Question about Samsung Washing Machines
Top loader Samsung washing machine wa13v9 wash ,drain but not spanning
SOURCE: hitachi top loader washing machine
Could be the safety switch which is faulty which is activated by closing the lid. There is a plastic section on the left hand side of the lid which activates the switch. The plastic lip on my model broke so i riveted a piece of alumimium in place
Posted on Apr 18, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
SOURCE: simpson esprit 450 washing machine top loader
your drive belt is brobably loose or broken
Posted on Aug 10, 2010
  • 490 Answers
SOURCE: washing machine not spinning or draining water
its your drain pump if you can hear it humming but no water is draining it is blocked or jammed by a foriegn object (most probably a 20 cent coin or bobby pin/s), if you can hear it working as normal but still no water it may have a blockage sumwhere along the drain pipe either that or the impellor has snapped off the shaft and is ratteling around and not actually turning, and with the spin that is directly related to yor drain pump issue as the washer will not even attempt to spin if water remains in the tub, incredibly easy to do hit me back if you want detailed instructions
Posted on Oct 14, 2011
Samsung washing machine WA13V9 fills water and drains what could be the problem
problem program board going from fill to empty with out energizing the wash cycle
Nov 04, 2017 | Samsung Washing Machines
I have a Samsung WA13V9 top loading washing machine, the water is not flowing into the machine when turn on. Inlet hoses and filters are clear.
It's possible to be the door switch fault.
Teoretically if the door is not close, the water isn't flowing into machine.
Jun 03, 2017 | Samsung Washing Machines
I have a Samsung WA13V9 top loader washing machine the water is not stopping when the cycle starts I have to turn the water inlet tap off for it to stop.
If the water keeps running all the time whether the machine is on or off, the water solenoid valve in the machine has failed. If it only fills when the machine is on, it is likely to be something with the water level control. The pressure hose could be blocked or disconnected or the pressure switch or water level sensor has failed. I'm not fully conversant with the Samsung but the same principals apply.
Mar 20, 2017 | Samsung Washing Machines
Samsung wa13g7q1 top loader
UNPLUG and lean forwards. sounds like a blocked pump. look underneath for the pump and remove it, check out inside and remove any blockages.
Nov 18, 2013 | Samsung WE356A5W Washer/Dryer Laundry...
My samsung vrt front loader will not drain or spin and showing nd code
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 28, 2010 | Samsung Washing Machines
Water drains in wash cycle
It is probably a solenoid valve for the drain that is stuck open. There could be an object in it or may be defective.
Jun 12, 2008 | Washing Machines
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
