Question about Toshiba DVR3 DVD Recorder/VCR
Comcast cable/DVD recorder problems
My problem is this: recently, Comcast has been converting all its customers to a digital signal and installing these DTAs (Digital Transport Adapters) on all its customers' older TV (including mine). But the issue I have is with recording programing on my non-digital Panasonic DVD recorder. Since I installed the DTA, I've discovered that the only way I can record a program on a specific cable channel is to move that channel to Channel 3 or 4, before I leave my home. This means this is the only channel I can record (during my time away) is on that one channel.
How can I record multiple shows on different cable channels using my DVD recorder? Comcast says I need a spliter, but will this device allow me to program my DVD to record multiple shows on different cable channels? I'm confused. Thanks for any help you can provide.
4 Suggested Answers
SOURCE: Toshiba d-r400 recording
I don't see anywhere in the program menu to input a channel number to be recorded, only date and time.
Posted on Jan 25, 2010
SOURCE: Won't allow recording ESPN and other cable channels.
It sounds like the programs are copy protected. I've had the problem with an E 27 error, but I've had success with recording other programming.
Posted on Jul 25, 2010
  • 7 Answers
SOURCE: I have a D-VR7KC2 DVD
The short answer is "yes", but it really depends on your TV having more than one input.
You would put a cable splitter (see Google images) on the wire that comes out of the wall. One of the OUT connections would be to the cable box, and the other would go directly to your Toshiba unit.
Depending on the outputs of your cable box, and the inputs of your TV, each unit would be connected to a TV input either by cable or video connections. You would then switch back and forth between the input from the cable box - when you wanted to watch live, digital TV - or the Toshiba when you wanted to set up/watch recordings.
Posted on Mar 14, 2011
Is my Magnavox 1T HDD rECORDER COMPABILE WITH cOMCAST cable Box ?
If your Comcast box has a composite output, you'll be able to record SD shows. Use RCA composite video and audio cables between the box and the recorder. You'll have to set the box to the channel you want to record and leave it on. Then set the HDD/DVD unit to record from video input (L1 rear, L2 front) for the appropriate length of time. The manual explains this. The manual is available from Funai who built the unit with the Magnavox name: http://funaiport.com/upload/MAGNAVOX/Manual/MDR537H_EN_OM.pdf . See pages 19 and 42. If your TV and/or cable box only have a limited number of video inputs/outputs, you may need to daisy chain the composite video cables from the cable box to the DVD/HDD unit's video in. Then connect another composite cable from the DVD/HDD video out to the TV.
This Magnavox unit can only read analog (NTSC) cable video signals without a set top box. You will not be able to record a show and then watch another with the cable box.
I hope this helps.
(I know that my cable system's box has a composite video out. So it does work with most of the Comcast boxes. Many of the manuals are available here: http://customer.comcast.com/help-and-support/cable-tv/cable-box-user-manuals/ )
Sep 25, 2014 | Televison & Video
Tevion tdr930
The TDR930 does not have a digital tuner. It handles the PAL and NTSC video signals. You need to connect it to a set top box and then record on the Line In (composite video) input. The set top box could be a cable, satellite or digital-to-analog OTA converter. Since the DVD recorder can't record HD signal, the regular SD output converter box connected to an antenna will be good.
I wish that I had better news for you.
Jan 04, 2014 | Televison & Video
Tv picture changes and recording is unwatchable when trying to rec one of 4 local channels
It is the signal from the 4 local stations that is the problem, because you can record all others ok. Borrow another VCR and try to record them, if its the same tell the people who run the local channels that they are losing viewing figures, because their channels cannot be recorded.
Dec 27, 2013 | Computers & Internet
Since my comcast switched to digital I cant record !! Is this DVR compatiable with Comcast digital cable???
Yes,all DVR compatible with digital signal that included Comcast digital cable.U can't record because probally the program u tried to record it copy write protected.What did u tried to record?Just tried to record some plain show,If it is recordable than u know the deal.
Feb 02, 2011 | Panasonic DMR-EH55 DVD Recorder/HDD...
I recently installed a Comcast digital adapter to my SONY RDR-VX515 DVD Recorder/VCR Combo and then onto the TV. Now, when I try to program the VCR to record, the only channel options are Ch 4, Line 1 and...
Hi and welcome to FixYa
Initially, postback the model number of the Comcast digital adapter and the TV.
Offhand, if the Comcast digital adapter is connected to the Sony through a coaxial patchcord, then the Sony would really have to be set to Ch 4 (or 3). Channel selection is done on the Comcast digital adapter. It is not possible to record one channel while viewing another.
Good luck and thank you for asking FixYa
May 22, 2010 | Sony RDR-VX515 DVD Recorder/VCR
RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Jul 22, 2009 | RCA Analog (RCA) to Digital (USB)...
TV Guide on Line for viewing and recording was there and poof
I think I may have the "answer".
I am in Atlanta and have a Panasonic DVR that was working fine and sometime during the past month or so we lost the channel listings. I've tried many resets as well with negative results.
I called Comcast tonight. The agent helping me took a long time to research the issue and gave me this answer (which sounds reasonable). By the way, this is for the Atlanta area and may not be applicable to other areas of the country.
Due to delays in the conversion to broadcast digital and the fact that Comcast is experiencing bandwidth issues, they have digitized the "channel listing" signal. By mid-June Comcast's signal will be all digital and you won't be able to watch a TV connected directly to Comcast cable - regardless of whether it has digital or analog tuner (or both). This is contrary to what I'd heard before.
After mid-June, you'll either need to use a cable box OR what she called a "Digital Transmitter Adapter" (let's call it a DTA). Prior to being converted to "full" digital, you'll get notification from Comcast. She said I'd be able to get 2 DTAs at no charge (I currently have one Comcast HD DVR box). Additional DTAs would be $1.99 a month. DTAs will only provide access to the "basic" cable channels, but the good news is that the Panasonic DVR should be able to obtain its channel lineup through this DTA box.
If you have any questions, please feel free to contact me directly at richard_gladney@yahoo.com
Good Luck!
Mar 25, 2009 | Panasonic DMR-EH50 DVD Recorder
Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
Mar 08, 2008 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Toshiba DVR3 DVD Recorder/VCR Logo
400 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
