Question about Refrigerators
Ice maker stopped producing ice. Then back wall of freezer is covered with ice. Turned off freezer overnight to see if it would defrost. Did not. Still has ice.
  • 58 Answers
SOURCE: ice maker leaks inside freezer
check the water discharge hose which fills the ice maker after ice is dumped into the bin. the line is located in most cases at one end of the ice maker and allows the water to flow into a funnel like device above the ice maker mold. the hose has the diameter of a penny, it is probably misaligned with the ice maker itself/
Posted on Sep 13, 2008
tborn6
  • 700 Answers
SOURCE: water coming from ice maker freezing down back wall of freezer
check for levelness of the ice maker also make sure that the fill tube is inserted all the way into the unit
Posted on Apr 25, 2009
Maytag317
  • 1136 Answers
SOURCE: Kenmore Elite Bottom Refer Internal leak
Hi, look and make sure the inlet tube to the icemaker is inside the fill cup. Make sure there is no ice build up in the fill tube also.
I hope this helps some, please let me know if I can help further.
Thanks Vic
Posted on May 15, 2009
Sea Breeze
  • 4655 Answers
SOURCE: TURN OFF FREEZER HALF TO DEFROST WATER LINE THAT FEED ICE MAKER
Just turn the refrigerator off inside on control panel. Then get a hair dryer and melt the ice away from the tube taking care not to get plastic too hot. Sea Breeze
Posted on May 22, 2009
  • 143 Answers
SOURCE: my daughter left the freezer door open overnight.
YES.
Posted on Aug 13, 2009
Clogged ice maker
1, ice maker may need to be replace, 2 water line may be frozen , if so turn off the freezer to defrost it for few hours, 3. when was the last time to replace the water filter? make sure you replace it when the time expired.
Sep 16, 2013 | Sub-Zero Freezers
KITCHENAID ICE MAKER STOPPED WORKING LED BLINKS WHEN FREEZER DOOR IS OPEN
Try firs unplugging power for 510 minutes, see if it reset.
Oct 10, 2008 | KitchenAid Refrigerators
Ice maker stopped producing ice. Turned off unit overnight to melt any possib. frozen secions in the line but still no ice.
Hello
Have you checked the waterline or water filter for clogs?
Also there is a solinoid in the back of refrig for water fill for ice,it may be stuck or not working.
Apr 13, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Not making ice, making a loud humming noise its a top freezer RT18BMXBL01
The ice maker has completely stopped producing ice:--Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly :--When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Noise can come from these areas:
The inside of the freezer :--Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator:--There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator:--Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
This will help.thanks.
Feb 21, 2010 | Roper Refrigerators
Freezer constantly produces ice buildup along the vents and fan blades inside are striking the ice buildup. Why wont the unit defrost? Also produces large chunks of ice from the ice maker during this time....
SAMSUNG REFRIGERATORS ARE KNOWN FOR DRAIN ISSUES., YOU NEED TO DETERMAN IF ITS FROST {DEFROST PROBLEM} OR ICE {drain issue} IF ITS ICE YOU SHOULD EMPTY IT AND UNPLUG OVERNIGHT WITH THE DOORS OPEN. IF FROST YOU SHOULD CALL FOR SERVICE.
Jan 14, 2010 | Samsung RS2630SH Side by Side Refrigerator
Icemaker stop working about 2 weeks ago and now the freezer not working
hi,
More than likely you've got an iced up evaporater. If you look in the lower section of the freezer on the back wall, is the wall frosty or icy looking? The only way to defrost this is by taking the back wall out of the freezer and using a hair dryer on it (being careful not to melt the plastic liner) or to just empty the whole thing and let it sit with the doors open for a few days. Be prepared for water to leak out from under it however as the ice melts and overflows the drain tray in the bottom of the fridge.
this will help you to fix ice maker http://www.bobvila.com/HowTo_Library/Fixing_an_Ice_Maker-Refrigerator-F2155.html
thank you,
vijay
Sep 29, 2009 | KitchenAid KSCS25FKSS Side by Side...
ED5NHGXMQ00 stopped working overnight. Ice maker
Clicking could be a bad starter relay if the noise is coming from the back under the unit where the compressor is. check it here Check your compressor relay- http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
The clicking could be coming from a fan, one of which is near the compressor under the unit and another is in the freezer behind the rear cover inside.
The defrost timer could be clicking. This sound would come from the fridge. Part 6 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ED5NHGXMQ00&productCategoryId=0165000&brandId=1198&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00011&componentDescription=CONTROL%20PARTS&documentId=W0309019&backToLink=Return%20to%20Sub%20Components%20list
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 16, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Ice maker not making ice
a few things, was the ice maker working before repair?? generally the ice maker need to "cool" before making ice, usually give 24 hrs to start producing ice. next perhaps the tech shut off water supply never turned back on??? bottom freezer, perhaps he had to remove the ice maker to remove the back wall of freezer and never reconnected wire harness to the back wall.
Nov 17, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite - top freezer
if there is ice build up at the back wall of the freezer section, then you have a problem with your defrost cycle. the freezer would not be very cold for the ice maker to work.
it's either your timer, defrost heater or your bi-metal.
tnx 4 using fixya,
drcool
Sep 30, 2008 | Kenmore Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
