Question about Food Mixers
How to replace a fuse on a gtd audo bm 225 mixer
WHERE CAN I GET FUSES FOR THIS MODEL AT
Garrett, there are not any replaceable fuses in the KSM150 models. What is the issue you are having with the mixer and we can help you find the right parts.
Also here is a link to the service manual that will help you with trouble shooting and finding correct parts for your mixer.
http://ep.yimg.com/ty/cdn/mendingshed/kitchenaidservicemanual.pdf
-Colleen@ Mending Shed
May 12, 2015 | KitchenAid Kitchen Aid 5 Quart Stand Mixer...
Speed control
The first thing you need to do is remove the end cover on the mixer, there is a screw at the top you need to undo then in an upwards motion you should be able to pull that off. behind there is the speed control plate. there are two screws at the top, and one at the bottom, the two at the top need to be adjusted the same amount, to speed up the mixer you turn the screws out, to slow down, you turn them in. you want to do each screw 1/4 turn, then test the mixer, see if this will slow the mixer down, so it regains the other speeds. If this adjustment does not work, then the problem will be the phase control board, that is part number W10325124, we sell the board, here is a link to that on our website: http://www.mendingshed.com/kaphaseboard.html.
Also, here is a link to the service manual for your mixer, it will go into more detail on taking the back cover off, and adjusting the speed control plate. Also if you do end up needing to replace the phase board it will show you how.
Service Manual: http://ep.yimg.com/ty/cdn/mendingshed/kitchenaidservicemanual.pdf
If you have any questions feel free to call us.
Colleen
The Mending Shed
801-225-8012
Mar 21, 2014 | KitchenAid Food Mixers
Replaced phase and speed control board and mixer still doesn't work! Bad words are flying around here tonight!
Michelle,
Have you taken the brushes out of the mixer at any point? I see quite often people remove the brushes, and then they are inserted incorrectly when put back in, the brushes will fit in in any direction, but there is only one way to put the brushes in properly.
when you look at the brush, the carbon portion is square with one side cut off, the brush holder inside the mixer is shapped the same way. use a flash light to match up the brush, after installed correctly the mixer should turn on and function correctly.
If it does not then you should call into us, when around your mixer and we can do more trouble shooting over the phone.
Thank you,
Colleen
The Mending Shed
801-225-8012
Mar 20, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Teeth on plastic gears for mixer are worn down
Even if you could obtain the parts, a 10 year old mixer is well past its prime.
Jan 17, 2018 | GE 106772 HandStand Mixer
It just stopped during use and seems completely dead!
Replace the fuse located below the plug inlet on the mixer,(it is a 6.3A Fuse, 250V 5x20MM fuse from Radioshack) you have to remove the outer panel to access it. I did the same thing, it stopped working while I was mixing dough for bread, replaced it, good as new.
Aug 11, 2010 | Jenn-Air Attrezzi JSM900 Stand Mixer
Piezas para reemplazo de mixer pro 600
Hola de nuevo PASTELERIARU. Haga clic en este enlace al sitio web del http://www.kitchenaid.com.mx/Contacto.aspx KitchenAid Internacional para México. Espero que sean capaces de señalar a los vendedores de partes en México.
Buena suerte otra vez, Howard, Burke, Inc. EE.UU.
Si esta solución ha sido de ayuda, por favor vota, gracias!
- Hslincoln
Feb 18, 2010 | KitchenAid KP2671 Professional 6 Series...
Engrane principal
Hola PASTELERIARU, hay varias marchas en su mesa de mezclas, así que me permito sugerir la descarga de las partes de su mezclador manual de la Lista de KitchenAid (KA) en: http://www.kitchenaid.com/flash.cmd?/#/page/home para ayudar a identificar exactamente el arte(s) y número(s) que necesitan ser reemplazados.
Haga clic en Customer Care>Locate Manuals & Guides> e introduzca el número de modelo de 6 caracteres de su mesa de mezclas, en su KP2671 caso de uso. Existen 4 versiones diferentes de la Lista de piezas de este modelo, por lo que se revisará cada uno y seleccionar el manual que corresponda a su mesa de mezclas.
Gire a la página titulada "Case, Gearing and Planetary Unit", que muestra el despiece de las partes el mezclador interno y las asambleas. Todas las piezas están identificadas con un número Ilustración y el número de parte. Con el número que usted puede solicitar una pieza de repuesto a un proveedor en línea y sustituirla por ti mismo.
Aquí están cinco posibles proveedores de EE.UU. en ningún orden en particular: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; y Grainger.com (de grasa). Usted debe buscar "la grasa de grado alimenticio 'en línea (aunque he visto Grasa para rodamientos automotrices usadas también - la llamada). Los precios pueden variar ampliamente entre los proveedores, por lo que hacer algunas comparaciones.
Si esta solución ha sido de ayuda, por favor vota, gracias! - hslincoln (Continúa en comentario - Parte 2)
Turntable does not turn. Motor runs. Beaters work.
I have the same one, and the turn table has never turned on it's own. from looking at the bottom of the stand, i think the mixers are supposed to turn the bowl, so i just give it a little turn, and the mixers kinda take care of the rest. BTW, i got 2 sets of beaters with mine and i dont know what the second set is for, do you? contact me at rawemo@hotmail.com
Feb 18, 2009 | Sunbeam Food Mixers
My mixer motor doesn't work
check and replace the plug fuse and internal fuse of the mixer
Oct 13, 2008 | Sunbeam 2370 MixMaster Series Stand Mixer
Food Mixers Logo
62 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
