Question about Huawei Cell Phones
Hi My Huawei wont charge
It fell from hand and then the main screen was coming at 80% .. ie not on full screen. but no buttons or screen were working I restarted it but ended up at same point. I tried to reset it by pressing both power and volume buttons but restarted at same point .. now its run out of battery and doesnt change. When I press power button, battery icon gets lit which is empty without power sign ie not charging. Same Huawei (original) charger does charge other phone. Any suggestions ?
    New Friend:
  • 97 Answers
Fone fell if screen doesn't respond digitizer has gone bad, charger port also damaged I'd recommend getting a new device since it will cost alot to repair that
Posted on Apr 18, 2017
vortash
  • 431 Answers
SOURCE: Lg Vu wont charge
First you must determine is it the charger faulty or the phone ? , have you a friend with the same phone if so try her or his battery to see if your phone is ok if so try the charger with your battery and see if it charges if it does get a new charger , if it did not charge or work with your friends battery or charger the sorry it would be cheaper to buy a new phone than try to get it fixed ...
if you haven't got a friend with the same phone have a local electrician check if there is an output from your charger . if there is it may just be the battery try a new one if still no luck it is probably the phone's charger circuit gone pop ,, sorry .. vortash
Posted on May 13, 2009
  • 62 Answers
SOURCE: The buttons...well..they don't work.
If you slept on it you might of got the keys stuck. so find one of the solved problems to open up your keypad and check if theor stuck or if the cabel is loose.
Posted on Mar 28, 2007
  • 67 Answers
SOURCE: Nokia 3250 charging problem
you must change the charging block /base pluck or go to the service provider will do it for you. advice by dogy.
Posted on Dec 21, 2007
SOURCE: my iphone wont go past the apple logo
hi juli this is glady even i faced the same prob in my i phone to so download a new firmware from apple site nd then switch off ur cell while conectd to ur pc then switch on through ur apple pc suite upgrde ur phone through the i tunes o give the path nd see or better to go to youtube for more crystal clear info bye
Posted on Jul 20, 2009
  • 363 Answers
SOURCE: My iRobot scooba won't turn on after a full charge
Do you have the charger terminal, or do you have the charger that you have to take out the battery and charge. Because I have found that my base terminal charger works better than the battery charger that needs the battery to be removed to charge.If you have the terminal charger and the power light is green when it is in the charger I would start from the terminal
Posted on Jul 27, 2009
How do I fix Android Huawei Ascend phone? It's stuck on the start-up screen.
You can recover your phone by holding down a sequence off buttons when you switch it on and it will go into recovery mode and there you can factory reset it to fix it
Jun 28, 2014 | Huawei Cell Phones
Apple ipod 30gb video
the recharge time on a fully discharged battery is 6 to 10x the discharge time. so, if that battery was good for 2 hours, the recharge could take 12 to 20 hours..sit back and see how it goes.
May 01, 2008 | Apple iPod MA446LL/A MP3 Player
I have a huawei m865 muve im in need of help its stuck wont turn on please help me
As for the charging of the phone: you probably had a faulty wire in your chargercord, that is the most common problem, not the chargeplug. So taking the phone apart was probably not necessary.
How about taking the back of the phone, take out the battery, check the copper plates on the battery for smudges. If so. take a q-tip, moist the q-tip in some spirt en gently(!) clean the tiny copper plates. Leave to dry, make sure there's no cotton from the q-tips left on the battery. Reinstall the lot. And recharge.
Good luck! Let me know if this worked.
Mar 15, 2014 | Huawei Cell Phones
Com.android.huawei.keypadprogramming (process.android.huawei.keypadprogramming) has stopped working unexpectedly
I had to call my phone provider to get the answer.
press up volume and hold while pressing power and hold until
it comes to a screen with choices on how to fix your phone. use the volume button to go up or down the choices. that's all i remember
good luck
Oct 01, 2012 | Huawei Wholesale Lot Of 10 Ascend Ii M865...
I require a mains charger for Tomtom 4n00.001. I need to charge it from home
You can buy a Tomtom main charger but they are fairly expensive.
You can use a Main powered USB charger along with your normal PC Tomtom USB cable: it should ideally be rated at 1 Amp or more.
You might even have a suitable main USB charger on hand now as they often come with generic MP3/MP4 players and some mobile phones: I use my Huawei U8150 or E585 modem charger for that purpose myself!
Hope it helps.
Sep 23, 2011 | Tomtom ONE GPS Receiver
New out of the box wont power on
Hi.. Let me try to help you if I can... I'd like you to check a few things,
1) Open battery cover on handset & make sure that the battery pack is installed correctly, and not upside down. Also make sure the little wires that come from battery pack are plugged into the tiny jacks of the phone (usualy red & black wires) in handset is fully attached & pushed snuggly into the handset... and if No wires, check to ensure the part that does connect the battery to handset is not covered with a plastic film of tape or paper as right from a manufacturer they sometimes do that to preserve length of battery until product is sold to you..
2) Check the bottom of the handset phone, that sit in the cradle of the electric part of the recharger, and make sure there is nothing like plastic or paper covering the connections between the bottom of the handset and the charger. Make sure there is a full on connection for a full charge to the handset. As with some cordelss phones Ive had the red LED light will not come on if there is something blocking a full connection for a charge.. The red LED light on base, only comes on when the electricity is flowing into the handset. The slightest tilt not allowing handset a full charge, wont give it a FULL charge.
3) You say " NEW. Out Of The Box" I hope when you connected the battery pack into the handset, and made sure it was connected right, you then allowed handset to charge at least a FULL 12 -24 hours before trying to use your new cordless phone. as the batteries right out of the box, are rarely already fully charged when any cordless phone is bought and then it does need 12 - 24 hours for a FIRST FULL CHARGE...
If you can check all 3 of these questions, and let me know how things are back on this posting, if you stilll can not solve the problem after a full charge to battery, I may have some other ideas that can help.
Good Luck
Stevie
Feb 14, 2010 | Uniden Cordless Phone
Fell, won't turn on
for sure the main board its broken and 80% chances that the picture tube has some internal damage that may can cause a rainbow effect, discoloration or color shadows. if you want it to try you can find the broke line traces on the main board , you can buy some tools at any radio shack store , and follow intructions . but its your bet to try the risk to have that picture disoloration and or learn some electronics
Jun 09, 2007 | Toshiba 19A21 19" TV
Cell Phones Logo
50 people viewed this question
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
rostit
 Brian Main
Brian Main
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
