Question about Vax Vacuums
How to change brush on vax ultra cleaner - Vax Vacuums
4 Suggested Answers
ukvacfan
  • 328 Answers
SOURCE: HOw to change the Belt on a Vax VX1 Model
There is a brush reset button on the handle. Check to see if this has been pushed in. Also check to see that the brush slider has also been switched on. Usually belts are protected on this model but you should be able to remove the bottom sole plate where the base of the vacuum is (and beater bar). If the belt cover can't be removed then it has to be repaired professionally.
Posted on Mar 27, 2009
SmartAlec
  • 171 Answers
SOURCE: my rotating brushes have stopped rotating
Almost certainly you have broken a drive belt. It is not a big deal though just turn it upside down and remove the base plate you should be able to access the belt from there. You should be able to get a belt pretty easy from an online retailer like vacuumspot
Posted on May 18, 2012
ercupa190
  • 12223 Answers
SOURCE: Vax rapid ultra brushes not turning
Dear Sir:
1) Test the power cord for defective wires, broker,or loose repair
2) Test the switch for open see the diagram
3) See if there are some open fuse.
4) See if the belt is broken, replace.
5)Test the input voltage motor.
God bless you
Posted on May 27, 2012
My vax cleaner trips the breaker on my consumer panel after about 30 seconds use. If I reset the breaker it will then operate for a similar time then trip again
It sounds like the windings or brushes in the motor are bad and draw too much current. Perhaps you sucked up too much water once and got the motor wet. I would take it to an electrics repair shop and have them check the brushes.
Sep 06, 2014 | Vacuums
My vax rapide xl ultimate v-027y brushes not working..new belt fitted and same problem
hello i have a vax rarid xl carpet cleaner when you switch power on just makes a buzzing noise can you help thanks
Jul 15, 2012 | VAX Appliances Vacuums
Vax rapide ultra not sucking water
Dear Sir:
Retach the nozzle to the cleaner. Cleaned can be blocked most of the time.
Wait for cool down, and try again.1( See the hose defective 2( Test pumpmotor for some wires loose or belt if there are, so you need replace.
God bless you
May 26, 2012 | VAX Appliances Agilty V123 Upright Wet...
Dear Sir:
God bless you
My rotating brushes have stopped rotating
May 07, 2012 | VAX Appliances Vacuums
Hi i have a vax swift complete 1800 watt,it is not picking up and the brushes are not moving they are also tough to move by hand what could this be
Possibly brush needs to be removed , cleaned , brush bearings lubricated, and new belt or oring belt needs to be fitted.
Dont do it yourself unless mechanically minded.
Ring up vacuum cleaner place.
Sep 12, 2010 | VAX Appliances Vax X5 Bagless Upright...
Mar 24, 2009 | VAX Appliances Vax X3 Bagless Upright...
Vax 2400 performance pet overheating
Unfortunately there is no permanent solution.It is a terrible vacuum cleaner and im getting rid of mine today. I have been maintaining it for 6 months cleaning filters , swapping filters, swapping carbon brushes all to no avail.Dump it. it would'nt **** the air out of a balloon.
Jan 29, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuums Logo
29 people viewed this question
Top Vax Vacuums Experts
rugby prop
Are you a Vax Vacuum Expert? Answer questions, earn points and help others
