Question about Gaggia Coffee Makers & Espresso Machines
Gaggia platinum vision steam valve replacement
How to replace steam valve?
  • 2039 Answers
SOURCE: Leaky Gaggia Classic Espresso
you have very steam because like you know our loosing our pressure you need a seal kit be carefull when you play in there calcium buildup is very hard to remove cheers
Posted on Feb 03, 2008
SOURCE: Gaggia Platinum vision (not in
I fixed it!!!
Take the brew unit out and remove the grey inlet peice (2 screws) then take out the peice with the perforated disc in it out and remove the disc. Clean the disc so you can see through all the holes and re-assemble.
This sorted my machine out and it now behaves correctly again.
Posted on Jan 03, 2009
SOURCE: steam valve wont turn off - need new steam valve
Go to http://www.partsguru.com/GaggiaHomeEspressoMakers.html and order it from them. They have great service and you have the parts in days.
Posted on Jun 25, 2009
EsWorld
  • 1618 Answers
SOURCE: Gaggia Coffee Classic Steam Valve Leaking - No Pressure!!
Yes it can be repaired if you have the parts, you will need the complete steam valve with the o-ring that connects to the boiler check the diagram below.
Posted on Aug 28, 2009
  • 3 Answers
SOURCE: NEW GAGGIA PLATINUM VISION GRINDER NOT
yes by either changing the grinder motor and/or the sensor HAL506
Posted on Jan 11, 2011
Gaggia Classic: how to replace the steam valve
WholeLatteLove has the necessary parts; they are the valve and an O-Ring or gasket. The valve is held in place by two Allen head metric cap screws. You remove the knob, open the case, remove the steam wand tubing (you reuse this), take out the cap screws and the valve comes off. Just reverse for assembly, don't overtighten the cap screws as they thread into aluminum. I've replaced several of these over the years; they don't hold up well. I have one to replace currently, and plan on using the old valve body as an adapter for a commercially available needle valve that hopefully hilds up better and is easier to get and costs less. IIRC, price on the Gaggia part is about $35. Hope this helps.
Jan 02, 2017 | Gaggia Coffee Makers & Espresso Machines
Seems that the valve stuck in wrong position. Try to start cleaning mode.
May 20, 2014 | Coffee Makers & Espresso Machines
What does wrench on screen of gaggia platinum vision indicate
I found a failing power supply board can cause the 'wrench' error code even in standby. The board is available for about $65 online and works in many Saeco models as well.
Jul 18, 2012 | Gaggia 74845 Platinum vision coffee maker...
Gaggia Platinum vision says dispensing failed
I suggest the spanner is telling you there is a fault, so you will need to get it serviced or repaired. It is doubtful that you can do anything.
May 06, 2012 | Gaggia 74845 Platinum vision coffee maker...
We have a gaggia classic and when the machine is on but the steam switch is off, water and steam still spray out of the steam nozzles. Is there a gasket that needs to be replaced or could the knob be...
You cannot replace the gasket in the steam valve, you will have to replace the whole steam valve assembly, you can get a replacement from wholelattelove.com
Aug 14, 2011 | Gaggia Classic Espresso Machine
NEW GAGGIA PLATINUM VISION GRINDER NOT WORKING ANY WAY TO FIX THIS?
If it's new send it to a service centre.
These grinders are failing and can also damage the power supply board.
Dec 29, 2009 | Gaggia Platinum Vogue 90800 Espresso...
Gaggia platinum leaking from milk island
The problem is the steam valve leaking.
It does not close fully and leaks.
You will find that when you turn the knob is seems very loose.
A service is required.
Jun 23, 2009 | Gaggia Platinum Vogue 90800 Espresso...
Water is leaking, while the machine heats water for steaming
The steam valve tap rod needs to be replaced, or check machine if it has a plastic steam valve, Gaggia designed a new Stainless steel steam valve for the compact machine.
May 23, 2009 | Gaggia Syncrony Compact Coffee...
Coffee Makers & Espresso Machines Logo
76 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
