/walk-behind-mowers/22-personal-pace-20332
22 56 cm Personal Pace 50 State 20332
Apr 14, 2016 | Toro Power Lawn Mower
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
Toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Apr 10, 2012 | Toro 52" Cut Wide Area Walk Behind Lawn...
I have a Toro 20" self propelled, electric start
I am strictly Briggs&Stratton. They are hard to start when the fuel tank is half empty. Clean the plug and air filter.
Jun 15, 2011 | Toro Power Lawn Mower
My 3 year old 22 inch walk behind mower will not start, I replaced the spark plug, there is no spark when I pull the hand start
Replace the flywheel key by removing the rewind housing, the flywheel nut and then remove the flywheel by using a small engine universal puller (cheap) and install a new key.
Jun 03, 2010 | Toro Lawn Mower With Toro Power Tools
Toro 6.5 hp 9 year old mower. Starts Ok; surges
Sounds like your carburetor needs to be cleaned out. The surging is usually a sign of running to lean (not getting enough gas) because of possible water, rust, gum, varnish or trash in your carb. Hope that helps.....
May 17, 2009 | Toro Lawn Mower With Toro Power Tools
Toro walk behind model 20025 Gas running through the carburetor
Carb. float must be stuck open. First if you have no fuel in the tank it must all be in the crankcase.Drain the oil and refill and also check the carb as the float has to be sticking open. Hope this will help you. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 20073 self propeled, walk behind mower-how to replace belt ?
Wait until the mower cools off
1. Remove the drive belt cover from the top of the mower
2. Tip the mower up, being careful to not go too far or the oil and fuels may spill out
3. Remove the mower blade - as I recall the bolt is 5/8" (could be 9/16") You will have to hold the blade from turning (if you have impact tools, this will be much easier)
4. Remove the blade
5. Pull the pulley out or off and remove the belt - be careful to not lose the crankshaft "woodruff" key - it's the little piece of half/moon shaped metal that keeps the pulley from spinning on the crankshaft.
6. Reverse the steps to reinstall
You MUST make sure the blade is tight when you reinstall it. Also, the blade usually fits over a couple of pins - make sure they are lined up properly and the blade is installed right-side up.
Mar 16, 2009 | Toro Lawn Mower With Toro Power Tools
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
776 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
