Question about The Office Equipment & Supplies
5th number light is red
The printer ready light is blink red. the toner is new. printer roler is not moving. what can i do now?
SOURCE: Red "Paper" light blinking Brother HL-2040
I agree with another su=olution. The paper light was blinking on and off sugesting a paper jam. Paper had jammed in the back roller and displaced the small lever out of its slot.
Open rear cover, open paper guide by pulling it downwards so you can see the rollers, In the middle of the guide you will see a black lever about 25mm long to the right of this you will see a small slot. The guide will have been pushed to the left of this slot and the Plastic cam will be bowing toward the front of the printer (about 3mm). You need to pull the 25mm lever towards the rear of the printer and then slide the plastic cam to the right so the blade part of the cam slides into its correct slot. The blade is about half a mm thick and the slot is the same and is about 60mm to the right of the lever Use a torch to see it easier. This is a 2 minute job once you see what is wrong.
Hope we have helped someone out there fix a printer
Posted on Jan 19, 2009
SOURCE: Dell 1720dn toner error
You have to reset the drum count on the printer after you replace the drum. Call dell tech support they will not charge you for help resetting the drum even if you are not in warrenty.
Posted on Feb 19, 2009
  • 6 Answers
SOURCE: resting the toner ctridge
Yep, some cartridges have a lockout chip that restricts the print of more pages once the maximum rating has been reached. Since you have refilled the toner cartridge, I would have expected the seller to mention that the page counter needs to be reset by replacing the lockout chip with a "reset chip" so it can print again. Here's additional info on that:
http://lasertekservices.blogspot.com/2009/08/why-replace-reset-chip-of-toner.html
Posted on Nov 04, 2009
SOURCE: R230 Epson Printer
I cant print coz of my printer (R230 Epson Printer) blinking 2 red light. Printer dosnt ready. It say-Service required. how can I release this problem. Plz tell me.
Posted on Nov 19, 2009
  • 11 Answers
SOURCE: Red light blinking and printer error "check printer ##330" appear
## 330 Power Supply (Replace/Repair)
Replacement part number is HH3-5278
Posted on Jul 02, 2010
Blinking amber light next to black toner?
the blinking light means the toner is getting low
when the blinking light yurns solid its time to change the toner cartrige
Jun 12, 2014 | Dell 1320c Laser Printer
When printer is turn on that time printer reddy and cartridge light on so what is the problem
You can see four LED's on control panel, from top to bottom,1st is toner indication 2nd Attention 3rd is Ready light, 4th go light.. Observe led's are 'blinking' or 'On' condition.. # If toner light is blinking ="toner cartridge missing or contact problem or memory faulty.
# If toner light & ready lights are on= "toner low indication or refilled cartridge loaded".
Jul 12, 2012 | HP LaserJet P2015dn Printer
On HL 1440 Laser Printer, ready and alarm lights (red) on control panel are lit.
Don't fiddle with it you'll just mess with it more take it in and see what they can do if not i suggest you by a new one.
Nov 28, 2011 | Brother HL 1440 Laser Printer
I have insalled new toner and the printer still has a blinking red light, i restarted the printer and nothing...help.
i have insalled new toner and the printer still has a blinking red light, i restarted the printer and nothing...help
Jan 31, 2011 | OKI C3400n Laser Printer
My Brother HL-2140 Went out in a storm. All three lights just keep blinking no matter what I do. Held down on the blue light button a number of time, restarted computer, turned off printer, reloaded ink...
You can find the usre's manual here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hl2140_all&dlid=&flang=English&type2=-1
1) If the LARGE BLUE BUTTON is blinking:
Data remaining in memory
There is remaining print data in the printer memory. If the Ready LED is blinking for
a long time and nothing has printed, press the Go button to print the remaining data
in the memory.
2) If the TONER LED is blinking:
Toner low
Indicates that the toner cartridge is nearly empty. Buy a new toner cartridge and have
it ready for when Toner life end is indicated.
The Toner LED will turn on for 2 seconds and off for 3 seconds.
3) If the DRUM LED is blinking:
Drum life end soon
The drum unit is near the end of its life. We recommend that you get a new drum unit
to replace the current one. See Replacing the drum unit on page 69.
The Drum LED will turn on for 2 seconds and off for 3 seconds.
4) If the RED ERROR LED is blinking:
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document.
Mar 26, 2010 | Brother HL 2140 Laser Printer
ML-2510 Laser Printer : persistent blinking red light
Dear
This problem you will be noticed when toner is 90% empty.
Does the printer is functioning or No. If yes the problem is 90% toner is finished.[10% toner remaining alert]
If printer is not functioning Please change the toner from Genuine dealer. Else your printer fails due to non genuine and refilled toner.
Nov 11, 2009 | Office Equipment & Supplies
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
Samsung printer ML 2510 series
Maybe the toner is low... According to the manual, a blinking red light:
• A minor error is occurring and
the printer is waiting for the error
to be cleared. When the problem
is cleared, the printer resumes
printing.
• The toner cartridge is low. Order
a new toner cartridge. You can
temporarily improve print quality
by redistributing the toner. See
page 8.3.
• The toner is totally exhausted.
Remove the old toner cartridge
and install a new one. See page
8.4.
• The toner cartridge reached the
end of its life.
Feb 24, 2009 | Samsung ML-2510 Laser Printer
Printer won't print
According to the operation manual: If alarm light and data light blink every 5 seconds- TONER LOW (purchase more toner and have it ready when the 'toner empty' is indicated). If alarm light and data light stay lit- TONER EMPTY (replace toner cartrige with new one).
Apr 21, 2008 | Brother HL 1440 Laser Printer
22 people viewed this question
Top The Office Equipment & Supplies Experts
Victorman
Victorman
micky dee
fhonwizards
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
