Question about Epson Office Equipment & Supplies
Inserting inks in new Epson WF2760
The carriage won t move to allow me to insert inks About
  • 3130 Answers
SOURCE: epson stylus 777 printer
isent this the same printer that you asked about with a problem with the carrage not working correctly after disassembly to rerplace a roller?? If it is then you ptobably have a sensor misalighned or unit still is not "timed" correctly.
Posted on May 12, 2006
  • 38 Answers
SOURCE: Still stuck ! color cartridge carrier won't move to allow my replacing them as you have suggested.
What kind of cartridges did you replace with?
Like with original ones or the other replacement you get in market.
Because with use to duplicates you get this problems many times.
If you are using original cartridges then try replacing all the cartridges at once.
And even if this does not work then may be you need to take the printer to the vendor to get it repaired.
Posted on Jul 18, 2008
  • 353 Answers
SOURCE: Epson Stylus C66 inkjet Printer does not print !
Have you tried a cleaning cycle? If not, try one. Now run a nozzle check using the status monitor (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back.
Posted on Feb 01, 2009
SOURCE: Just installed Epson NX400 printer.
I found a solution to the same prolem that you guys have. I took the cartridges out and shook them horizontally, instead of vertically, with the large surface up for 3-4 seconds. Re-inserted them back in. Then I started seeing on the LCD "Recharging Cartridge". When it returned to regular copy screen, I turned the printer off and turned it back on. No more error message. It's been working for almost a day now. Try it to see if that works for you. Good Luck.
FYI. I just bought NX400 last Friday. The error message came on this morning.
Posted on Mar 06, 2009
  • 1218 Answers
SOURCE: Epson R320 carriage jammed
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
Posted on Oct 04, 2010
Ink carriage is stuck on right side how do I make it move to but new ink into the printer
Look in the left side of the printer, you'll see some wheels
Shut the printer down and pull the power cord
manually rotate the wheels until the little lever that block the carriage moves
When the carriage is unlocked, you are free to move the carriage.
Hope the Best
ADCSFXworks printing center
Oct 17, 2014 | Epson Workforce 520 Printer
I have an epson sx510w how to change ink cartridge
use the tool button to access the menu and let it know you want to change cartridges. IF you dont have the instructions then go here and download the basic operation guide
Jan 08, 2012 | Epson Office Equipment & Supplies
Printer is running out of ink. To put new cartridge in I lift the lid and normally cartridge carrier moves over to left allowing replacement of cartridge. Today no movement---why? Green light is flashing...
Hi there.
It's probably jammed by dirt. Unplug the printer, move the carriage out of the way and clean thoroughly the metallic rails the carriage runs to using a cue tip.You might have to move the carriage multiple times to clean it totally. Finally spread a little fine grease over the metallic rail and again move the carriage from side to side. Now plug it in and try using it.
Let me know what happens.
Sep 11, 2011 | Epson Stylus C46 InkJet Printer
I want to change black ink cartridge in Epson Printer TX110
If ink level reach ink out level, follow How to.. on Epson status monitor. But, if it's not, turn off printer. Unlock carriage lock, then move carriage by hand. Or you can turn on printer and unplug power while carriage moving. Then move by hand freely.
You should be able to follow the bottom link and find it or you can check this answer .
Hope that helped..
Nov 05, 2010 | Epson Stylus NX400 InkJet Printer
How to change the ink of an epson stylus sx215
press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartidge". the ink cartidge will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then they just pull out
Jan 07, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Trying to bring ink holder in position to insert ink
Turn off printer, release carriage lock. Or turn on printer and unplug power while carriage moving, then move carriage to replacement position.
Jan 01, 2010 | Epson Stylus NX400 InkJet Printer
I am trying to put new ink cartridges ito the epson stylus ns400 series epson ink jet printer. how do I do that?
Hold the ink button down for 3 seconds, the carriage unit will move out to allow you to change the cartridge
Dec 13, 2008 | Epson Stylus NX400 InkJet Printer
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R320 InkJet Printer
Here is how to get the ink cartridges to move to the changing position on the R320.
1. Press the paper jam/ink button on the printer control panel.
2. A menu comes up. 1st item is ink cartridge replacement. Press
OK button.
3. Another menu with ink cartridge replacement. Press OK button.
4. Thats it, ink cartridges move to the changing position. Change your cartridge as you normally would and follow prompts on screen to finish process.
Hope this helps.
Aug 21, 2008 | Epson Stylus Photo R320 InkJet Printer
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
