Question about The Office Equipment & Supplies
Error 68:01 substrate jammed and i have removed the substrate, but the error still occuring
pagebor
  • 2785 Answers
SOURCE: Remove Misfeed B Fusing Unit Error- After 1 page is printed
just open the printer and check for any dislocation of the sensor or levers.
Posted on Apr 26, 2008
  • 81 Answers
SOURCE: Jam error B3S
This is a problem with the preheater sensor. It could be a clutch, paper tray seperation pad, or (my vote for most likely) the preheater assy. Not too expensive, but you should get a technician to look at this.
Posted on Jul 23, 2008
SOURCE: Kyocera KM-3035 - Paper Jam 00 error. Paper removed, still not working.
Check to make sure that their is no paper that is jammed in the paper draw. Also open the main panel where you would change the toner and pull out the little draw underneath the toner, I believe it is marked A2. Make sure that there is no paper there as well. Another place that paper will sometimes hide is in the left panel by the duplex system. Sometimes a little piece of paper gets left behind and this can cause the system to think there is still paper jammed in the machine. If all else fails try restarting the system. If you are still experiencing a problem than I would recommend you call your servicing dealer.
Hopes this helps.
Henry
Posted on Aug 15, 2008
1alexh
  • 484 Answers
SOURCE: Paper Jam error will not reset after removing jammed paper
In many cases, you must use compressed air in a can, and blow out the insides of the printer. These printers use photoelectronic eye technology to tell you when there is no paper left, or other supplies are used up. But unless you clear that out by blowing air through and past those sensors, they do not reset. The paper dust continues to block the sensor which makes it report that there is no paper, that there is a paper jam, etc.
Try clearing it out that way.
-a.
Posted on Jul 02, 2009
yammy_alf
  • 666 Answers
SOURCE: get Print error occured on screen,sounds like
check for possible paper scratch inside or in between roller, try to feed paper manually by turning roller. and observe if no abstraction when feeding also check if sensor key is working.
Posted on Apr 09, 2010
SX415 Error message A printer error has occurred - switching off and on again results in the same message.
Diagnosing the Problem - Epson
https://files.support.epson.com/htmldocs/rx620_/.../trble_1.htm
EpsonAn error has occurred in the printer parts. Turn this product off, and then back on. If theerror message still appears, contact your dealer. Scanner error occurred.
Epson printer sx415 printing problems/paper jam - Forum Thread ...
www.pcadvisor.co.uk > Forums > Tech Helproom
Jun 30, 2010 - Epson printer sx415 printing problems/paper jam ... before it will work correctly again otherwise you will continue to get the error message.
Oct 08, 2015 | Epson Stylus Office Equipment & Supplies
You can explain to me that it produces the error 45.1:03
Page 46 here.
"Possible substrate jam"
if no substrate is jamming, check the reflector on left side of carraige for dirt, dust, or ink
Aug 28, 2014 | HP DESIGNJET T1200PS 44IN 2ROLLS 32GB RAM...
6b10 error, meaning?
Hi this is what i found for your problem hope it helps thanks. Paper feed cam sensor error or Error Code 6B10
Condition: An error occurred in the paper feed cam sensor during paper feeding from the cassette, or the paper absorbing a large amount of ink jammed in the PF rear guide.
Problems and Solutions:
  • Jammed paper in the PF rear guide (when a large amount of ink was absorbed in the paper);
    - remove the jammed paper and foreign material.
  • check for foreign material or paper debris in the cassette or in the PF rear guide;
    - remove foreign material.
  • If other solution fail, replace one off the following part
    - PF pick-up unit
    - Logic board
Sep 21, 2011 | Canon PIXMA iP2000 InkJet Printer
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
"error occured,call service person
Try unplugging it for 10 minutes. While unplugged, press and hold the start and stop but for 10 seconds. Double check for any paper jams. Just the smallest piece can jam it up. There should be a list of error codes for anything wrong. List paper jam would have an error code, change toner, change or clean ink, ect. Is this the only message you get? If that's so, try the steps I mentioned above so the machine resets itself. It the problem still occurs, let me know I will gladly help you to correct this problem.
Jan 27, 2011 | Kyocera Copystar CS-1820 Black and White...
My printer lexmark e342n 201 jam error code, what the are problem, fuser or pick-up roller and how to soft that problem. tq
If you are getting 201 error code, it means a paper jam has occurred. To fix this problem please Open the front door. Remove the toner cartridge and remove the jammed print media.
Click on the link http://bit.ly/p1jJcd to see instructions on how to go about the procedure.
For further assistance, please contact Lexmark Technical Support.
Jan 22, 2011 | Lexmark E342n Laser Printer
Optra 2450 error 241
24X Paper Jam message displays, Paper jammed over the Pass
Thru Sensor. (The printer displays the value of X for the paper tray
where the error occurs. Example: 241 is a Paper Jam Tray 1)
That is a quote directly from the service manual. You have a paper jam, or some tiny bits of paper stuck over the pass thru sensor. Remove debris and clean out to fix your problem.
Thanks and please take a moment to rate as fixya.
Nov 10, 2008 | Lexmark Optra S 2450 Laser Printer
Paper jam 11
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 07, 2008 | Copystar CS-1815 Printer
Jam error B3S
Jun 26, 2008 | Xerox Phaser 8500/DN Printer
Apr 26, 2008 | Ricoh Aficio AP3800C Laser Printer
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
