Question about Sansui Televison & Video
Where can i get a sansui tv power supply board model SV-3715 LCD
It does not supply power and no pictures. I need a power supply board
  • 5 Answers
SOURCE: akai lct3201 ad power supply
Hi doonz75
I got same problem with MLT169A power supply it wont power on. but i found service tech who fixed my power supply. but he stays in toronto, canada. only thing is you have to pull power supply out and mail it to him. his email is
Posted on Apr 08, 2008
what is the cost of picture tube for model SV 2102
Posted on Sep 14, 2008
SOURCE: sansui tv sv2918
replace vert IC301, C432, ( D431 & R431 should also be blown)
Posted on Nov 26, 2008
  • 2326 Answers
SOURCE: no picture
The way to isolate the failure to the power supply would be to measure the voltages going to the backlight inverter board. If all the voltages are normal then is more likely a defective backlight inverter board or LCD controller board.
Posted on Jan 05, 2009
SOURCE: I Have a Philips LCD TV model#30PF9946D/37.
Oh yeah, you can most certainly change the power supply by yourself.
It's easy to locate - just follow the power cable - and easy to replace.
Only make sure to let it discharge before you operate it. 10-15 minutes disconnected from power should do.
However, there's no guarantee that the problem is in the power board.
There is a very good chance it is, in fact, not there.
There's another board which commonly fails on many plasma TVs and the effect is exactly as you describe. It's called Y-Sustain board and you can tell which one it is by looking at the side of your TV and seeing which large board has manny plastic connections that enter the display on the side.
That board often has one or two fuses on it - I'd check those first.
Posted on Nov 03, 2009
Hi i have got sansui TV model sv-4200lcd with no picture but oudio is fine
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 23, 2016 | Sansui Televison & Video
Hi, I have a Sansui SV-4210 LCD HDMI TV . It does not switch on with the remote and only works once I unplugged the power cable and plug it back again. Lately it occurs every time and I have to do th
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 20, 2014 | Sansui Televison & Video
Our Sansui HD LCD 3212 32" has audio but no picture. Can you tell me what is wrong and how to fix it. This TV is not used much and went our of the 1 year warrant January of 2011.
Must have to take the tv aparts.U must have all the tools and understanding basic electronic and also u must able to do basic soldering works too?Yes,u must have to do examining the tv power supply board carefully,that the board where the tv power a/c cord plug into it.U must have check all the tv capacitors components parts,if the tv have any bulges or puffing up any capacitors parts at all will and could causes these problems.U must have to changes all the tv dying and leaking capacitors parts in the tv power supply board will to help the tv power supply board to work correctly again.If u check and examining tv power supply board carefully but have seen none or any dying and leaking bulges or puffing up capacitors parts at all.Than this tv have a 1 or 2 long boards that are called the LCD inverter boards it is dead.These 1 or 2 long inverter boards only job are to help and provided the tv LCD screen panel to have a backlight on the screen to see a picture on the tv LCD screen panel.Must have to be changes 1 or 2 long inverter boards to fixed the tv have sound but no pictures problems.If u can't do soldering work and can't changes capacitors components parts at parts levels.U can tries websites like, to buy a whole new refurbish tv power supply board and or the 1 or 2 long LCD inverter boards too for the replacement.
Nov 10, 2011 | Sansui HDLCD-3212 32 in. LCD TV
Picture shows for 1 sec when switching on TV, and then screen goes black on my Sansui TFT SV-2010 LCD Monitor
Now u turn on the tv the tv pictures only flashes a few sec.than dies,but the tv still have audio sound left only?Yes,mean ur tv have a 1 or 2 long boards that are call a LCD inverter boards are the causes and the problems.These 1 or 2 long LCD inverter boards only job are to provided the tv LCD screen panel for a backlight for the tv to have picture only.Tries websites like, to buy a 1 or 2 the tv long LCD inverter boards for the replacement.
Oct 03, 2011 | Sansui HDLCD3210 32 in. LCD TV
Sound but no picture
Ur LCD inverter board it dead.Replaced the LCD inverter board.U will get ur picture back.Tries websites like,Ebay,com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
May 09, 2010 | Sansui HDLCD3210 32 in. LCD TV
Televison & Video Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
