Question about The Office Equipment & Supplies
The green paper means? - The Office Equipment & Supplies
Does anyone know what the flashing green power indicator means on a Lexmark Z1480 printer? I don't have the manual anymore, and the Lexmark website does not have any information about the blinking green...
If it is blinking fast, it means that you have something in the paper path. Check the paper path.
If it's blinking slow, it means that paper has run out in the middle of a print job. Add paper.
Oct 13, 2009 | Lexmark Z1480 InkJet Printer
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Kyocera FS-920 RED LIGGHT IS BLINKING AND GREEN LIGHT IS OFF
There are 2 possibility to cause your printer acting like this:
1) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
2) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
If it is condition 1) then just remove the jam paper then open and close the Top Cover to clear the error.
If it is condition 2) then insert some paper in the paper tray.
YBC (/\)
Jun 05, 2009 | Kyocera FS-920 Laser Printer
Kyocera fS-920KX. Not printing
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
What does yellow flashing lite on top right of deskjet 670C mean.
It indicates paper jam or out of paper. Try to see if somethings stack up inside.
regards,
-engrkoiled-
Mar 27, 2009 | HP DeskJet 670c InkJet Printer
Kyocera Ecosys FS 920
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Lights on printer are alternating between red and green flash
try to reset the printer by opeing the front cover and close it again.
Mar 17, 2009 | Samsung ML-2510 Laser Printer
My printer has two flashing lights
try to rest the printer by opening the front cover (not the paper tray) and closing it again.
Epson C84 paper light is on and power light is flashing what can I do?. E Green.
Please check if there are any foreign objects inside the printer. And unplug it from the computer and test if you can print just using the printer itself without using the computer.
Make sure there is paper loaded on the printer and the printer is OFF.
Hold down the paper button and press and release the power on switch, if you can see flashing green light release the paper button. Just wait till it feeds on paper. If it feeds on paper and prited on a pattern it means the printer is working fine, but if not you have to call your manufacturer of your printer.
Feb 28, 2009 | Epson Stylus C84 InkJet Printer
Can you help me with kyocera fs-1030d
If a paper jam occurs while printing, the printer notifies it by the following combination of the four indicators. Remove the
jammed paper . After removal, open and close the top cover once to initialize the jam sensing
Dec 04, 2008 | Kyocera Mita FS-1030D Laser Printer
11 people viewed this question
Top The Office Equipment & Supplies Experts
Gareth Cockram
Gareth Cockram
Tygh Duval
Tygh Duval
Jerry Greenberg
Jerry Greenberg
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
