Question about The Office Equipment & Supplies
The word white paper means? - The Office Equipment & Supplies
My canon displays p and it will not copy
P means paper. load enough paper in the cassette or clean the pick up rollers they might be dirty leading to not picking paper
Dec 01, 2010 | Canon PC-920 Black and White Copier
What is massige " cheek your document"?in canon copier model ir2016i sanks
do you mean CHECK DOCUMENT SIZE?
If yes, check the paper size slider in cassette, check under printer properties custom paper size, it should state the paper wich is in cassete.
Aug 11, 2010 | Canon iR 2016i Black and White Copier
Error Code U 6
Error code U-6 means the door on the RHS of the machine is not closed properly.
Jun 24, 2010 | Panasonic FP-7735 Black and White Copier
Red mark-out of paper,when it has paper?
It means that its white paper sensor is already dead. Have the white paper sensor replaced by the manufacturer.
Nov 06, 2009 | Brother HL-5240 Laser Printer
Prints have a thin white line across all the images printed. Everything else works and prints are ok outside of the thin white line running horizontal across the 5x7 prints.
  • Thermal head — generates heat; prints on paper
  • Platen — a rubber roller that feeds paper
  • Spring — applies pressure to the thermal head, causing it to contact the thermo-sensitive paper
  • Controller boards — for controlling the mechanism
I think that you may need to replace your thermal head, A line means there is a place that the head can not head or it cannot recieve data
http://www.youtube.com/watch?v=LWs74J7EfjM
How to matinence it and clean the head
Oct 21, 2009 | Sony UP DR100 Thermal Photo Printer
I have proplem in canon ir 2020
Under service mode *28* find the clear all and OK, after that you shouldnt have any pass required, but you need to set the IPadress, and your preferd sets.
Apr 05, 2009 | Canon iR 2020i Laser Printer
Canon PC-921 copy machine error message "P"
Load paper.If there is paper in the tray,there is a problem with the paper pick up.Try to use the Manual feed try.
Oct 26, 2008 | Canon PC-921 Black and White Copier
Check Paper
Check paper can also sometimes mean a jam. Remove the drum unit from the machine and check for a piece of paper inside the machine.
Also with this machines feed path it can mean that a foreign object can fall down the back and obstruct the paper.
Feb 12, 2008 | Brother IntelliFAX 2800 Laser Fax
22 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
