Contact number for Sonoma outdoors so I can find a part
I need two base poles for model#TJWU-003-9P-KI/KIE/00/00E/MB/MBE/DP/DPE/RGS/RGSE/CY/CYE/DN/DNE/BSE/SFE/ASE/HTE/PCECAE/GP-14E
Need the support arms that go from base to main pole as rusted out
OK.. try this... Buy a 10' length of 3/4" EMT electrical tubing.
Cut it to length and HAMMER the ends flat.
Now drill holes for your new/fresh bolts and mount your new support arms from the base to the main pole.
Wa-La!
Anthony
Dec 02, 2017 | Sport & Outdoor - Others
Need poles for avid outdoor tent with screen house. Originally bought from big w
try outdoor or hiking retailers for spare poles
take the name of the manufacturer and the brand name and model to help identify the poles
Feb 26, 2017 | Sport & Outdoor - Others
I need to buy a replacement center pole for my Embark tent
Contact the maker of the tent for parts. We have no parts resources other than what is available to you.
Jun 14, 2016 | Sport & Outdoor - Others
How can I fix the rip on my patio umbrella
why bother, most of them are made in China and like most stuff we are a throw away society, it will cost you plenty for glue and material if you still chose to fix it, The most I get frmo umbrellas int eh desert sun is barely a year.
May 31, 2015 | SONOMA outdoors Crank And Tilt Solar Led...
Replacement Pole for Coleman Oasis Cabin Tent model 2000000583
Coleman may be contacted toll-free at 1-800-835-3278. Replacement parts are available from them.
Apr 01, 2014 | Coleman Outdoor Products Coleman Oasis 16...
Bought a tent with no poles no instructions have a model number
CONTACT MANUFACTURER FOR REPLACEMENT POLES ..OR # AND LENGTHS/DIAMETER OF POLES AND FABRICATE YOUR OWN...PERHAPS EVEN WITH SCHEDULE 40 OR BETTER PVC
Jul 30, 2012 | Wenzel Swiss Gear Grand Lodge Cabin Dome...
Loud banging noise when using the Kettler elliptical trainer, ctr
This is a common problem for the CTR1, it actually sounds a lot worse than it is. It's just one of the 4 bolts that hold the front "pole" of the CTR1 in place that is broken. You will need to unscrew the bolts at the base (just move the plastic piece that hides the bolts up on the "pole"). After removing the pole you will need to remove the broken bolt from the inside of the "pole" with plyers. Then just put the pole back in the base, replace the screws (be sure to tighten them good). All will be good :)
This is a weak point of the CTR1, be prepared to run into the same problem again down the road...
Nov 10, 2009 | Kettler Mondeo Elliptical Trainer
How do u erect a lichfield challenger 5 tent ?
Peg out 2 back pegs of inner tent. Peg out 2 front then side pegs. Place smaller pointed pole through hole at bell end of inner tent from inside, longer pole through hole at front.Fit protective bases to each pole. Top pointed poles with separators. Assemble roof pole, put through loop and over separators. Throw outer tent over from bell end (needs 2 people) then carefully lead towards front til holes in roof match - back hole first. Fit rain hoods front and back. Peg outer tent from bell end first then back corners, front corners then sides. Place porch poles through holes at front of porch, zip door sides down with one person holding poles upright and taut and peg out door. Peg sides all along making sure they do not touch inner tent. Fix guy ropes.
Aug 06, 2009 | Sport & Outdoor - Others
I desparately need some assembly instructions for my Barbie tent.
Mattel products, including Hot Wheels, Barbie and Polly Pocket:
In the US and Canada: 800-524-8697
Nov 19, 2008 | Sport & Outdoor - Others
jasbo
jasbo
