Question about Canon Office Equipment & Supplies
Where is the USB port located on the Canon MF244dw?
  • Canon Master
  • 3,592 Answers
According to the manual it is at the back of the printer .
It is the very top socket in the part where the power cord plugs in at the back of the printer.
at the back of the printer it is on the right hand side.
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwjIgYv2ga7TAhVnLMAKHTJIALIQFggtMAI&url=http%3A%2F%2Fgdlp01.c-wss.com%2Fgds%2F4%2F0300025074%2F01%2FMF244dw_UsersGuide_usEN.pdf&usg=AFQjCNHrYeZUe12KK5nz9lY_IP0oOBDyAQ&sig2=NHRHWY1y0933j4fmJB4pjw
Posted on Apr 18, 2017
2 Suggested Answers
emissionwiz
  • 76848 Answers
SOURCE: Does anyone know how I can reset a Canon MF244dw printer to factory settings?
I can find no such master reset but you can reconfigure the printer, which means the software can be reset for user preferences. Below is a link to the user manual take a look for yourself. http://gdlp01.c-wss.com/gds/5/0300025205/02/MF244dw_UsersGuide_EN_1.pdf
Posted on Mar 18, 2017
Mar 18, 2017 | Canon Office Equipment & Supplies
Canon ir2018 copier usb port problem
Your problem is that the usb port is damaged and the only solutions worked for me too is that you have to remove the psb where the usb port is located and you should detached it and change with a new one...works perfectly than.
Jun 14, 2012 | Canon Office Equipment & Supplies
WHERE DOES MY STICK GO IN AN IBM THINKPAD LAPTOP
The model number is located either on the bottom of the right corner of the screen and on the label on the bottom of the laptop and the location and number of USB ports vary with different models.
The USB port is a connector/port that is 12x5 mm in size, some model thinkpad have onlt one USB port and some have 2 USB ports.
The USB ports are usually located at the back or at the sides of the laptop.
The T30 model has 2 USB ports at the back of the laptop located between the LAN and PS2 connectors.
The T40 model has 2 USB ports located at the left side of the laptop.
The A31p model has 2 USB ports located at the back left hand corner of the laptop.
The R32 model has 2 USB ports, one is located at the back left hand corner and the other is located on the left hand side of the laptop.
Feb 08, 2012 | IBM Computers & Internet
My Canon printer PIXMA MP 800 cannot be3 installed with my windows xp. Help please
ARE YOU UNABLE TO INSTALL YOUR PRINTER AND OTHER DEVICE MOSTLY REASON ARE YOU HAVE NO SUITABLE DRIVER THE BEST STEP THE FIND DRIVER GO TO MY COMPUTER MANAGE, DEVICE MANAGER, PROPERTY ON DEVICE WHOSE DRIVER ARE NOT FOUND, COPY DEVICE ID CODE OPEN http://devid.info SITE AND SEARCH YOUR DRIVER AFTER SEARCHING EXTRACT YOUR DRIVER ON ANY LOCATION GO TO DEVICE MANAGER, UPDATE DRIVER SELECT PATH OF DRIVER INSTALL DRIVER TO USE THIS STEPS
May 18, 2011 | Cannon Office Equipment & Supplies
Can I hook up to the DW 100 Canon burner with my ZR200 to burn mini tapes on DVD?
No. The Canon USA web site says the Canon DW-100 has a USB terminal and works with "USB 2.0 Hi-Speed (with compatible Canon camcorders only)." In other words, the Canon DW-100 burner works only with Canon's USB 2.0 camcorders. I have a Canon ZR200. The ZR200 has Firewire 400 digital video output, not USB 2.0 output. The USB port on the ZR200 is ONLY for still images. Video will not and cannot be output through the USB port on the ZR200. (Page 121 in the ZR200 manual mentions using the USB port on your camcorder for transferring still JPEG images to your computer.) You need a DVD burner with "DV Input" (also called Firewire 400 or IEEE 1394) to hook up your camcorder to burn Mini-DV tapes onto DVD. The Sony VRDMC10 Stand Alone DVD Recorder/Player has DV Input. The ZR200 camcorder did not come with a Firewire cable, but you can buy one at any electronics store or at a cheaper price online. Make sure that you get the right kind of Firewire cable, 4-pin to 4-pin or 4-pin to 6-pin, whatever the DVD burner you choose requires. (Your ZR200 has a 4-pin DV port on the camera's end.) USB 2.0 Hi-Speed (with compatible Canon camcorders only)
Mar 15, 2011 | Canon ZR200 Mini DV Digital Camcorder
I would like to print off of my lap top HP paodion dv7-1451nr Where is the port for the USB cable ? Is there a program/Cd I need for this?
Printers do not have a standard USB port. Instead, they use a port that is a bit more square. The cable you'll need is USB one one side and Printer on the other wide. These are extremely easy to find at an electronics retailer and are commonly known as a printer cable.
Whether or not you'll need a program/CD depends on your computer. After you have the correct cable, you can try connecting the printer to your laptop and seeing if the driver already exists/works correctly. If no luck, you can use the Internet to go to Canon's website and download the correct driver for your printer. That should get things going with no Program/CD needed.
Mar 01, 2011 | Canon MP560 All-In-One InkJet Printer
HAVE PRINTER CANON S200x The result was a BLACK CABLE LEFT AND NEED DIAGRAM FOR LOCATION
Some printers can connect either to a "parallel-port" or to a "USB-port" on a computer.
So, if you have one cable connecting your printer to your computer, then the other cable is "surplus" to your needs.
Nov 15, 2010 | Canon S200X Ink-Jet InkJet Printer
Can't print or scan through USB port on Canon imageRUNNER 5070.
The port should be active. You can look for problems by right-clicking My Computer and then Properties. Under the Hardware tab, press the Device Manager button. Any hardware issues will show either a question mark or exclamation mark, disabled items with a red x. After the printer is connected, turn it on, then go to Start -> Control Panel. Here, go to add hardware. See if this finds it.
If not, have you added the printer after connecting it via USB under Start -> Printers and Faxes? What about inserting the installation CD before connecting the printer?
Apr 20, 2009 | Canon imageRUNNER 5000 Copier
50 people viewed this question
old marine
old marine
