Question about Nordic Track Exercise & Fitness
My Nordic Track GX2.0 Excise bike has limited adjustment. From Min to max adjustment the resistance motor only makes a 1/4 turn with a stop in the middle. Should it make a 1/2 turn min to max>
  • 104 Answers
SOURCE: air cond will run for 1-1.5 min then stop , will restart after about 2-2.5 min
you have un under charged unit, under charged of freon. add some freon and check for leak of freon.
Posted on Jan 20, 2008
  • 832 Answers
SOURCE: Nordic Track C2000 starts and then stops.
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the current over load circuit to activate thus shutting down the unit to prevent further damage, Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit shut down again then you will have replace the running belt and possibly the deck
Posted on Jun 01, 2010
  • 832 Answers
SOURCE: nordic track commercial 1300 manual
It sounds like reed switch inside the side panel located on the frame by the large pulley either needs to be adjusted or replaced. Try adjusting the switch first the clearance between the switch and large pulley magnet will be 1/8" if you have the same result then replace the switch.
Posted on Jun 14, 2010
  • 12223 Answers
SOURCE: i need a repair manual for a nordic track mod ntc4015.2 bike
Please go to www. nordictrack. com
then to service customer, and then parts & Manual, get the right model, serial number and download free. Of course you must download only the Onwer manual or user . For repair y/o service manual you must call then. In the web page you must find the toll free number for to explain you situacion.
Posted on Nov 22, 2011
  • 493 Answers
SOURCE: Min oil sign
Probably sticky sensor. The sensor is only a float. They do stick especially with lack of oil changes or incorect oil. Definatly oil min?
Posted on Jun 18, 2012
My cx1055 elliptical resistance is not working how it should. Once I get to resistance lever 4 or higher it starts out with the resistance but then it slips as you step into it. Any suggestions?
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For ...
Nordic Track Nordictrack Cx1055 Elliptical Incline Motor For Model Number 285090, ...the bolts that secure the magnet4=if there are slips, the resistance will . ... my schwinn 460 elliptical resistance cannot be changed When I increase the ... Every time I increase the resistance it will go to that level of resistance but within a ...
Need someone to install a new resistance motor on a Nordic ... > Manage My Life > Questions
Aug 10, 2013 - I bought a CX 1055 Nordick Track elliptical at a garage sale. I noticed that the resistance doesn't really change between levels. ... 100 dollars, but how much would it cost to have someone come out and do the replacement for me? ... I wonder if maybe something shifted when I brought it to my apartment?Missing: slips
[PDF]View Manual in PDF Format - NordicTrack
NordicTrack4. Place the elliptical exerciser on a level sur- face, with a mat beneath it to protect the... The CX 1055 elliptical exerciser is an ... 1055 elliptical exerciser features adjustableresistance ..... press the Odometer button again; the words "My.
Jan 05, 2016 | Exercise & Fitness
Tread belt not turning on
please LUBE the deck belt with WD-40 or grease . and try to loose a little the deck, the idea is to lift- 2-3" max.
Of course is time too, to maintenance Motor
Feb 12, 2015 | Nordic Track NordicTrack C2200 Treadmill...
Why my commercial vr resistance levels not working at all? Do i have to replace the resistance motor?
Jun 16, 2014 | Nordic Track NordicTrack Commercial VR...
How to adjust belt?
If you are adjusting the walking belt that much (7 complete turns) it sounds like the drive belt the small rubber belt from the motor to the front roller is really loose. You should only have to adjust the walking belt 2-3 turns max... you do not want to prematurely stretch your walking belt!
May 14, 2014 | Nordic Track Exercise & Fitness
Not incline or declining
I expect there is a limiter switch that tells the treadmill when it has reached its maximum elevation. The switch is probably either malfunctioning or broke.
Feb 27, 2014 | Nordic Track Exercise & Fitness
NordicTrack Classic Pro Skier has a noisy pulley
1) LUBE the deck belt inmediately, maybe you have now a WORN deck belt time to replace.
2) LUBE the rollers bearing TOO.
3) test the voltage input motor, if there are the motor NEED repair
God bless you
Oct 14, 2012 | Nordic Track NordicTrack Classic Pro Skier
I have a nordic track 4100i treadmill.
1) Faulty sensor speed try to adjust it face to face magneto motor
2)Sensor speed try to tight the connector very well.
3) Replace if neceesary.4) Main motor faulty or burn. Test 115vac for input measure without load fore easy running.
5) Test the main motor controller board for 115vac input and output for +5VCD,
6) Adjust the deck bel for 2-3" for lift max.
7)Lubricate the deck bel.
8) Test the transformer for input and secondary voltage.
See the block diagram for illustration how the main motor controller has 90% aprox of function of any treadmills.
sincerely. Merry Christmas.
ernesto cuadra
managua, nicaragua. c.a.
Dec 20, 2011 | Nordic Track Nordictrack Apex 4100i...
I have a Nordic Track EXP1000 that wad purchased
Go to click on manual input manufacturer and model name 1000.
Try this calibration procedure:
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
5) If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled.
6) The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
7) It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
8) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing.
If you still do not have belt movement then call iconfitness @ 1-800 999-3756
Jun 26, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic track commercial 1300 manual
Jun 12, 2010 | Nordic Track Exercise & Fitness
We have a Nordictrack Futura 2200 and when we set the weight resistance it jumps back to 10lbs. no matter what we set it for it jumps back to 10lbs
When the resistance setting changes, the motor will be heard. To prevent damage to the motor, do not pull any of the cables while the resistance setting is changing. If the motor has difficulty adjusting the resistance level and no cable is being pulled, there may be too much tension on the Upper Cable (110). Adjust the tension as described below. To decrease the tension on the Upper Cable (110), turn the two 3/8” x 38mm Tension Screws (106) twice, counterclockwise. Select the desired resistance setting. Repeat this step if necessary.
Apr 24, 2010 | Nordic Track Nordictrack Futura 2200...
Exercise & Fitness Logo
29 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
