Question about Miele Dishwashers
Miele dishwasher doesnt pump out water
Miele dishwasher g532 doesnt pump out water
  • 171 Answers
SOURCE: Just purchased a miele g1142sc
Hi eaglesblue,
I'm Harvey the Master Plumber.
Your problem is: Just purchased a miele g1142sc dishwasher had a mate over who is a plumber and installed it. No water is coming into the dishwasher is there any safety seals on the water hose, put water into dishwasher pump is working fine.
Please take no offense but a plumber is not the same as an experieced appliance installer. Any way, your mate may have done just fine but the water line is clogged or he failed to flush the line before hooking it up and you may now have a clogged solanoid valve. Did you run the d/w a couple of times before he left? Did you confirm it working then and now it's not?
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
  • 5 Answers
SOURCE: Miele G646 dishwasher keeps trying to pump out
Had a similar problem with an 846, but with the inlet outlet lamp flashing. the bottom tray had filled with watedr froma dodgy seal. I switched off and disconnected the electricity. Removed the bottom front cover below the door (2 screws behind the pretty kickboard which also had to come off). The bottom of the machien was a big puddle. I dried this out with paper twowel, put the machine back together and it ran fine. I am going to replace the pump seals now as the machine seems otherwise OK.
Good luck with yours. rupertvdpP
Posted on Aug 11, 2009
Testimonial: "true, bottom tray was wet fron small split in waste pipe taped it up and have ordered new one thanks for the info job well done"
SOURCE: hi my miele dishwasher g665 no hot water or drying
new heating element
Posted on Jan 27, 2010
  • 37 Answers
SOURCE: F13 error code on Miele dishwasher. I can't find
The water valve on Miele dishwashers is built into the end of the water line where it hooks into your plumbing(in that box-looking assembly) Your best bet is to call Miele USA, I have had very good luck with their customer support system, they can usually diagnose your problem right over the phone.
Technical Support
Residential Appliances Hotline
(800) 999-1360
Monday-Friday: 8:00 am - 8:00 pm EST Saturday-Sunday: Closed
Posted on Apr 20, 2010
  • 230 Answers
SOURCE: Miele dishwasher G646 SC plus water pump
I would suggest any appliance repair shop or appliance retail store should be able to order one in for you
Posted on Sep 06, 2012
Miele 870 dishwasher..timer works but doesn't wash goes thru cycle but no evidence washing or water swishing around.
I had this happen when my "water pump" went out on my dishwasher. It wasn't pumping the water up and into the machine or pumping it out.
Jun 05, 2017 | Miele Dishwashers
Miele G 851Intake/Drain light flashes and program stops
Page 39
Jul 01, 2015 | Miele Dishwashers
Why is miele g1002 not using hot water
Most dishwashers are cold fill only , check it is heating ,( element , toc , relay or pcb)
Mar 02, 2015 | Miele Dishwashers
Sep 06, 2012 | Miele Dishwashers
My Miele DW is not pumping water into the unit.
The water is not pumped in. It usually comes through the inlet valve using the water pressure.
However, if the water is not circulating through the arms when wash motor is running, then it is likely the arms are clogged or the water is getting pumped out due to the pressure valve being faulty.
Sep 08, 2011 | Miele 24 in. Incognito G843SCVi Built-In...
This dishwasher will drain but not wash m/n g811sci the intake drain lite is blinking
A fairly common occurence with Miele dishwashers is the seal on the pump/motor assambly swells up freezeing the motor.Miele makes tool to free it up very easily,if it doesnt reoccur the seal just swelled and it will be ok once freed up.If it does reoccur the seal needs to be replaced. Any Miele authorized service company will have this tool and could free the motor up within 5 minutes and only a couple uses will tell if it will swell again and need to be replaced.
Aug 05, 2011 | Miele G811SCI Dishwasher
Dishwasher not draining
you need to remove the drain pump motor and see what is obstructing the impellar.(small shreds of glass:small popcorn pieces etc. Doesnt take much to stop the drain pump.Try and get to drain pump from the front. Miele very compact.
May 28, 2010 | Miele Incognito G818SCVi Built-in...
What is the error F14 in a Miele dishwasher ?
The error F14 in your dishwasher is due to water intake fault with heater or circulation pump, or something like that. The circulation pump would have been clogged. Try to clear it and your problem will get fixed
Apr 04, 2010 | Miele Premier-Plus Built-in Dishwasher
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Dishwashers Logo
Top Miele Dishwashers Experts
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
